mx3 radio
#17
i was looking more at the mx3 s radio and i think i will just save up for it because i would rather pay the extra and not have to worrie about stupid crystals! but im still worried about that NO abs feature, how important is it? i dont want to be burning up my speedo!
and should i get the one thats on the 24 or the one thats on the 72mhx band? whats the diffrence between the two?
#18
the 3pm also have a synthesized version,the 3pm-fs.but i dont think it is available any more.cant find it anywhere.but it is also available with transmitter synthesized(with normal receiver) which doesnt make any sense at all
#19
how important is abs? if i dont have it will i run a high risk of burining up a speedo?
whats the diffrence between 24 and 2mhz?
#20
it is just the frequency i think
#21
anti lock break uses pulses on the circute which will give extra work to ESC in eletric car or servo in nitro car
most ppl i know (nitro driver) do not use anti lock break cuz they afraid of burn out the throtal servo
#22
If you live in Socal and want the MX3s I would advise against it. I have the standard MX3 and it works great. I got the Mx3s and Ive had nothing but glitching problems with it ..after returning the system for a new one and then 2 more recievers..Ive had nothing but problem at So cal raceway with it..Airtronics is working with me but i have been able to practice or race in a while its so bad..
#23
the difference between 27 and 75 mhz is that 27 has only 6 channels to choose from, 1-6, and 75 has many more(not sure how many but there are enough to choose from at a race).
and about the ABS-you are right most people dont use the feature because the brakes usually dont get hot enough for them to melt! i personally think that it de-stabilizes the car when braking.
#24
Originally posted by macnkitty2002
...but your speed control should have the ABS feature with it, most do...
I have ABS in my radio, I'm running electric with one-way on carpet. I dont brake at all, so I wouldnt say ABS is needed...
#25
well the esc i plan to get is the lrp prs sport it say it has "EMF Brake w/APC (adjustable power conrtrol) to prevent locking"
dont know what that is? but yeah im not really worried about the abs because my stock rtr tc3 doesent have it and i havent had any problems what do ever with the break, and....
macnkitty2002 your running the same radio im looking at with out abs and i assume you use electric? have you had any problems?
#26
Cole Trickle- i must have been mistaken. i think what i meant was that alot of radio systems have ABS. your ESC should have some sort of braking feature, either delayed reverse(if you have a reverse ESC) or some sort of brake strength feature. it all depends on your ESC.
kh15-i run the MX-3S 27 mhz in my gas touring car and my mini-t. so really, i know about both. i dont use the ABS at all on my gas tc, like i said before the brakes dont get that hot. and in my mini-t, it works fine. i personally prefer the 27 mhz because really no one uses it in gas tc, and in electric i still have 5 other channels to choose from. no glitching at all. the ARC feature is helpful too.
#28
http://www2.towerhobbies.com/cgi-bin...p?&I=LXGRA7&P=
thats the one! i just need to save another 50 bucks or so and then i will order it!, its fm, sythisized, and 27mhz, one servo, one switch....very nice! i cant wait
and then i will be useing my old tc3 radio for my yet to buy rc12l4 1/12th pan car!
#29
http://www2.towerhobbies.com/cgi-bin...p?&I=LXGRF1&P=
with the MX-3S radio system you will be getting, all you have to do is just get another receiver and use the same transmitter with two cars. ever noticed how the radio says "18 model memory", that means that you can store your settings for 18 different cars(if you ever had that many). thats what i do, i have two receivers and one transmitter, i just change channels when i want to use the other car. no more toting around 3 transmitters. its very conveineint, but you will have to save up some more money. i am about to get a TC4, and all i need to get is another receiver, which is about $100USD cheaper than getting another radio system.
#30
well i figured insteed of puting the old radio in my closet i might as well use it, but yea when i buy other cars that are kits like the new tc4 or an pro4 etc i will deffinatly just buy a reciver!
