Brushless Motor Thread
#211
Guys, thanks for the replies. From the above, can i say that the drag braking 'feel' will be the same for all timings unless i changed the drag brake % using the u-soft?
#212
yup, you're right.
i don't use it.
i don't use it.
#213
OMg...another weird problem...
On my hacker 6, there is a little set screw where you can undo to take the motor apart.
When I was putting the motor back - apparently i screw that screw in too much it started to uplift the motor cap to the point where it came out of groove unevenly. So now I can't even open that cap because...well...don't know if you guys know what I'm talking about. You don't feel any resistence on that set screw when fastening...I can't open it now..
#214
#215
Originally posted by flyingfox
hi, i'm looking for U-Force 50 or 75 Esc please pm me or e-mail me at [email protected] thanks!
#217
Originally posted by Exe
yup, you're right.
i don't use it.
yup, you're right.
i don't use it.
#218
i got it from finedesignrc.com . buy lehner basic xl5000 you won't be dissapointed.
#220
SS5800 motor + U-Force?
Anyone tried SS5800 motor with U-Force75 ESC? I think it will work but does it faster than SS5800 motor with SS ESC?
#221
Re: SS5800 motor + U-Force?
#222
i did. one good thing, that esc does not cut off motor due to high esc temp. but there is a huge problem with cogging, you can drive , but cogging is really an issue on low speeds
#223
I won't work as the novak motors are sensored motors and U-force is only for sensorless
#224
kufman, danjoy25, don't confuse people with wrong info.
novak motor works with uforce, you just don't connect sensor wires and that's it. but it does cogg.
#225
use U-Force with LMT motors!! true electromagnetic motor!! novak motors are useless. invest in a good motor and esc for brushless. no point wasting money on a brushless motor and esc that gives problems now and then. just spend a little more and get the best out of it! =)
