Why F1?
Why F1?
Ive been thinking of going into track racing....with Touring cars I can easily understand why lots of people get into it and probably most popular onroad EP rc.
But with F1 rc racing, its rear wheel drive, i guess its quite difficult to drive compared with front or 4wd TC.
but I like the way it looks.
To F1 drivers,.....What made you go with F1?
Pros and Cons
Pros and Cons
Challenging to drive (less reliant on equipment, more on driver skill and setup), cheaper to run, and realism.
Pros and Cons
Pros and Cons
Pros and Cons
Pros and Cons
Touring cars are fun, but can have high initial start up costs. Being TCs are a pure racing class, like 12th scale, the expectation is that they should be pushed to the limit. If I were you, I'd get a used TC and try 17.5 no timing. They are more forgiving to drive than F1.
I have both and prefer F1.
Also a ton of less maintenance too. Ball diff on a F1 can last a bit between rebuilds. But with touring cars moving to spools and gear diffs, it isn't as bad as it used to be.
For me it was a lot of things. The scale looks are great. Driving a rear wheel chassis is more of a challenge especially on rubber tires. Tuning offers different challenges.
Most of all is the high level of FUN competition. The drivers in f1 are all about fun but still very competitive. There is also a respect between drivers that makes the racing much cleaner. In tc you have a full body so someone never thinks twice about bumping you a little. In f1 the open wheels won't let that fly. There is a lot more concentration on not touching the other car. Wheel to wheel contact usually results in both cars up against the wall. It is just a lot cleaner. Since it is cleaner racing that also translates into less broken arts. Usually when you do break something you know it was your own fault and you earned the repair bill.
well, hell. You guys have all sold me on getting into F1. Now I have to start shopng for a good one.
Bite Me Adam
Having driven about every onroad vehicle that there is the F1 is just a blast to drive they handle great when set up correctly and are a challenge to get around the track without taking your competitor out.... and the rubber tires make the greatest sound on carpet.
Bite Me Adam
Bite Me Adam
it is just good fun
Difficult to drive on rubbers/asphalt , but we run low power brushed motors , we are mostly older/experienced TC drivers and we have some serious giggle racing F1 at our local track
