Like Tree1Likes
Old 12-15-2013, 07:14 PM   #316
Thumbs up Newbie
Originally Posted by BobW View Post
It sounds like you have not selected all the components that assemble a car. On the main page the name of all the components that make up the currently selected car are displayed,Chassis TC4, Battery Lipo1S2P and so on. If there is no name shown then open the "Car Manager" select them from the drop down boxes and then click save.
If that isn't the problem then please provide some more details on which chassis you are working with. Or even better From the "Car Manager" export the file and email it to me so I can have a look.
Thanks Bob for the quick reply and instructions (via email). It was just my inexperience with the program. Thanks again.
Now, how do I keep this program a secret so the competition doesn't get it also?!
Silverexpress is offline   Reply With Quote
Old 12-16-2013, 04:49 AM   #317
BobW's Avatar
Glad I could help out.
Meant to mention in the emails that I was impressed at how quickly you got the hang of creating a model for the TLR22. It's not really that difficult.
Bob Wright
http://rccrewchief.wrightdesign.ca
BobW is offline   Reply With Quote
Old 12-16-2013, 04:01 PM   #318
Ok, Bob. I just gave your software a hefty bump. In return, is it possible to add more rows to the "Camber Link Positions" pop up menus? The limit seems to be 20. TLR's 22 series uses 0.5 mm washers as well has mounting holes for adjustments. As an example, the rear camber blocks have 8 holes for version 1.0, and 6 holes for version 2.0. For the buggy, the outer link is limited to 3 mm in height at increments of 0.5 mm before it starts rubbing against the inside of the rim. So that's 48 positions possible.
Old 12-16-2013, 04:51 PM   #319
BobW's Avatar
I'll up it to 100 for the next update. That should be enough to handle any situation
Bob Wright
Old 12-16-2013, 06:01 PM   #320
VBC Wildfire model is now available for download on the website.
Is it the new D06 chassis?
smknpipgras is offline   Reply With Quote
Old 12-16-2013, 06:44 PM   #321
BobW's Avatar
It's the D05. Wouldn't take much to modify it to D06 spec if you have calipers.
Bob Wright
Old 12-16-2013, 08:28 PM   #322
What kind of measurement tools would you all recommend? Currently, I'm using steel T-squares, rules, 11# postal scale, hobby clamps, and a divider.
Old 12-16-2013, 08:28 PM   #323
Thank you.
Old 12-17-2013, 04:44 AM   #324
BobW's Avatar
I do 99% of the measurements using a 8 inch digital vernier calipers.
http://www.amazon.com/s/ref=nb_sb_no...ernier+caliper
Weighing I use 4 digital pocket scales
http://www.amazon.com/American-Weigh...s=pocket+scale
I then have a setup station for setting toe and camber, a tweak bar, balance pins for weighting the car and a setup board to work off of.
Lastly if you want to determine CG height you need is a means to raise the rear of the car a known height.
Bob Wright
Old 12-19-2013, 12:57 PM   #325
azeroth's Avatar
Trader Rating: 20 (100%+)
ok i havent set up my 1/8 scale into it yet but it has inserts in the rear hub to change the arm angle (roll center) with a giving size tire has this feature been added or can it or do i need to setup three different chassis to see the effects?
Nitro is for Racing!!!!!!!!!!!!!!!!!!!!!!!!!
YA SMELL WATTs I BE STEPPIN IN????
Yes I race a Snake, VP, Radiopost,Protek,EDS,Matrix
Team Nitro RC Club Lynwood, IL
azeroth is offline   Reply With Quote
Old 12-19-2013, 06:18 PM   #326
BobW's Avatar
I still haven't gotten up enough nerve to modify everyone's database remotely. So you have two choices.
1. Create three models each with a different location for the hinge pin on hub as you suggested.
2. Transpose the outer hub positions to the inner hinge pin. Will take a little manipulation using a CAD layout but wouldn't be hard to do. Done correctly it will still yield the correct static Roll Centre positions. I could work it out if you send me the model.
Bob Wright
Old 12-20-2013, 05:07 AM   #327
Trader Rating: 32 (100%+)
Hi...
just checking if there is any plan to add in ae tc6.2 as model in your software?? If yes... when??
hobbs is offline   Reply With Quote
Old 12-20-2013, 05:08 AM   #328
Hi...
Old 12-20-2013, 08:10 AM   #329
BobW's Avatar
Always looking to add more models to the library. As soon as I can get my hands on a TC6.2 I will add it. Just can't say when.
You can also create models yourself within the software.
Bob Wright
Old 12-20-2013, 08:10 AM   #330
BobW's Avatar
Bob Wright
Carpet On-Road in NYC-New Rochelle, NY Donny Lia Northeast Racing Forum 3143 Yesterday 09:24 AM
Roll Centre. Hinge pin Vs upper arm adjustments YZFAndy Electric On-Road 18 01-25-2012 12:30 PM
