Old 03-28-2013, 10:57 AM   #226
jhautz's Avatar
Trader Rating: 84 (100%+)
Does this software have the xray T4 in it?
Looks like something I'd like to try out.
jhautz is offline   Reply With Quote
Old 03-28-2013, 12:35 PM   #227
Moderator
mxwrench's Avatar
Hey Bob, I have some HP and TQ data from my dyno testing if that will help you out. I have actual HP and TQ dyno graphs from years and years of testing. I might be interested in checking out the beta version.
Is the Nitro stuff gonna be an update or an add on?
BK
Brian Kinney
TLR Design Engineer
2016 Sponsors: Team Losi Racing, AKA Tires, Orion, Nitrotane, Horizon Hobbies, Fast RC Paint.
mxwrench is offline   Reply With Quote
Old 03-28-2013, 02:00 PM   #228
BobW's Avatar
No T4 yet. T3 2012 is there. Likely not a lot of difference between the T3 and T4 so shouldn't take much to adjust the model to suit the new car.
Bob Wright
http://rccrewchief.wrightdesign.ca
BobW is offline   Reply With Quote
Old 03-28-2013, 02:04 PM   #229
BobW's Avatar
BK
More dyno data would be great.
The new version is an update. Once I get the Beta testing done it will be available to everyone as an automatic update.
I'll take you up on the offer to Beta test. Hope to have it ready this weekend.
Bob Wright
Old 03-31-2013, 06:48 AM   #230
BobW's Avatar
The new update is out for Beta testing. I could still use one or two more users if anyone is interested. Nitro motor experience would be good.
Bob Wright
Old 03-31-2013, 07:36 AM   #231
narcotiks's Avatar
A value enter box for the camber link shims would work really effectively, it takes a while when changing and comparing setups because you have to zoom in, change length (counting lines etc) zoom out, zoom in again etc...
It would be much easier just typing in 3mm 4mm in boxes, in addition to the manual change as options.
narcotiks is offline   Reply With Quote
Old 04-11-2013, 04:18 AM   #232
Default Capricorn Lab C02
Dear all, I almost have all the measurements inputted for the Lab C02.
Some questions
To weight the drive train do I need to include i.e. diffs, shafts, axles, pulleys, belts and bearings.
Re center of gravity calculations some questions
1. When you incline the car do you ideally use a certain height?
2. For the wheels can I use aluminum setup wheels or do I need to use the foam tires in order to keep weight as close as possible?
3. Suspension springs will the measurement take different reading in using different springs?
4. Default length of nitro touring cars is 254 or 255 as I measured mine and it's 255
ARB measurement
How do you calculate the rear arb of nitro touring?
that's if for now
speed6 is offline   Reply With Quote
Old 04-11-2013, 05:19 AM   #233
BobW's Avatar
To calculate the Mass Moment of Inertia (MMI) for the rotating components is a somewhat tedious task to do properly. In the end the power required to spin up the rotating components is generally around 20% of that required to accelerate the mass of the car itself. If you want complete this then for every component in the drive train (axles, diffs, gears, wheels....) that spins you need the Mass (weight) and outside diameter of the part. The equation for the MMI of the part is C x Mass x (OD/2)^2 where C is a constant that is a function of the geometry. If you want to go complete these calculations then send me a email and I can provide more details.
Re CG calcs
1) you can use whatever height you wish but the higher the better. Min is 4" high.
2) Yes you can use aluminum setup wheels. Once you have calculated the CG height with the setup wheels on you will need to correct for the tire diameter you race with. The correction would be to subtract (setup wheel diameter - Race tire diameter)/2 from the calculated value.
3) The CG height measurement is very sensitive. If you go back a couple pages there was quite a discussion on this subject.
4) same as 3)
Re ARB
The best model to use is the "Wire Type" just straighten out the wire and use the total length outboard of the mounts.
If you are using the Front Blade ARB use the ARB calculator that is accessible from the Calculator tab on the main page not the one in the Chassis Manager. There is an error in that routine that will be fixed in the next update out shortly.
Bob Wright
Old 04-11-2013, 05:36 AM   #234
Warren Weaver's Avatar
Trader Rating: 46 (100%+)
I would love to beta test my email is warrenwvr@yahoo.com
thank you
warren
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-MCFACTORY MOTORSPORTS-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 04-11-2013, 06:26 AM   #235
BobW's Avatar
thank you
warren
Beta testing is almost complete. I am hoping to release the update this weekend if alls goes as planned so may be a little late now but thanks anyways. Also I don't see you in my users database. Are you a registered user?
Bob Wright
Old 04-14-2013, 01:44 PM   #236
Re CG calcs
4) same as 3)
Re ARB
Re REAR ARB Measurement:
I have attached an image to make sure re the measurement that I need to take
L1 is marked in green kindly confirm
L2 I marked with an A and a B version, logically since its torsion force that B is supposed to be the right choice. Kindly confirm
Old 04-14-2013, 05:17 PM   #237
BobW's Avatar
Actually 'A' is the right choice. Most of the stiffness in wire type ARB's is due to bending of the arms not torsion between the mounts. We always think of ARB's as torsion only which in full scale cars is the way they are designed. In our cars with this style of bar bending is the primary component. I have verified this with testing.
You can visually see it by restraining one wheel and lifting the other. Note the bending of the arms.
Bob Wright
Old 04-14-2013, 05:27 PM   #238
BobW's Avatar
An new update will be released tomorrow so this is just a heads up to make sure you backup your database. There should be no issues with the update just to be safe.
New version features:
•Acceleration simulation of Nitro Cars with multi-speed transmissions is now supported.
•Plan to have an extensive library of Nitro Motor models to choose from on the website.
•Improvements to processing Electric Motor Dyno results into Math Models
•Several bug Fixes.
So stay tuned. When you open the program you will be notified of the update. It will install automatically if you approve.
As always if anyone would like to contribute models to build the online library, RC3 would be happy to receive them.
Bob Wright
Old 04-14-2013, 05:41 PM   #239
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Looking forward to the update...
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-17-2013, 12:09 PM   #240
BobW's Avatar
Program update that includes Nitro Motor Simulation was released on Monday. Uploaded a quick screencast video to Youtube to demo how to use it.
http://www.youtube.com/watch?v=Eczz4hxJBb8
Bob Wright
Carpet On-Road in NYC-New Rochelle, NY Donny Lia Northeast Racing Forum 3085 Yesterday 03:41 PM
Roll Centre. Hinge pin Vs upper arm adjustments YZFAndy Electric On-Road 18 01-25-2012 12:30 PM
