Like Tree1Likes
Old 02-28-2013, 06:38 PM   #196
YFZBOB's Avatar
Thanks for posting the charts and marking them. Makes it easier to read.
YFZBOB is offline   Reply With Quote
Old 03-04-2013, 06:37 PM   #197
BobW's Avatar
Just uploaded 3 new models. Two from users, TOP Photon EX and a blast from the past the Xray T1 EVO2. Keep those models coming.
The AE RC8T econv truggy is back together and there as well.
Bob Wright
http://rccrewchief.wrightdesign.ca
BobW is offline   Reply With Quote
Old 03-08-2013, 06:33 AM   #198
BobW's Avatar
Bob, enjoyed the video and still trying to understand using RC crew chief for setup ideas. Can you elaborate a little more about reading your tires for buildup and relating it to your camber settings. You can use private messaging (or even better your crew chief thread) if you would rather not muck up this thread.
Greg
If you see a build up of rubber on the outside edge of your tires what is to blame is either too much static camber or too much camber gain IMO.
This is my explaination:
As the chassis rolls the camber angle on the outside tire decreases due to the chassis roll angle. Similarly the camber angle on the inside tire increases such that there can be a gap (or very low contact pressure) at the outside edge of the tire. The gap is also strongly dependent on the tire sidewall stiffness, air gap and hardness of insert all three of which affect how much the tire carcass deforms under lateral load.
So if we assume on the inside tire there is a gap at the outside edge then rubber that is stripped off will move from the inside to the outside of the tire due to the slip angle of the tire. Once the rubber reaches the gap it will start to build up.
If the next turn is in the opposite direction then our inside tire with the buld up now becomes the outside tire. If our camber settings are correct and the tire makes contact over it's full width any build up will be removed and all is good. If not then turn by turn the buildup will continue to increase.
So build up on the outside edge of your tires is an indication the tire is not making full contact with the racing surface and consequently not achieveing maximum grip. That's my theory.
Bob Wright
Old 03-08-2013, 09:00 AM   #199
SS LS1's Avatar
Trader Rating: 23 (100%+)
Bob, thank you for taking the time to write that clear and descriptive explanation of using outside rubber buildup on your tires as a gauge for reading the effectiveness of your camber settings.
I understand and agree with your theory after reading that post. When I watched the video I thought you were only talking about the outside wheel and how it contacts the track. Thus I did not understand how a tire with too much camber would develop a buildup of rubber on the outside edge when it is not even touching the track during cornering.
Now that I realize you were taking about when a particular tire is on both the outside and inside of a corner how each can affect the amount of rubber buildup on that same tire.
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 03-08-2013, 02:22 PM   #200
Correct me if I'm wrong, build up of rubber on the outside of the tire means that thru the corner the whole tire isn't touching the surface and that would mean decrease camber and the front tires will have full contact with the surface thus more front traction and steering?
I've only witnessed a build up on the outside of the front tires, so I am assuming you are talking about the front
JOE SI is offline   Reply With Quote
Old 03-08-2013, 07:42 PM   #201
BobW's Avatar
Build up can occur on the front or rear tires. To fix it reduce static camber, and or camber gain or soften the suspension so the chassis rolls more.
Bob Wright
Old 03-09-2013, 10:14 AM   #202
Lessen's Avatar
Send a message via MSN to Lessen
I completely agree. Although I'm still fairly new to racing, this seems common sense to me. What I've found shocking is this simple visual analysis seems to be overlooked by many with plenty more experience than I. That's just an observation I've made as I questioned local talent for tips over my first couple years. All I can say is that every single time I've had buildup issues and reduced camber, the car became easier to drive and more responsive to further tuning... because the tire is simply working more effectively.
"Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. "
Lessen is offline   Reply With Quote
Old 03-09-2013, 11:32 AM   #203
TT_Vert's Avatar
Trader Rating: 68 (100%+)
Any chance of a 25.5 novak motor model? Only info I can find is the following:
Watts: 82
Maximum RPM: 50,000
kV: 1550 RPM/volt (unloaded)
TT_Vert is offline   Reply With Quote
Old 03-09-2013, 05:11 PM   #204
BobW's Avatar
Watts: 82
Maximum RPM: 50,000
Sure will. I'm away this weekend but will upload a model beginning of the week.
Bob Wright
Old 03-09-2013, 05:16 PM   #205
TT_Vert's Avatar
Much appreciated. Are you generating this data or so you have a source for it?
Dave
Old 03-10-2013, 05:57 PM   #206
BobW's Avatar
The electric motor model uses DC Permanent Magnet equations. Knowing the Kv, max power and voltage you can come up with a fairly accurate model.
I plan to build a flywheel dyno in the near future which will allow better models to be developed and motors to be compared head to head.
Bob Wright
Old 03-11-2013, 12:29 PM   #207
TT_Vert's Avatar
Hey Bob, any chance a droop setting could be added to the handling tab to see the direct correlation of droop limitation to wheel loads? I understand that droop only affects wheel loads during chassis movement so perhaps an option to show the wheel loads at the currently selected g load in handling would work?
Old 03-11-2013, 02:03 PM   #208
TT_Vert's Avatar
Anyone else having issues w/ CG calculations? I originally calculated CG at 2" and I was at 20mm but after reading the documents it mentions testing is most accurate at 4-5" I'm around 47mm this way. I've ensured that there is nothing contacting my scales aside from the tires. Looking at the stock tc5 file it shows 30mm as the CG so I find it hard to believe 47mm is accurate. Any opinions? I'm also measuring w/ the body on.
Dave
Old 03-11-2013, 02:49 PM   #209
BobW's Avatar
It is difficult to add droop the static wheel load calculations as the point where the droop limit is reached is a function of suspension geometry, g load and roll angle. What's I need to do is link between the dynamic and handling page. Something else for the wish list.
Bob Wright
Old 03-11-2013, 03:44 PM   #210
BobW's Avatar
Dave
47mm is definitely way off. All the TC's I have measured have been between 29 and 31mm body on. Some things to check.
1. Wheel weights were entered for the car oriented as shown on the graphic.
2. When you raise the rear make sure you account for the thickness of the scales. I always place scales under the rear as well so I don't need to account for this.
3. RL is tire radius not diameter. I always use 31mm for 63mm tires. The .5mm accounts for some deflection of the tire.
Bob Wright
Carpet On-Road in NYC-New Rochelle, NY Donny Lia Northeast Racing Forum 3312 Today 05:30 AM
Roll Centre. Hinge pin Vs upper arm adjustments YZFAndy Electric On-Road 18 01-25-2012 12:30 PM
