Like Tree236Likes
Old 07-31-2012, 09:49 AM   #1456
Originally Posted by JKyte5 View Post
I need help fellas. Im running vta at my local track and am getting smoked coming out of the corners and in the straight. Im running a 25.5 Ballistic and a GTB esc. My pinion is a 49 and my spur is an 80. These guys are killin me speed wise. Im not a great driver but at tha same time i dont run into tha walls or crash people all tha time either, just descent i guess. Any ideas on why my car is so down on speed????? Any suggestions????? Running a good 2s lipo recalibrated my esc to default and all my settings on my controller are at full blast and still no speed........Please help with a checklist of things yall think it might be......thanks
The guys have all given you good suggestions for places to look at to find if something may be mechanically wrong with your car.
I would add a few more as well as a few observations.
Some of the fastest TC3/4's that I have seen do not run anywhere near the FDR of a belt drive car, on average size tracks, due to the added rolling weight of the drive line. (something to consider when gearing your TC3)
There can be up to 1000 rpm difference between motors when at full timing if not more, at the sacrifice of efficiency and then more heat.
I would consider putting your GTB2 in the VTA car as well to make sure that there is nothing wrong with your current esc.
Your tires, older tires that have a considerable amount of runs on them and lots of sauce will have a larger diameter versus new. The older tires will have more top speed,and potential corner speed versus a new set because of the roll out and side wall flex.
Is your car weight biased to the front or rear? Front bias has a tendency to understeer/push, while rear biased can become rear loose as the weight swing through the apex.
Is your car's wheel base full long, long front, short rear, long rear? These can and will effect forward bite,steering,side bite, etc.
The angle of your links in realtionship to the cvd's will and can also effect all of the above as well.
Lots of food for thought, didn't directly answer your questions but another direction to look.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 07-31-2012, 11:13 AM   #1457
snoopyrc's Avatar
Originally Posted by beemerfan View Post
76 tooth spur / 52 tooth pinion gets you a 3.65 FDR. The only modification you possibly have to make (not sure its been so long) is to take down the chassis webbing directly beneath the pinion if it rubs or binds.
Would he need to run any timing with that?
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 07-31-2012, 11:22 AM   #1458
beemerfan's Avatar
Trader Rating: 34 (100%+)
It's going to depend on the track and conditions. I was just throwing that out there because of the statement that it is "difficult" to get a TC3 lower than a 4.0:1 FDR. I run that gear ratio with 45 degrees of timing at some tracks, but it depends on the layout and how hot it is outside. Should have pointed out that I was speaking in terms of 64 pitch gears as well.
beemerfan is offline   Reply With Quote
Old 07-31-2012, 11:53 AM   #1459
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
I'm seeing that ratio run at full timing on carpet here.
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 07-31-2012, 06:06 PM   #1460
snoopyrc's Avatar
I am running a Yokomo SD which is essentially their upgrade for TC3 users back in the day. Its a very similar car. I am aiming for indoor carpet (Southern Nats at Thunder RC) with AC running so it should be nice and cool in there. Thanks for the multiple views on this. I havent really raced since One lug earlier this spring so I will be super rusty. As always.
Old 08-01-2012, 11:13 AM   #1461
JustWill75's Avatar
Send a message via AIM to JustWill75
I can't wait to hear about the blue esc that is being tested. I have been told BLUE IS BETTER. I hope its not to much better that it won't make it through.
TEAM ASSOCIATED // REEDY POWER // BLAST RC
JustWill75 is offline   Reply With Quote
Old 08-01-2012, 06:12 PM   #1462
Decathalon's Avatar
Default VTA at SMA in Australia...
Thought I'd share few VTA pics from our club SMA (Sydney Model Autosports) in Australia http://www.smaracing.org . We run the same rules as USVTA except with 21.5 motors instead of 25.5 and allow a few extra bodies such as the '78 Firebird and Australian muscle cars. Racing is outdoors under lights every tuesday night, with a few sunday meetings too. We ran VTA oval last weekend for a laugh, man it rocked!!
VTA @ SMA by Leigh Nelson, on Flickr. Leigh Nelson Copyright 2012 All rights reserved
CRC GenX10 LE Pro 10 & SE WGT, Kyosho Plazma F1, Atomic VMII,Tamiya M05, 1/12th Scale (CRC Xti, Xi & T-Force, AE L4, Yokomo YRX12, Hara AH12) www.smaracing.org - Star Kebab Akihabara :)
Decathalon is offline   Reply With Quote
Old 08-01-2012, 11:09 PM   #1463
JustWill75's Avatar
That was awwwtummm
Old 08-02-2012, 03:00 AM   #1464
trytowin's Avatar
Very cool pics !!
I'm just here to discharge my battery.
trytowin is offline   Reply With Quote
Old 08-05-2012, 04:06 PM   #1465
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Wasssssup you slackers hope some of you had as much fun as I did
This weekend
I was carpet racing @ FIRCC
All day Saturday practice
And all day Sunday racing all I can say is WOW
Carpet VTA is great gitting ready for the southern nationals
Can't wait
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 08-06-2012, 06:12 AM   #1466
JustWill75's Avatar
Any word on the new ESC testing? I really want to know how the blue one did.
Old 08-06-2012, 07:36 AM   #1467
DARKSIDE's Avatar
it went really well...waiting on more info from LRP and since Dirla is back...Im going to do another test with his equipment...
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
Final On-Road Race
Summit RC Raceway June 17th
Ft. Wayne IN
DARKSIDE is offline   Reply With Quote
Old 08-06-2012, 01:53 PM   #1468
wwddww34's Avatar
Trader Rating: 9 (91%+)
Duplicate post.
wwddww34 is offline   Reply With Quote
Old 08-06-2012, 01:53 PM   #1469
wwddww34's Avatar
Hey DARKSIDE, do you have one of these 1/10 scale R/C cars in your collection?
Old 08-06-2012, 05:26 PM   #1470
DARKSIDE's Avatar
I do have this one thats gets up to 25+ mph...lights and sounds as well...it HUGE!!!
Also I have 3 smaller ones, that have the old school push button that turns in reverse
Final On-Road Race
Ft. Wayne IN
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 5996 06-21-2017 06:50 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
