View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
Pro Invintational VTA
a. must have TQ'd or finished in the top 10 of one of the following events running U.S.VTA rules: Scale Nats(Chicago) Southern Nats(Nashville) Summit Nats(Ft Wayne) Halloween Classic or Summer Slam(Cleveland) Snowbirds Nats(Orlando) U.S.VTA Pavement Nats (FL) or the U.S.VTA National Points Series...other events will be considered
b. sponsored racers are encouraged to run this class over regular VTA, but sponsored or unsponsored is welcomed
c.handout Novak VTA Boss 25.5, built by Charlie and/or Bob Novak. Built to be as equal as possible. One motor per racer
d. battery will be tech for capacity with the ICharger. NEW Rule is 6000 mah. Must use the same battery, limit 2.
e. simple points system 1-10, lowest amount of points wins. tie breakers will be times and laps
f. limited to 10 racers
g. random sort and starts using all 3 types: rolling, lemans, inverted
h. 6 rounds at 10 min each
- Its really not inverted because there is no qualifying order.
- One of the things with a Reedy format is that all of the racers get a chance to start near the front approximately the same amount of times and have to start from the rear approximately the same amount of times - inverting the sort order for X number of races will unfairly penalize some of the racers and unfairly reward others.
I would like to politely suggest that rather than inverted maybe use rolling, lemans, single file, and side by side as starting formats?
Its the invite class rules at the Southern Nats this year
First time out on the new protoform tires was horrible. Like driving on ice. Was told about using liquid wrench and that would soften them up. Soaked them for a couple of days before next race. It was like night and day. Had great results second time out with them no saucing whatsoever the whole day. This was on asphalt. New pf mustang was great too.
Local VTA racing in Flagstaff, Arizona.
Age and treachery (Gary McAllister) versus youth and exuberance (Vin Baldacchino). Age and treachery won, but Vin is the up and coming star!!
Looking good Gary
Thanks Brian..... I assume you are talking about the car..... LOL
2 things
1. Would like to see protoform put out 67 or 68 camaro, and like off road some yellow wheels but the nascar style.
How do the new PF VTA tires work on unprepared tarmac?
Thanks.
Cheers,
Jim
Thanks.
Cheers,
Jim
