Like Tree436Likes
Old 08-09-2017, 05:12 PM   #10696
scirocco14's Avatar
Originally Posted by teklein View Post
Very cool. Car definitely won't be ready by then, but I'll try to swing by.
I have a loaner VTA car/radio/transponder if you want to race. No charge for the loaner, you only pay for any broken parts. This way you can find out what VTA racing is like with a proven, fast car.
Hope to see you Saturday.
Mark
Trick81 likes this.
Mark C. USVTA #115 TC4 & Xray T4 '13, USGT #115 Xray T4 '13
USVTA-F1 #115 F103/4 & F1R3 & WTF1 FC-16. Tamiya M05 M06
Bush River RC, The RUG at King, Ho B Max Raceway, Easley RC
scirocco14 is offline   Reply With Quote
Old 08-11-2017, 02:47 PM   #10697
teklein's Avatar
Mark
Hey Mark,
That's a very generous offer and under normal circumstances I'd jump on it in a heartbeat (even though I'm scared to death I'd wreck the car or other people since I haven't raced in 16yrs!). Unfortunately I just can't make it work tomorrow The next race should be no issue though if you let me know when it is! We have a 3wk old baby and my grandma in law is being moved to rehab tomorrow so LOTS going on around here.
Is it ok if I PM you for some other questions I have about racing at Easley?
Thanks!
scirocco14 likes this.
teklein is offline   Reply With Quote
Old 08-11-2017, 03:12 PM   #10698
What is the best 25.5 motor out their? I'm running a TC4 and thinking about a Reedy once their back in stock.
Dodge426 is offline   Reply With Quote
Old 08-11-2017, 03:24 PM   #10699
DARKSIDE's Avatar
any of them...I like the Reedy Powered 25.5...but its all about the brand you like...just make sure they are on the list
Spec 25.5 Motors
ASM likes this.
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 08-11-2017, 04:12 PM   #10700
theproffesor's Avatar
Trader Rating: 57 (100%+)
Any idea besides "mid August" as to when the VTA tires are going to come off back order at tower. About to cancel and order straight from proline.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 08-11-2017, 04:33 PM   #10701
lilws6's Avatar
Order the protoform tires got mine.e direct from them
Trick81 likes this.
lilws6 is offline   Reply With Quote
Old 08-11-2017, 05:27 PM   #10702
BadSign's Avatar
Trader Rating: 15 (100%+)
Ordered mine from protoform saturday, arrived today.
This is the day the Lord has made, I will rejoice and be glad in it- Psalms 118:24
World Champion Turn Marshall
BadSign is offline   Reply With Quote
Old 08-13-2017, 09:02 PM   #10703
Lone Drifter's Avatar
Maybe people who are buying multiple sets (more then 2) could let other people get at least one set. ( who only have thin slick balloons) until production can meet demand
USVTA , USGT and Wheeler Fan
TC7, TC6, T3 11 & 12, and TLR 22-4
Looking Forward to New Racing Options
Lone Drifter is offline   Reply With Quote
Old 08-14-2017, 12:34 PM   #10704
IndyRC_Racer's Avatar
I got to see a set of the new Protoform VTA tires. There are several things I noticed.
Tread appeared shorter
Gap between treads appeared a bit larger
Sidewalls appeared a bit smaller
Can anyone else comment on the differences they have noticed. I still have a set of unopened HPI VTA tires, but I didn't have them with me at the track to do a direct comparison.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 08-14-2017, 01:14 PM   #10705
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Side walls are definitely stiffer
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 08-14-2017, 02:20 PM   #10706
Has anyone tried the new tires on pavement yet?
And if you had do they hold up better?
Old 08-17-2017, 02:20 PM   #10707
I'm in the process of gluing up a set of new HPI VTA tires on new HPI VTA wheels (white 8-spoke). It has been a while since I've glued up tires, so I don't think there is as much of a difference between the sidewall diameter as compared to the new Protoform tire. However there is definitely a difference between the tread pattern.
Here is a picture of the HPI 31mm VTA tire that I just glued today (8/17//2017)
Below is a picture of the Protoform 31mm VTA tire from Protoform's website.
As you can see when comparing the 2 tires that the gaps between the treads do appear to be different.
HPI VTA tire - gap is smaller
Protoform VTA tire - gap is wider
There may be a simple reason for the difference, such as the HPI molds being more worn out. Or it may be possible that the Protoform VTA tire needed to have a slightly different tread pattern to avoid any copyright infringement.
I'm only posting this as something I've noticed (that others may have noticed as well). Whether the actual tread pattern has any affect on performance will probably be irrelevant. Based on my own experience, I've always had to slightly adjust my setup/traction compound routine depending on how new or old the VTA tires I've been using. I've raced VTA on many different surfaces and have been beat by good drivers running new tires, old tires, ballooned tires, and almost balding tires.
In the end the driver with the best setup/driving has almost always won the main. The majority of the A-main driver's fast laps where always within a tenth. And lastly the cars have always seemed fairly equal going down the long straights.
Old 08-17-2017, 02:40 PM   #10708
DARKSIDE's Avatar
PROTOform shared US Vintage Trans Am Racing's post.
5 hrs
Some helpful tips from #USVTA.
5 hrs
Just to help out those who are trying the new Protoform VTA tires on tarmac, here's a couple suggestions:
*For traction compound on asphalt, testing has shown Mighty Gripper V2 works very well in most situations. Another alternative has been Liquid Wrench or PB Blaster type penetrating oils. Most of the thicker, oily compounds like a Tire Tweak or SXT 2.0 are not helpful. Stick with the thinner products.
*If you are running a minimal amount of toe in, like 1* or 1.5*, you may need to increase this a bit. Remember, different rubber, different set up!
https://www.facebook.com/PROTOformRa...Ty3Ex4tGB6pHo4
Old 08-17-2017, 02:52 PM   #10709
DARKSIDE's Avatar
Below is a picture of the Protoform HPI 31mm VTA tire from Protoform's website.
I have both new sets at home...didnt notice, but Ill check when I get there and post back
Old 08-18-2017, 08:53 AM   #10710
RussF's Avatar
Trader Rating: 21 (100%+)
It would appear to me that the Protoform is using a better mold for their tires, Much higher definition.
Boomer likes this.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 6015 10-19-2017 01:56 PM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
