Old 06-02-2012, 01:17 PM   #901
wwddww34's Avatar
Trader Rating: 9 (91%+)
Have you heard about this project for making "Steelie-style" rims?
http://www.kickstarter.com/projects/...scale-steelies
wwddww34 is offline   Reply With Quote
Old 06-02-2012, 02:54 PM   #902
I saw that and think its a really cool idea. That would be great for those wanting a real scale appearence. It looks to me like he is going to have a tough time hitting his goal.
CajunJoe is offline   Reply With Quote
Old 06-02-2012, 04:50 PM   #903
Originally Posted by robk View Post
Nash, if you see fit to change the rules at your track, that's fine. I can't make esc manufacturers follow the rules that have been set out.
Have you ever tested any of the ESCs available through HobbyKing? They have several inexpensive ones. I've got one that came from another company ("ECSpeed") that apparently doesn't exist anymore, but it looks exactly like their 100A "X-car" model #HK-SENS-100A (gee, I wonder how they come up with their part numbers?). It's not PC programmable/updatable and appears to be a Chinese shameless copy of a GTB (the heatsink and CASE will fit a GTB). The only possible issue is that it has a "motor timing" setting, but I've tested it with a radar gun at all possible timing values and it made no difference. I suspect the motor timing function only applies to sensorless motors.
Kevin Marcy is offline   Reply With Quote
Old 06-02-2012, 10:10 PM   #904
nashrcracer's Avatar
R/C Tech Charter Subscriber
oh I'm not saying that the rules are wrong but I get tired of all the hype that there is all kinds of choice in the rules. from bodies to speed controls. it's great that Novak has pretty much cornered the market on the class in the speed control area and yes having one motor Novak 25.5 makes it great that you don't ever have to worry about the motor of the week club. Which for a cost control class is awesome. You have spec tires, only one kind, but it is good that you can get white grey black or chrome rims in a couple styles. Body wise yes you have 20 different bodies but only 3 basic models mustang cuda camaro. But I have had a heat at my track that was 5 white with blue strip Mustangs.. yes 5 in one heat. The class is fun and a good comfortable place for beginners compared to TC which is faster then 27t brushed days of old. But to say it's a high competition class that has loads of choices which compares with full TC ad-nausea just makes me pound my head against the wall.
it's a great SPEC=limited class that can be entered for a small outlay of cash in either used equipment or less expensive cars. That is loads of fun and not too serious so winning doesn't mean as much as having a smile on your face after then run.to make it over complicated or take it too serious makes it not what the spirit of the class is as far as I am concerned.
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 06-03-2012, 12:15 AM   #905
robk's Avatar
Trader Rating: 22 (100%+)
I don't test any of the oddball stuff, unless someone has one we can use, and they want to submit it. I would be out a lot of $$$ if I bought one of every Chinese esc out there
Generally, though, if it says it has a timing mode, I don't even bother. It's not worth the headaches I would develop when the first guy posts that he got beat by brand X, and why did we allow that when we knew it had a timing mode?....LOL
Seriously, i have had inquires about many products, but a lot get eliminated when I look the manual up on the intarwebs, and i see "timing mode" in the literature.
Old 06-03-2012, 12:19 AM   #906
robk's Avatar
I don't pretend this is a run what you brung deal in any way. You have a lot of choice in how the car LOOKS. You're right, there's only a few basic models, but the Pegasus 70 Camaro is pretty far from the HPI 68, or the Pegasus Boss and the HPI fastbacks.
As far as hype? Maybe you have been hanging around with Darkside too much..he is the hype man for VTA
Old 06-03-2012, 08:28 AM   #907
DARKSIDE's Avatar
wow...hey Im not even in this...you and Nash need to pm each other, and leave the Batt out of it...lol
and while we talking hype...did you know that the
*****2012 US VTA+ Southern Nationals in Music City, USA is coming Sept 21-23rd at Thunder RC Raceway in Nashville, TN*****
incase you didnt , know you know...BTW, 96 entries last year, looking for 120 this year...lets get it US VTA Racers!!!!!
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
THUNDER JAM IX Snowbirds Warm-up
January 21, 2017 Thunder RC Raceway
http://events.rcsignup.com/events/displayEvent.cfm?id=5313
DARKSIDE is offline   Reply With Quote
Old 06-03-2012, 08:25 PM   #908
beemerfan's Avatar
Trader Rating: 34 (100%+)
Default More C rating nonsense
Not trying to drum up a new debate here, just adding to the general knowlege base. Since the C rating thing has come up so many times in the past, I bought one of these gizmos from HobbyPartz that measures wattage and current draw. I believe it is fairly accurate and I wanted to measure the actual peak draws of a VTA car. We've figured in the past that the average is about 10 - 12 amps but the peak draw is where the C rating comes in to play. So the results...
About 20 amps!
I started by doing several burnouts to simulate a race start or when you get going after a mishap. The meter actually maxed out at 29.9 amps for that.
Then I did 3 runs with smooth rolling starts to avoid a big draw and ran about 5 to 10 laps per run.
Run 1: 19.5 amps
Run 2: 20.4 amps
Run 3. 19.6 amps
This was on a big track using a Novak GTB speed control, a Ballistic 25.5 motor set to 45 degrees of timing and geared at 3.32 FDR.
This means you need a 6C 5000 mAh battery to cover those peak draws of hard acceleration and a little more than 4C everywhere else. Combine this with Darkside's recent test of his Reedy 25C Wolfpack outperforming a much higher rated pack, and it's a pretty strong argument that C ratings don't matter in VTA. 20 to 25 C packs are more than good enough for this class.
beemerfan is offline   Reply With Quote
Old 06-04-2012, 07:46 PM   #909
Ray Murray's Avatar
Hey all....Had a great USVTA turnout for a memorial race we had here this past weekend! Except for one "non period paint scheme", EVERYONE was up to FULL USVTA specs down to the numbers and driver figures!
Big Thanks to substitute USVTA director "spurcheck" for following up, and making sure everyone was race ready!
Here are a few pics....
Dee Lee is a nut and I don't condone what he will say next! (LOL)
WWSD....What Would Scooby Doo???
Ray Murray is offline   Reply With Quote
Old 06-04-2012, 08:24 PM   #910
DARKSIDE's Avatar
wow!!!...nice turn-out...keep it up
Old 06-04-2012, 09:58 PM   #911
trytowin's Avatar
Where is your track located ?
I'm just here to discharge my battery.
trytowin is offline   Reply With Quote
Old 06-04-2012, 10:10 PM   #912
Ray Murray's Avatar
Thanks man, much more to come....
We're in South Jersey not far from Atlantic City....
Old 06-05-2012, 02:59 PM   #913
fpart's Avatar
Trader Rating: 38 (100%+)
Send a message via Skype™ to fpart
I wanna know what Scooby is doing with that car. Is he teching it since Kaybo is not there?
teamYokomo.com teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 06-05-2012, 04:10 PM   #914
Rozzt_iwa's Avatar
Send a message via MSN to Rozzt_iwa
any one know were to get VTA tyres cheap that also dose 3racing sakura zero parts ?
B5M (17.5),cactus (17.5),sc10 short corse truck (10.5), sakura s zero VTA(21.5),mini-z
www.nbhc.com.au
supporting local hobby shops
http://www.iwawrestling.com.au
Rozzt_iwa is offline   Reply With Quote
Old 06-05-2012, 04:10 PM   #915
scooterman19's Avatar
AHHHHHH HAHAHAHA! to fpart....just keep stirrin that pot...lol
HPI RS4 and F10
A bad day of RACIN is better than a good day at work!!!!
S J C C R WAGNER BABY!!!!!!!
scooterman19 is offline   Reply With Quote
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5864 01-07-2017 11:00 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
SEO by vBSEO 3.5.0
