Like Tree253Likes
Old 01-18-2015, 04:19 PM   #8431
IndyHobbies.com's Avatar
We switched from off-road on on-road. I loved the fact that the cars gripped so well and the speeds seemed higher. Even though I loved jumping trucks and buggies, if you land the least bit squirrely, you flip and get passed. We still run off-road from time to time, but on-road is what I prefer. VTA is what did it. Racing 70's muscle cars with Cragar style wheels? What could be better than that!
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 01-19-2015, 06:20 AM   #8432
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
first "VTA" style running i Grand Forks area will happen tommorrow. More of a test and track setup day as they are trying to get running going again in the location they used to use a few years ago, but other than a few rule changes for the area (no innner body, any 25.5 motor) they are looking to use USVTA rules.
Hope to make it up there.
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 01-19-2015, 01:30 PM   #8433
IndyRC_Racer's Avatar
I need to glue up some new VTA tires on chrome wheels. I'm looking for any shortcuts to removing the chrome in the areas that will have super glue - specifically the area where the side wall of the tire attaches to the wheel.
When you glue the VTA wheel onto the tire at this point, the chrome is actually under/hidden by the wheel. If you don't remove the chrome before you glue the tire, it usually pulls off the wheel, which causes the outside of the tire to pull away from the wheel. Basically the tire gets glued to the chrome, but the chrome plating pulls away from the wheel. When the plating pulls off you can try to glue it back onto the wheel, but I've always had mixed results (which is why I remove the chrome plating).
I can obviously use some type of abrasive (sand paper, file, etc) to remove the chrome, but I'm being lazy and want to know if anyone has found a quicker/easier way to do this (without damaging the wheel). I was thinking of using a q-tip to apply some type of chemical over the chrome that I want removed and hope that it will just wipe away with a little bit of effort.
Any suggestions would be appreciated.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 01-19-2015, 02:29 PM   #8434
Try a Q-tip dipped in Acetone and if that doesn't work, try using a soft wire brush in a Dremel tool
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 01-19-2015, 03:42 PM   #8435
Anyone still running the old Yokomo MR-4TC chassis? I picked up a special and any setup/gearing tips would be great..
thanks
sschering is offline   Reply With Quote
Old 01-20-2015, 02:21 AM   #8436
howardcano's Avatar
Trader Rating: 35 (100%+)
How was everyone's VTA racing this last weekend?
We had a blast at the Omaha HobbyPlex. We run one qualifier (average of five fastest laps in an eight minute session) and three mains with inverted starts. TQ was decided by about 0.05 seconds, and all three mains had first and second separated by (I'm estimating) no more than one second for the entire race duration. Wow!
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-20-2015, 11:19 AM   #8437
RotorTruck's Avatar
I've been using a stainless steel wire wheel in the dremel to remove the chrome on the sidewall, and also to buzz along the bead groove to rough up the surface a bit. Works beautifully. If I had a brass wheel I'd use that instead as its softer, but haven't gouged a wheel yet.
Muchmore Racing Instant Rubber Tire CA glue is fantastic with these HPI wheels and tires. Sets up super duper quick though. I've found that holding the wheel upright is necessary, so the glue runs down the bead.
RotorTruck is offline   Reply With Quote
Old 01-21-2015, 11:02 AM   #8438
hoyt1967's Avatar
Trader Rating: 34 (100%+)
Ok guys I have a gearing question. So on a small track, a higher FDR is desirable, correct? I was getting pulled on the infield pretty bad last race, so I asked the leader what FDR he was running, he said right at 4. I had mine geared for a 4.2. So with this info should I continue to go smaller with my pinion? Or am I way off base here. (new to on road so forgive my ignorance)
hoyt1967 is offline   Reply With Quote
Old 01-21-2015, 11:45 AM   #8439
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Could be a series of issues - timing could be off, drivetrain might not allow the car to roll freely through the corner, suspension set up might be scrubbing speed, or a combination of all three. I'd make sure the timing is advanced from the factory mark a minimum of 10 degrees, and start looking at vehicle setup to find the infield speed you need. Corner speed is everything, especially on carpet.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 01-21-2015, 11:52 AM   #8440
Tech Legend
Cain's Avatar
from what I recall for hoyt, they also run plan VTA for motor rules, so it could be the motor you are referencing may be different than yours too and have different performance characterstics.
I also noticed that at the PRCP track that depending on how hot I can into the first turn then the infield, I saw different punch performance with the Novak 25.5 motors. Its like I needed to adjust my driving style to get the feel of more torque in the infield, I wish I could explain it better.
Old 01-21-2015, 12:07 PM   #8441
anyone using the Ferrari 599xx body... nit sore what paint scheme I want.... dont want all red.. or just 1 colour..
coolair is offline   Reply With Quote
Old 01-21-2015, 12:45 PM   #8442
hoyt1967's Avatar
Ok, should have added this 1st off. I'm running a Boss Novak, timing is at 35degrees on the "pointer", the chassis is pretty free (xray t4) and I'm running the stock carpet setup in it right now. My motor temps were low 120's after a 5 minute heat. Should I be gearing for a 170 degree temp? I know my setup could be better, but it definitely didn't have the pull out of a corner like the faster cars.
Old 01-21-2015, 12:58 PM   #8443
oeoeo327's Avatar
Not knowing the track dimensions, it's tough to say if you'd benefit from more timing or a higher (lower numerically) FDR. If it's a short track, add timing and see if motor performance picks up. If it's a longer track, add 5 degrees of timing and 4 teeth on the pinion. That should get you in the ballpark for all tracks with a straightaway of 70 feet or less.
That said, speed in and out of the corners is found in the chassis; the true challenge of participating in this class is finding all the speed you can in the chassis setup.
Old 01-21-2015, 01:09 PM   #8444
snoopyrc's Avatar
thanks
I have two of them and I love them but I am faster with a newer chassis. Double cardigan joints from a BD5 helped. Front spool did not seem to work as well as the differential. At least for me on tight tracks i rolled through corners better with a ball diff.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 01-21-2015, 01:47 PM   #8445
hoyt1967's Avatar
Thanks for the info. I agree with you on the setup...I have my work cut out.
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 5998 07-05-2017 07:02 PM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
