Like Tree253Likes
Old 12-22-2014, 06:08 PM   #8356
godzukihop's Avatar
Trader Rating: 31 (100%+)
Default GForce Motor Analyzer
Just got my GFORCE MOTOR analyer and have been playing around with it, but had a few questions. Can anyone advise on good or max #'s for amp draw, RPM, timing and noise.
JOHN's MOBILE RACEWAY | 180 RACEWAY | Jackson RC Track
Murnan Modified because HP is intoxicating!!! | VP RACE FUEL |
G-FORCE HOBBIES | Fordham Hobbies | ASHFORD HOBBY | TEAM CAMDEN
RC AMERICA / XRAY / HUDY / TEAM POWERS
godzukihop is offline   Reply With Quote
Old 12-23-2014, 01:53 PM   #8357
Only one I'll comment on is the timing. Used to be a max timing rule for the BOSS motor of 45 degrees. However RobK announced in the USVTA thread he was rescinding that rule as it was outdated (and unenforceable because of issues with the placement of the timing labels). That said the USVTA rule book still has the 45 degree rule in it. My BOSS is timed at 45 degrees (with my motorlyser) and runs great, I'm at a 3.6 FDR and the car runs strong throughout a 12 minute main. Depending on the track, FDRs between 3.6 and 4.0 are common with that timing.
John Wallace2 is offline   Reply With Quote
Old 12-23-2014, 02:29 PM   #8358
godzukihop's Avatar
What is your rpm & amp draw @ 45 degrees?
Old 12-23-2014, 03:08 PM   #8359
LasagnaCat's Avatar
Trader Rating: 140 (100%+)
Send a message via AIM to LasagnaCat
And being able to set it at 45 degrees (no matter how you get there) does not necessarily mean that's where you should be running the timing on any particular motor. The whole 45 degree thing is often misused and misunderstood.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 12-23-2014, 07:44 PM   #8360
+1
Totally DIALED is offline   Reply With Quote
Old 12-23-2014, 08:00 PM   #8361
RotorTruck's Avatar
What do you think of my setup sheet? TC4 VTA on asphalt outdoors. Soda prepped track, very good traction. The front tires wore out real fast, predominantly on the inner 2/3 of the tread so I'll bump the camber down to 2.0*.
RotorTruck is offline   Reply With Quote
Old 12-23-2014, 08:49 PM   #8362
Sorry I don't remember off hand and I don't log that information as free revving RPM and AMP draw aren't of much interest to me; I use my dyno for that info.
After seeing two guys (both good drivers) run the same motor in USGT on the same track; one with minimum timing (~30 degrees) the other with max timing (~60 degrees) but different FDRs and have the same lap times, there is nothing magic about 45 degrees. My motor just happens to be very very happy there.
Old 12-23-2014, 09:07 PM   #8363
Sorry I couldn't read your setup sheet (too small or too poor eye sight). What are your front camber and toe settings? And what is "real fast" - two runs two weekends or ?
Old 12-24-2014, 08:17 AM   #8364
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
looks like he's running -2.5* camber and 1* toe
personally, i think the -2.5 is too much.. I usually only use about -1* on my TCXX
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-24-2014, 08:24 AM   #8365
Yea me too, the front caster helps with the camber gain in the turns. But the wear pattern is the same as I get, but my VTA tires last more than 5 or 6 weeks.
Old 12-24-2014, 09:19 AM   #8366
howardcano's Avatar
Trader Rating: 35 (100%+)
A spool on the front will definitely increase tire wear, especially on asphalt. Try a differential. On our very abrasive track, we see about a factor of two difference in tire life between the two.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 12-26-2014, 03:10 PM   #8367
IndyHobbies.com's Avatar
Running at Indy RC Raceway tonight. Just a fun evening of club racing. I wanted to see what one of the new RPM blowers would look like so I mounted it to my old Camaro body. It's a really solid unit and held together with 2 hex head bolts through a reinforcing plate underneath the hood. So, 2 small holes through the body is all you need.
Weight seems to be about 20 grams. The edges are rounded from the factory, so I don't believe carpet damage is an issue. Certainly will cause some drag too. But... man it looks cool.
Seems like a car with a blower should do a burnout before racing too.
Update: Better photo with blower on a new body:
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 12-27-2014, 06:46 AM   #8368
NutDriver's Avatar
Trader Rating: 15 (100%+)
Now it needs the Team Associated Ess-One or the Traxxas sound unit out of the Slash.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 12-27-2014, 05:16 PM   #8369
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
looking forward to someone using that sound system in VTA
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 12-27-2014, 05:56 PM   #8370
NutDriver's Avatar
If I can find one in stock somewhere besides Associated and preferably less than full retail, I will be running one soon!
USVTA member #111
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 5998 07-05-2017 07:02 PM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
