Old 12-02-2014, 12:51 PM   #8131
theproffesor's Avatar
Trader Rating: 45 (100%+)
Nothing limits ROAR from using a specific manufacturer tire/motor/battery. I asked this in another thread and was answered by NITRO450 (who is apparently a ROAR board member) that there are no rules/bylaws preventing it, they just dont do it.
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 12-02-2014, 12:54 PM   #8132
Originally Posted by nf_ekt View Post
You can get the only "old" cars with some degree of parts support left (xxxs, tc4/4...ran them all) under 1550g without too much effort. As well as others. On asphalt 1550g makes for some fast wearing tires.
I'm not arguing against the aspect of running older cars and having fun. Heck, I wish I still had my RDX. Eventually the old parts supply for antiquated cars dries up.
And yes, I have been a loyal USVTA guy. even when I show up to tracks where ROAR is the locals choice and I suffer with a heavy car. I make top-3 in these situations sometimes. Gonna' need another car though...roar & usvta rides to bring out depending on what's being run.
One of the fastest guys around here in VTA races a TC3. Not sure what fast tire wear is but I'm getting 6 to 8 weekends on a set of VTA tires before they are bald (practice, 2 or 3 qualifiers and 12 minute main each weekend) 1550+grams on asphalt but big track.
John Wallace2 is offline   Reply With Quote
Old 12-02-2014, 12:54 PM   #8133
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
using yes -spec'ing it into the rules, no
that's what I was referring too.. I remember that being said once before and i remember that being said when I was on a rules committee about 6 years ago (not for USVTA, however)
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-02-2014, 01:05 PM   #8134
Tech Legend
Cain's Avatar
Trader Rating: 210 (100%+)
so, would it be better to have the discussion in a thread specific for ROAR VTA changes then if that is what is being targeted?
< Team Associated RC10B6D x 2>
< Tekno SCT410.3 x 2>
< Durango DEX410V5>
Old 12-02-2014, 01:40 PM   #8135
Guys, if anything were to be made consistent with the two sanctioning bodies, there would have to be give and take from both sides.
The battery and weight rules are the EASY ones to give up in exchange for a spec. motor. It's not a compromise if everything only goes one way.
.crispy is offline   Reply With Quote
Old 12-02-2014, 01:55 PM   #8136
howardcano's Avatar
Trader Rating: 35 (100%+)
USVTA already changed from the USVTA ESC list to the ROAR ESC list. Now it's ROAR's turn to change something. That's why I said "reciprocate" in my previous post.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 12-02-2014, 01:58 PM   #8137
nf_ekt's Avatar
Trader Rating: 113 (100%+)
The track I have been to the most in the last few months is pretty tight and certainly a bit rough. It's hard on tires, but no one seems to care if they are bald or not. And the TC3 is certainly good- I had one with trf shocks and it was on-point. But I like belt better. Weight? Hey whatever, but since we have people in higher places affiliated with both sides of the fence, it would be great if a uniform minimum could be agreed on. That pretty much solves the issue between the two camps. Thumbs up to the larger array of esc's we can now use. ROAR should consider bridging the gap in a few minor areas.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 12-02-2014, 02:09 PM   #8138
Spec. motor is a biggie. THE big one.
You better be prepared to concede everything else.
Old 12-02-2014, 02:10 PM   #8139
Tech Legend
Cain's Avatar
So, in short, what are exactly the differences between USVTA rules and ROAR's current VTA Rules?
Right now I see:
- Weight
- Battery size requirement
- Tire specific requirement
- Motor specific brand requirement
Is there more to it than that?
< Durango DEX410V5>
Old 12-02-2014, 02:16 PM   #8140
k_bojar's Avatar
Right now I see:
- Weight
nope
Old 12-02-2014, 02:19 PM   #8141
Right now I see:
- Weight
I didn't realize "they" don't have a spec. tire. What do they use?
Staying with those vintage HPI tires is a must. Maybe the HPI option vintage tires, but certainly not open open?
Old 12-02-2014, 02:21 PM   #8142
k_bojar's Avatar
they have/had dimensions that matched the HPI tires. plus at the events, it was spec'ed to be the HPI tire - but you were allowed to bring your own tires
Old 12-02-2014, 02:26 PM   #8143
Tech Legend
Cain's Avatar
I think the big thing with ROAR is that they appear to not limit it to one brand in the rules from what I can tell, I could be wrong and that is fine, but it appears to be more open that other manufacturers can get on board if they choose.
Me personally, either works, I may prefer one method to another, but you have to use what works for you. I can see the arguments the pure usvta guys use as well as the guys who want more stuff open.
As for things to compromise on, personally I wouldn't mind this as a hybrid of the rules:
- Weight
1500grams
use a maximum weight requirement as the whole mah thing to me personally seems you can fudge that unless you are teching and approving packs specifically to be made with true "5000mah" cells.
< Durango DEX410V5>
Old 12-02-2014, 02:35 PM   #8144
The problem with the max mah requirement is that as battery technology gets better and better, the 5000mah packs are getting lighter and lighter which just exacerbates the weight issue.
With that part open, you make the decision knowing that more mah generally means more weight.
Old 12-02-2014, 02:40 PM   #8145
howardcano's Avatar
"I" don't need to concede anything. Rob sets the rules for USVTA. He has stated many times that the motor will remain Novak.
Also, ROAR still needs to release rules for 25.5 motors. But that's something that doesn't really fit into this thread at the moment.
Howard Cano
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5864 01-07-2017 11:00 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
