Like Tree12Likes
Old 11-22-2014, 11:41 AM   #8056
DARKSIDE's Avatar
here is my new solution
http://www.teamassociated.com/news/l...d_Sound_System
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 11-22-2014, 11:58 AM   #8057
Tech Legend
Cain's Avatar
Trader Rating: 219 (100%+)
Originally Posted by DARKSIDE View Post
very nice find!
< Team Associated RC10B6D x 2>
< Tekno SCT410.3 x 2>
< HB Racing D413 x 2>
Old 11-22-2014, 04:07 PM   #8058
NutDriver's Avatar
Trader Rating: 14 (100%+)
A couple of us have been talking yesterday and today about what a redneck good time the new sound system could make VTA racing. Don't like putting ballast in your car? The new Associated sound system is about 90 grams.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 11-22-2014, 06:34 PM   #8059
SWTour's Avatar
lol - I was on the phone w/ a buddy of mine today, who was at the ASSOCIATED Garage Sale and he put Don Natale on the phone...and played one of those over the phone. IT WAS LOUD!!
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 11-22-2014, 08:20 PM   #8060
NutDriver's Avatar
The ad says that it is 25 or 30 amps (depending on what page you read).
USVTA member #111
Old 11-27-2014, 09:09 AM   #8061
spurcheck's Avatar
Default Setting up TC3 for VTA.
Hey guys, pardon my ignorance on this question. It's more than likely been asked numerous times before so bear with me. On setting up a TC3 for a friend and I believe I recall some modification on some level is required to get enough gear hung on the car to at least have it somewhat competitive (speed wise, not handling wise). Can someone give me some pointers on what is needed and gearing suggestions ie; pinion and spur, thanks.
The Punter or The Punt-ee,,,,,,,,,,,,,,,,,,,who you be??
No Apologies Racing, don't believe me, try me!!!!!
spurcheck is offline   Reply With Quote
Old 11-27-2014, 09:14 AM   #8062
godzukihop's Avatar
Trader Rating: 31 (100%+)
U.S. Vintage Trans-Am Racing Part 2
i believe it starts with post #7746
JOHN's MOBILE RACEWAY | 180 RACEWAY | Jackson RC Track
Murnan Modified because HP is intoxicating!!! | VP RACE FUEL |
G-FORCE HOBBIES | Fordham Hobbies | ASHFORD HOBBY | TEAM CAMDEN
RC AMERICA / XRAY / HUDY / TEAM POWERS
godzukihop is offline   Reply With Quote
Old 11-28-2014, 09:44 AM   #8063
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Jeff - look for IndyHobbies posts, I know he was running (and done alot with) the TC3.. I did some of them to my TC3 for rally racing... when I get a chance I can pull it out and look at it. if I actually got out racing once and a while, I'd bring the chassis with me for you to see in person
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 11-28-2014, 10:26 AM   #8064
First you need to do some "Dremel surgery" to remove the webbing under the pinion gear. Probably want to start with a 60T spur, 38 pinion with 48-pitch gears (depending on track size & configuration). Robinson has 60T & 55T spurs.
Kevin Marcy is offline   Reply With Quote
Old 11-28-2014, 11:37 AM   #8065
IndyHobbies.com's Avatar
Here's the mod that is required. You can take the webs out with your dremel entirely, or just enough to clear your pinion. That's what I did. I left as much as I could.
I thought I had a photo, but couldn't find it. Here's a photo I found:
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 11-28-2014, 11:53 AM   #8066
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Yep, dremel that area out and it's good to go. I think I had to dremel the bottom part of where the motor mounts in two places... once you try to use the motor cam part that screws to the motor, you will see how the rotation is limited... just keep looking closely at what's going on and do test fits until everything lines up. I also modded the chassis brace piece (RR) by dremeling slightly to ensure clearance. Get it right and you can run any FDR you want.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 11-28-2014, 01:21 PM   #8067
spurcheck's Avatar
Thanks guys. In between "turkey bingeing" I did just that. Ended up installing 49/76 64 pitch and it worked out. Any as you guys indicated, if I get aggressive enough with Mr. Dremel, I can get it to run whatever fdr I want.
Old 11-28-2014, 01:23 PM   #8068
spurcheck's Avatar
Hey Indy Hobbies. You may have solved another problem I was going to have to work out. The pic shows location of a fan,,, thanks!!!
Old 11-28-2014, 02:36 PM   #8069
k_bojar's Avatar
i also grinded away a little of the motor cam on mine too - wanted to get as much movement in mine as possible... but mine was all done for RALLY, baby
this mean you're going to be making a return to VTA??
Old 11-28-2014, 06:58 PM   #8070
spurcheck's Avatar
I'm doing up a car for a friend, getting him up and running, VTA to me is the perfect platform. Actually, there are many drivers that could learn a thing or two about racing by running in this class. I like that the cars are running at a more realistic pace, more door to door racing, you aren't chasing the "motor of the week" and more emphasis is on chassis set up and making wise choices on the track.
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5870 02-22-2017 09:31 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
Currently Active Users Viewing This Thread: 5 (2 members and 3 guests)
Loco4G63T, Metalsoft
