Like Tree227Likes
Old 06-18-2014, 08:35 PM   #7651
snoopyrc's Avatar
Originally Posted by Kevin K View Post
Let keep this one for the bickering and name calling...thanks.
Good cause I need a place where I can do that freely.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 06-19-2014, 06:35 AM   #7652
snoopyrc's Avatar
Originally Posted by Loco4G63T View Post
Hi everyone,
I am new to VTA racing. I am going to run my 13' Xray T4 with my own brass weight system to include two brass weights that two other companies produce. My car weighs in at 1562 with body and am 6mm ride height front and rear. The only foreseable issue I have with VTA rules is the GTB 3/ Ballistic 25.5. I have one question with regards to gearing. I have the 64 pitch setup with a 35t pinion and 116 spur. Will this fly on a 90x60 track roughly? I also posted some pics of my first VTA body/ 1966 Mustang GT. Most of the details are painted in to include all the lights, chrome, stripes and window trim. I look forward to any and all feed back.
Originally Posted by mikel33 View Post
Your gearing is, unfortunately, a ways off. your fdr is about 6.3 and you should be somewhere in the vicinity of 3.5 to 3.75 (I pretty much run 3.5 with as much timing as the motor can handle - others may do it differently). The 116 spur is much too big. I have run several xray's in vta, including a 2013 and for that size track I would use a 92 tooth spur and maybe a 49 tooth pinion - then gear / adjust timing based on motor temp & performance.
Your gearing might be a ways off but your paint is spot on. Welcome to USVTA. On a 90x60 track I like my fdr lower with more torque. Closer to 3.8. That's just my preference.
Nice job on the paint.
Old 06-19-2014, 07:01 PM   #7653
Send a message via AIM to JimmyMack12
Would someone point me to the "updated ESC rules" post(s), so that I may update our Web site for Vintage Stock Cars as well?
Also, has/was the USVTA site updated and current yet with the new stuff?
JimmyMack12 is offline   Reply With Quote
Old 06-19-2014, 07:41 PM   #7654
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
yeah the rules are updated on the website.
http://www.usvintagetransam.com/rules/index.html
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 06-19-2014, 11:27 PM   #7655
It doesn't appear that the PDF version has been updated. If you're like me and assume that they are both the same, be careful.
calvin is offline   Reply With Quote
Old 06-20-2014, 05:03 AM   #7656
Can someone actually point me to the actual list of approved speedos?
Yeah, I've found the ROAR website and I've found the rulebook. I see a lot of specs. Justl don't see a "list".
.crispy is offline   Reply With Quote
Old 06-20-2014, 05:33 AM   #7657
howardcano's Avatar
Trader Rating: 35 (100%+)
http://www.roarracing.com/approved_non_timing_escs.php
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 06-20-2014, 06:38 AM   #7658
My bad. I assumed it would be sub-heading under RULES.
Thanks.
Old 06-20-2014, 07:03 AM   #7659
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Thanks.
nope
approvals - go figure
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 06-20-2014, 09:31 AM   #7660
wwddww34's Avatar
Trader Rating: 9 (91%+)
I kept checking the date at the top of the web page and it still says "Rules updated 08.27.2013." You have to scroll down to the Motor Specifications section and look at the ESC list to see where any changes have been added.
That's funny. The PDF rules say that they were updated on 6/6/2013. The PDF rules are definitely very different than the web page rules. The Protoform '71 Pontiac Firebird Trans-Am body is not listed in the PDF. Also the PDF rules does not mention the approval of ROAR 'blinky' ESC's.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 06-20-2014, 01:02 PM   #7661
robk's Avatar
Trader Rating: 22 (100%+)
i have to update the pdf.
Old 06-20-2014, 11:38 PM   #7662
xrayracer1's Avatar
HI guys, I'm wanting to turn my xray t3 into a vta class car. I was wanting to know which HPI rims do I use on the front since the vta bodies are 200mm wide. I know the 31mm rims have a 6mm offset but I can't find any 26mm rims with an offset.
Gavin.
Converting nitro to electric is utter blasphemy.
xrayracer1 is offline   Reply With Quote
Old 06-21-2014, 03:30 AM   #7663
k_bojar's Avatar
all front vintage rims are 26mm wide, 0mm offset and all rears are 31mm wide, +3 offset.
trust me, it works - no matter which chassis you run you might, however, need some flat shims (or thicker wheel hexes) in order to really fill the wheel wells on some bodies - but on 95% of the bodies, the wheels and a 190mm chassis work
Old 06-21-2014, 04:04 AM   #7664
xrayracer1's Avatar
Thanks.
Gavin.
Old 06-21-2014, 08:04 AM   #7665
snoopyrc's Avatar
Unless you are running the Pegasus Camaro. That thing is awful big. VTA chassis running that thing looks like a toddler wearing daddy's shirt.
The HPI vintage wheels and tires were made to go with the HPI vintage bodies on a 190mm chassis. Stance and the rear being wider, it's all intentional. It's a look that HPI was going for. Then we started racing that stuff.
The Protoform VTA shells are blessings from God and Dale and were made for us to use in this class. I think the McAllister shells on the USVTA list were also made specifically for us. I think the Parma Pegasus and whatever else is on the list is stuff that just happens to work.
But I could be wrong.
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 5991 Yesterday 06:53 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
