Like Tree122Likes
Old 05-29-2014, 06:59 PM   #7261
hanulec's Avatar
Trader Rating: 24 (100%+)
Parma 70' Cuda. Best USVTA body for sure!
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-29-2014, 07:34 PM   #7262
snoopyrc's Avatar
Originally Posted by nf_ekt View Post
I like the durability it has as-is. And I figure as heavy as you have to make these things, the shell is just another way to achieve the mark. Definitely like the 68 . My LHS has had no problem getting them.
I would like to see one pulled from a little heavier lexan. They did that with the 70 Cuda and I liked it much better.
I think you just liked torturing every one with it like you do. It did handle well at the birds. Of course that could have been the chassis. Nah it has to be that Parma shell.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 05-29-2014, 07:37 PM   #7263
CraigMBA's Avatar
Trader Rating: 22 (100%+)
Wrong thread. Looking forward to shaking down my new VTA car on Saturday.
* Cee Lo Dizzle, the Secizzle * Red Bull * Team Homies * Pintura de Negro Mate * USVTA #152
CraigMBA is offline   Reply With Quote
Old 06-01-2014, 06:40 PM   #7264
nascarkeith's Avatar
When I drive a clean race I have the normal group of VTA guys at my track pretty well covered. I can at least run top 3 almost every race. Every once and a while someone shows up and runs the class that I just can't keep up with. What am I missing?
I run a TC4. Timing and gearing are pushing the limit with temps. Set up drives great. Bearings and diffs are decreased and free rolling. I just don't know where I am losing speed on some guys.
In racing if it goes out of bounds it probably ain't coming back.
SouthviewRC.com
nascarkeith is offline   Reply With Quote
Old 06-01-2014, 07:06 PM   #7265
mikel33's Avatar
Trader Rating: 2 (75%+)
What are you missing? Sort of a loaded question. Experience most likely. Both your setup and driving. Sometimes what we might think is dialed in, a top level driver might go 'eh.. not so much'.
Nothing wrong with the tc4, maybe a more recent chassis could offer something, but plenty of guys are competitive with that chassis. When you say you are pushing the limit with temps, what is the temp? What kind of track? Big, small, tight, open? Not that I am all that special, but I usually set my gearing at 3.5 for vta with a lot of motor timing for indoor carpet, lower gearing for bigger outside tracks. I've been down into the 2's on asphalt.
Michael Larson.
Village Idiot Racing
mikel33 is offline   Reply With Quote
Old 06-01-2014, 07:54 PM   #7266
SWTour's Avatar
as a long time Oval guy, generally most of us who are chasing speed are losing it in the handling/corners.
On a Oval w/ only 4 corners - 2 entrance/2 exits, it makes a huge difference...
But think about that on a Roadcourse... 10, 12, sometimes MORE corners.
If you over drive the corner and scrub speed coming off just a LITTLE on each corner...you've lost a Ton of Time over a whole lap.
If you are using 70% steering rate while someone else can get through the corners with only 20-25% rate - you are losing speed that you may not even feel.
Myself, I tend to drive way to deep into a corner, then have to force the turn...instead of making a nice smooth corner with an early entry and good exit... I KNOW IT, but can't ever seem to fix it - I get close sometimes...then WHAM I short cut a corner and lose a whole lot more time then if I'd just kept the line I'd been running.
I am always in such awe of the Open Mod guys and how they take corners...
Joe Myers
R/C Racing since 1985 ~ Santa Maria, CA (Central Coast)
2001-2012 - South-West Tour R/C Oval Series...will the SWT be revived?
Things are headed towards a return of the SWT Series, but for
2017 the focus will be on the Encino Velodrome (and dirt oval racing)
SWTour is offline   Reply With Quote
Old 06-01-2014, 08:04 PM   #7267
nf_ekt's Avatar
Trader Rating: 113 (100%+)
I hear you, I guess I've always enjoyed "over-driving" a bit... I just have more fun that way. When I make the point to ease into corners, keep it tight, and get it back on power / in a straight line quick I run better laps. but I get bored of it.
In VTA if someone is consistently running a tenth or two faster per lap, it truly adds up over 6-8 minutes. It's not that they are blowing your doors off, it's just that small advantage per lap that can collectively make the difference. You pay for every mistake in this class!
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 06-01-2014, 08:14 PM   #7268
mikel33's Avatar
Yep.
Michael Larson.
Old 06-02-2014, 05:13 AM   #7269
The winds of change are on the horizon.
I guess what they say is true about the squeaky wheel.......
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 06-02-2014, 06:53 AM   #7270
dave-man's Avatar
Care to fill us in or are you just going to leave us hanging?
dave-man is offline   Reply With Quote
Old 06-02-2014, 07:03 AM   #7271
howardcano's Avatar
Trader Rating: 35 (100%+)
A) Locate wasp nest.
B) Insert stick.
C) Shake vigorously.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 06-02-2014, 10:44 AM   #7272
IndyRC_Racer's Avatar
I sure hope this isn't hinting at changes to speed control rules.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 06-02-2014, 11:32 AM   #7273
wwddww34's Avatar
Trader Rating: 9 (91%+)
+1
Yeah, tell us what's a squeakin man?
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 06-02-2014, 11:46 AM   #7274
I do like a nice New York Cheddar with my whine
Old 06-02-2014, 11:47 AM   #7275
B) Insert stick.
Well, I did grow up in the early 70's when eating lead based paint chips was the norm :-)
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5973 04-20-2017 07:27 PM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
