Old 05-08-2014, 10:53 AM   #7126
chiefj48's Avatar
Originally Posted by k_bojar View Post
side-by-side racing is, and always will be, more entertaining then lapping the field for the 7th time
BINGO!!!!!!!
chiefj48
Home of the; 2016 ROAR On Road Asphalt Nationals
Special Thanks to , Awesomatix USA, Valkaria RC, Trinity, Discount RC Store, Team Associated, Team Powers, Prime Hobby
https://www.facebook.com/ValkariaRcraceway/
chiefj48 is offline   Reply With Quote
Old 05-08-2014, 11:25 AM   #7127
Trader Rating: 32 (100%+)
Originally Posted by nf_ekt View Post
hey....Led Zeppelin...
you keepa knockin but you cant come in
fermanracer is offline   Reply With Quote
Old 05-08-2014, 11:35 AM   #7128
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I know, I bought an RS off you.
I knew your userID looked familiar
So my question for you is this... do you personally feel that some of the ESC's apparently now in question should be removed?
The thing myself, along with a number of others have been trying to do, is find an accurate / valid reason to do so. Parity exists when using a HW or SP. Close racing exists. Equal performance (despite "profile "feel") exists. Will it help the class to remove them? Or just make some people feel better? It will certainly benefit Novak, but that is for another discussion. Find a "secret boost profile" for one of these ESc's, regardless of brand, and I will whole-heartedly agree.
honestly, I think the list is fine as is. the problem with allowing one a 'chance' is the backlash that will happen if/when its found to have a profound advantage over the others... look at what's been happening with the HW
If the speedo can be locked in a spec/non-timing mode only, regardless of updates, then it probably should be allowed if, and only if, its been proven to NOT provide an advantage over the existing ones.
USVTA doesn't need to turn into a 'flavor of the week' class like the other classes are. Racers, by nature, will always look for what gives them (the appearance of) that extra umph. so you will never, ever please everyone - its down to controlling the the possibilities of what's available in order to find that 'one good one'
I remember the last Scale Nationals I went too... One kid (and he was a kid), have 4 speedos on his workbench, plus the one in his car. he was trying to find the 'one' that would give him that advantage. now, personally, that's a lot of $$ to just be sitting there for a spec class, or any class for that matter. but that's what he did, and obiviously, it seemed his dad was fine with it. now would allowing a tekin or orca in the mix change anything? who knows, but it definitely would have blown up a cost control approach to the class
Bodies By Bean | Team Belly
k_bojar is online now   Reply With Quote
Old 05-08-2014, 11:54 AM   #7129
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Mellow.....Melllooowwww....
Well, anyways, I've thrown my .02 in enough for now. I think if we cut two of the most affordable zero-timing ESC's out of the picture in USVTA, it is a shame and a loss. Nothing improved. It won't really affect me personally as the VTA racing locally is a half Roar/ half USVTA deal anyways. But as a whole, I find it to be completely unnecessary... and a fix to a non-existent problem. And more money to spend on an "affordable" class. Time will tell....
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 05-08-2014, 12:33 PM   #7130
Originally Posted by Jorge T View Post
FWIW I have a 25.5 D3.5 maxilla that is weak compared to my Novak Boss 25.5
Unless you modify the timing end of the motor, the 25.5 D3.5 timing is limited to 20 degrees and at that timing its a dog compared to other motors unless you run a very big pinion and a really small spur. If you modify the end bell so the timing ring can rotate to 40 degrees, it really comes to life, but that modification is most likely illegal and why I'm not using that motor.
John Wallace2 is offline   Reply With Quote
Old 05-08-2014, 01:01 PM   #7131
Originally Posted by theproffesor View Post
So I assume by now everyone can tell im pro Tekin and pretty much anti novak. But I can say that betwen Tekin, Novak, and Trinity, motors I have run, the Novak is definately the more powerfull motor. Top end is close to the same, but has a good deal more low end than the other 2. On the Novak crank the timing up and go at it. On thenother two, its takkng me some time to find that sweet spot. I dont mind the one motor rule, but even ifnit were open, I think people wouldnstill gravitate to the Novak.
We'll see about that. We are having a race this weekend with an "any 25.5 motor rule" in vta. I know of at least two other motors that will be used. So I'll see how the Novak compares with the others. My motor, at the same FDR as my Novak, has more bottom end rip and visibly more top end than my BOSS, but my BOSS motors aren't the fastest either. I may run the Boss for one of the qualifiers just to see the difference in lap times.
Old 05-08-2014, 01:20 PM   #7132
moparSRT's Avatar
I'm building the Spec-R now, and i'll weight it when I'm done - I'm willing to bet I'll have to add at least 50g to get to the legal 1550 weight... so how is lowering the weight going to benefit someone that just bought that chassis? I'm sure the 3Racing isn't too far behind the Spec-R
going to 1450 will put a lot of chassis at a disadvantage (and I'm betting most of the 'cheaper' sport edition models ...
FYI my 3Racing XI Sport came in @ 1385g RTR with everything.
Needs 165g 24 lead bricks to get 1550g
2014 IFMAR Warm-Up Pics >>> www.rcactionpics.com <<<
Check it out >>> www.RaceVTA.com <<<
moparSRT is offline   Reply With Quote
Old 05-08-2014, 01:24 PM   #7133
Default ESC discusions
I haven't been reading this thread lately and probably should have. But the discussions about banning the HW Just Stock ESC concerns me as that is the ESC I have. The issue is back loading unapproved software version into the ESC. True you can update the HW software just like you can update the Tekin software, which makes it easy to upload it with unapproved software versions. But in both cases its reasonably easy to verify which version of the software is loaded in the ESC. More so with the HW than a Tekin, because you have to use the handheld programming box to update the software (although TEKIIN now now has an APP to program ther ESC with an Iphone). When you plug the HW ESC into the box and turn the car on, the programming box software version and then the ESC software version are displayed and can be checked if there is any suspicion of cheating. Might take 2 minutes to complete on any suspected car or tech any car in the top 3 with a HW ESC. IMO just too easy to tech what software is in the HW Just Stock ESC to consider banned this ESC.
Old 05-08-2014, 01:33 PM   #7134
moparSRT's Avatar
FALSE !! you cant upload any software to the JUSTOCK, you are limited to only NO TIMING, same with the TEKIN SPEC which will not allow you to upload ANY software with turbo/boost.
Old 05-08-2014, 01:33 PM   #7135
k_bojar's Avatar
or about 4, maybe 5 .9 oz tungsten squares. which is what i'm going with.
give it a rest.... the weight for USVTA isn't changing anytime soon - there's been more then enough reasons why its not going to change, so you can give up your 1 man crusade and go run ROAR rules already
Old 05-08-2014, 01:33 PM   #7136
k_bojar's Avatar
nevermind... old man is blind here
Old 05-08-2014, 01:42 PM   #7137
moparSRT's Avatar
any you're proven this?!?!?!! I know on my HW, the only software options available to me, are the 508_nontiming versions
you just confirmed what I said, so why are you questioning it
Old 05-08-2014, 01:45 PM   #7138
k_bojar's Avatar
shit.... because i'm blind and didn't see you did say can't - missed the ' on the word
my bad
Old 05-08-2014, 01:47 PM   #7139
moparSRT's Avatar
or about 4, maybe 5 .9 oz tunsgen squares. which is what i'm going with.
thats around $35 for tungsten weight on a $112 car, makes a lot of sense
dont care, we run 1450g in my neck of the woods
Old 05-08-2014, 01:48 PM   #7140
k_bojar's Avatar
not if you shop around.. seen them on ebay for less then $3 a square. I know I was pricing 10 of them (so 9oz of tungsten) and it was less then $30 shipped to me - which is more then enough for 2 cars
before its asked, here - http://www.ebay.com/itm/181357188011...%3AMEBIDX%3AIT
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5864 01-07-2017 11:00 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
SEO by vBSEO 3.5.0
