Like Tree84Likes
Old 05-05-2014, 05:32 PM   #6976
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
Originally Posted by snoopyrc View Post
There are drift cars that are purposely built like that with the weight laid out like a real car motor in front RWD. I think they drift well, but I doubt that they would handle at all. If I had the money I would build a VTA ride on that layout, just to test it.
On the VTA Florida conundrum, I feel your pain. I am sure that many racers keep gear around to go either way. I also think that the USVTA rules keep sponsored drivers involvement at a reduced level by limiting the use of gear. That may or not be intended. Also, fully legal cars do just fine at ROAR events.
Snoopy thanks for the thoughts. Yes, you are correct, often a USVTA car is just as fast.
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 05-05-2014, 05:53 PM   #6977
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Unhappy
Snoop you NAILED IT !!!!!
As for the Florida conundrum the problem I see is MUTE !!!!!
To many cooks in the kitchen ...... Is the best way I can put it .
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 05-05-2014, 06:12 PM   #6978
.crispy is offline   Reply With Quote
Old 05-05-2014, 06:18 PM   #6979
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Just a thought - maybe the ROAR VTA faithful need their own thread...
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 05-05-2014, 06:53 PM   #6980
I agree. Squash any dissenting opinions. It is must more enlightening when everyone is of one mind.
Old 05-05-2014, 07:06 PM   #6981
NutDriver's Avatar
Trader Rating: 14 (100%+)
Please excuse the noob question. Feel free to direct me to the correct entry in the thread, etc. I've been running used tires since I started in VTA. Just ran my first set of brand new shoes. I was less than impressed. I cleaned them a couple of times with a 50% concentration of Simple Green and let them soak in traction compound for about 20 minutes before the run. How do others prep a brand new set of VTA tires for their first run (or two, or three, etc)?
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 05-05-2014, 07:08 PM   #6982
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Im just wondering what ROAR rules are you guys using down in FL? From what I understand ROAR only has rules for 21.5 VTA. ROAR does not have any rules for 25.5 motors or even approve any 25.5 motors at this time. So what rules are you guys following if you are using 25.5 motors?
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 05-05-2014, 07:10 PM   #6983
Kevin K's Avatar
The latest sets of tires seem to break in really quickly and dont need much prep work from what I have seen. Now I just run them a few times and they are good to go out of the package. Buggy Grip works good to break in new tires also letting the compound soak long and apply it twice has worked well for me on newer new tires.
Old 05-05-2014, 07:13 PM   #6984
NutDriver's Avatar
Thank you, sir! Greatly appreciated.
I've been using SXT 3.0, if that matters.
USVTA member #111
Old 05-05-2014, 07:16 PM   #6985
theproffesor's Avatar
Trader Rating: 53 (100%+)
First rule of USVTA. You dont talk about USVTA.
His name is robert paulson... his name is robert paulson
All kidding aside I would sincerely like to apollogize for the tone of some of my previous post over the last couple of days. Been in a bad mood and this was onenof the outlets. Thank you to that that gave a little support, and thank you to those that responded to my questions. Some I liked, some just kept fueling the fire. Again, sorry about that, but it was fun wasn't it.
SMC - Motiv - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 05-05-2014, 07:20 PM   #6986
oeoeo327's Avatar
Providing each group their own forum wouldn't squash all dissent. Both sides would still be left with plenty of rules to debate. However, one side attempting to convince the other that their way is the better way tends to be counterproductive.
Old 05-05-2014, 07:21 PM   #6987
Nut, from what the guys at BRR have been saying, dont use simple green. Once I stopped, my tires got alot better. It causes them to balloon out (from what ive been told). I started using electrical contact cleaner, or traction compound to clean them. The simple greennleft a sticky residue on them also. As for as break in time for me it was usually a couple race days worth of heats and practice before the tires came around. I wish my USGT tires broke in that quick. I also store my tires in a ziplock bag with a coat of traction compound on them. This helps to prevent them from drying out.
Old 05-05-2014, 07:23 PM   #6988
NutDriver's Avatar
Thank you, sir. I'd noticed the used sets I've been running getting stickier throughout the day. I'll give your suggestions a shot.
Scott
USVTA member #111
Old 05-05-2014, 07:27 PM   #6989
Kevin K's Avatar
Thats what I run 90% of the time
Lighter fluid works good to clean tires without drying them out it will keep the traction up in the tire. If you use motor spray to clean the tire most times that takes away a little traction cause it tends to dry them out. IMO simple green can do some strange things at times so I stopped using it.
Old 05-05-2014, 07:40 PM   #6990
Suspended
Angry
You know what guys the sad part of this is Florida has some of the fastest
Racers .BUT we will never know WHO IS THE BEST USVTA racer in the state
Until the guys that want to keep changing s#|+ can just make the commitment
And race the class the way is was ment to be raced
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5917 Yesterday 03:44 PM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
