Old 03-13-2014, 11:11 AM   #6511
Okay, so let's back up... I want more info on the differences between the SS and the Ballistic and the Boss.
I have one of each. All completely stock. All legal. I generally run the SS at max timing (because I was told to) and the Ballistic/Boss at the 45 mark.
What is the difference in RPMs between the motors?
What is the difference in Torque between the motors?
Thanks,
.crispy is offline   Reply With Quote
Old 03-13-2014, 11:25 AM   #6512
Travis S's Avatar
Trader Rating: 46 (100%+)
I don't think dropping the timing rule will have a big impact on racing other then giving "most" people one less thing to bitch about. People THINK it will make them soooo much faster then they are currently... It may with some, but I doubt it will with the majority.
I did "most" above because there are a few USVTA Old Timers still running the SS and they may not like the idea... So we could hear some old timers grumble... I do know at least 2 these vta old timers know that max timing is not aways better. Right ? Right Eric???
Travis S is offline   Reply With Quote
Old 03-13-2014, 11:31 AM   #6513
Cgolf's Avatar
Quick question here, newly back in racing, we have a body that fits the vintage year/car type, but it has a wing on it instead of the molded in spoiler. Is this legal/illegal, or depend on the track.
cgolf
Cgolf is offline   Reply With Quote
Old 03-13-2014, 11:35 AM   #6514
Travis S's Avatar
I have one of each. I generally run the SS at max timing (because I was told to) and the Ballistic/Boss at the 45 mark.
Thanks,
Sounds like you are running them all at MAX timing. Even the same motors (ballistic vs another ballistic for example) can and will be be different in RPM/Torque #'s. One factor if a motor has more Torque or higher RPM is the strength of the rotor in it. The higher strength the rotor the more torque but lower RPM. The lower strength the more RPM but lower torque. There is a trade off for both and you try to gear your car to fit that. If you have more torque you can then go up in teeth to make up for the lack of top end. If your motor has more RPM you would go down so you don't lose as much in the infield.
There is a good write up about rotors here: http://www.fantomracing.com/proddeta...?prod=FAN28382
This is just to explain rotors and NO these rotors are not legal and will not work in these motors!
Old 03-13-2014, 11:36 AM   #6515
cgolf
Unless it is the HPI Boss Mustang, the wing would make it illegal for USVTA.
No other legal body has a wing type spoiler.
Also, not all "vintage" bodies are legal for USVTA. Some period correct bodies are not on the "list".
Old 03-13-2014, 12:19 PM   #6516
As a driver..........wind um up, max em out, burn and blow them up, doesn't matter to me. You still have to get around me CLEANLY
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 03-13-2014, 12:24 PM   #6517
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
cgolf
which body are you talking about?? none of the USVTA-approved bodies have a wing, regardless of whether it comes in the packaging out not. The closest body to having a wing is the HPI Boss 302 mustang - it has a little wing-like that is legal..
all the other bodies can have a spoiler added, if its not molded in the body - but that's about it
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-13-2014, 12:25 PM   #6518
k_bojar's Avatar
you also forgot, 'you need to get around me in the corners'
Old 03-13-2014, 01:26 PM   #6519
nashrcracer's Avatar
R/C Tech Charter Subscriber
Did you see me drive at snowbirds. Come on I took out the leader...
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 03-13-2014, 01:47 PM   #6520
snoopyrc's Avatar
cgolf
The thing that catches me in your question is the words "Molded in". There are several lip spoilers that are legal as well as the one small wing that is more cosmetic than functional. As demonstrated on the Mustang in the post above. The big wing that comes in the package with some shells is not legal.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 03-13-2014, 01:49 PM   #6521
Travis S's Avatar
You know because of that takeout an Awesomatix won the race. Causing people to get all pissy and wanting it banned from USVTA... You just don't realize the effect you have in this! Or maybe you do... LOL And that was your plan all along. Very sneaky...
Old 03-13-2014, 02:04 PM   #6522
I like to call that being melvined
Old 03-13-2014, 02:50 PM   #6523
snoopyrc's Avatar
Just in case anyone missed it. The atrocity happens at about 5:32 mark.
+ YouTube Video
Old 03-13-2014, 06:51 PM   #6524
Cgolf's Avatar
The body in question is an HPI Vintage Cuda that sounds like it has a touring car wing included as well as a smaller spoiler. I will pull off the wing and put spoiler on.
Cgolf
Old 03-14-2014, 08:08 AM   #6525
k_bojar's Avatar
Cgolf
this one:
under the rules, you can only run the spoiler - its probably one of the few that HPI makes that includes the wing.
except for the mustang(s), all of the other HPI bodies all have some kind of rear deck spoiler
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5864 01-07-2017 11:00 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
SEO by vBSEO 3.5.0
