Like Tree500Likes
Old 03-03-2014, 08:14 AM   #6376
moparSRT's Avatar
Try it with the battery forward.
moparSRT is offline   Reply With Quote
Old 03-03-2014, 03:40 PM   #6377
nascarkeith's Avatar
Yes, it has a front one way.
Do they make plastic 2.0 toe blocks for a TC4 or do you have to pony up for the aluminum ones?
I also just bought a Spektrum DX3S so that may help. The Fly Sky seems to have a slight lag.
In racing if it goes out of bounds it probably ain't coming back.
SouthviewRC.com
nascarkeith is offline   Reply With Quote
Old 03-03-2014, 07:17 PM   #6378
NutDriver's Avatar
Trader Rating: 19 (100%+)
You have a TC4 that you're running VTA on carpet with a front one-way? I think that I would start with putting ANYTHING in the front and see how you like it (assuming, of course, that you haven't driven it with a spool or diff in the front before). In my experience, I could be MUCH more ham-fisted with spool in the front. I had a hard time developing the finesse needed to drive with a one-way. (your results may vary).
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 03-03-2014, 07:47 PM   #6379
oeoeo327's Avatar
Trader Rating: 72 (100%+)
Originally Posted by nascarkeith View Post
Hello, fellow VTA'ers. I need a little set up advice.
Below are pics of the track and my set up then I will discuss my issues.
The car is very stable and easy to drive. I have plenty of speed and torque. No one passes me on the straights and I have a ton of pull coming out of the turns. Where I get beat is the middle of the corner. I have to turn the wheels pretty sharp to make the corner so it scrubs a ton of speed and pushes to the outside allowing me to get passed on the inside.
The fast guys who are racing me comment on how close my car is. They tell me it needs freed up just a little. I just haven't been able to hit that magic set up. A fast lap is a 9.5 and my best is a 10.0.
So let's hear it. What do you all think?
How are you setting your droop? Are you using setup blocks and setting the droop to 7mm front and rear? If that's the case, I'd think your car doesn't have enough droop, and not transferring enough weight to the front tires once you lift to enter a turn. Try setting the droop to 6mm in the front and 5mm in the rear, and see if that makes a difference.
You could also try adding some drag brake in small increments - with a one-way in the front, your car should initiate turns a lot better since you're using rear brakes exclusively.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 03-03-2014, 08:08 PM   #6380
I like how hard the one way pulls out of the turns. I had wondered about droop. I will add that to my list of things to try.
SouthviewRC.com
Old 03-03-2014, 08:27 PM   #6381
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
You'll need ASC31069, the aluminum one.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 03-03-2014, 08:32 PM   #6382
nf_ekt's Avatar
Trader Rating: 113 (100%+)
It will pull the same with a spool, because on-power, that is basically what a one-way becomes.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 03-04-2014, 07:36 AM   #6383
NutDriver's Avatar
IMO, the spool has more of a push to it than a one way, under acceleration in a turn. Your results may vary.
USVTA member #111
Old 03-04-2014, 08:19 AM   #6384
oeoeo327's Avatar
If you're under constant acceleration, the spool and one way will act identically. However, if you're in a turn and power to the front is disrupted (e.g. over a bump, or the driver lifts to adjust their line), the one way could disengage momentarily and give you a little more steering. Otherwise, both axles should provide excellent steering while on power in a corner.
Old 03-04-2014, 12:39 PM   #6385
Teamhotrods's Avatar
Where do you get a one-way or a spool for a tc4.
I see some tc3 nitro one ways ... Do they fit? Do you cobble together tc5,6 pieces?
Sam
TC4 VTA. RC 10 Gold Pan
2wd SCT. 4wd Rally.
Mugen MBX6 ECO Tekno conversion
Teamhotrods is online now   Reply With Quote
Old 03-04-2014, 12:49 PM   #6386
howardcano's Avatar
Trader Rating: 35 (100%+)
The "Poor Man's Spool": leave the balls out of a ball diff, assemble with a light film of Weldwood contact cement on the faces of the diff rings.
This isn't recommended for diffs using plastic outdrives.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 03-04-2014, 12:59 PM   #6387
Originally Posted by IndyHobbies.com View Post
Here's some photos from last night at Indy RC.
looks like a sweet spot. What kind of chassis are you guys runnin ?
Ive got a TA TC4 im building so i think its going to be good for VTA class.
Saint Hyacinthe RC Circuit
circuitctsh.com
rc-demon is offline   Reply With Quote
Old 03-04-2014, 01:01 PM   #6388
liljohn1064's Avatar
Trader Rating: 17 (100%+)
I ran a one way bearing in place of the front shaft cup. It would disengage the whole front drive off power. For a long time, this was in the rules as not legal and I removed them from my TC3s.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 03-04-2014, 01:07 PM   #6389
snoopyrc's Avatar
I know that my memory is not flawless, but I do not remember that being the case in the national rule set. (USVTA rules) Now I do remember some big races not allowing front one ways, but that was in addition to the USVTA rules. Kind of like lipo sak rules are at some tracks but not in the USVTA rules.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 03-04-2014, 01:36 PM   #6390
NutDriver's Avatar
Another poor man's spool is to take the diff rings out of the stock TC4 ball diff and replace them with TC5 slipper pads. I haven't done it myself (yet. I have the parts), but I'm told that it's very much like a spool, but the slip under heavy load (like hitting the wall, etc while on power) is easier on gears, outdrives, etc.
USVTA member #111
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 6017 11-14-2017 08:49 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
JayL
