Like Tree436Likes
Old 02-26-2014, 04:37 AM   #6316
Originally Posted by NutDriver View Post
While I don't intend to cheat, I would like to get the most out of my motors. I found the motor checker that Eric has in his pics, but it's $250 and Speed Passion doesn't make it anymore. What are the preferred methods of checking/testing motors? Feel free to direct me to another thread if needed. :-)
Scott
These give the same readings as the pictures Eric is showing. http://www3.towerhobbies.com/cgi-bin...&I=LXAGTT&P=ML You can get it for about 1/2 that price if you're willing to order from china and wait a few weeks.
anr211 is offline   Reply With Quote
Old 02-26-2014, 06:45 AM   #6317
DARKSIDE's Avatar
hello....
how was your VTA racing this past weekend?...and where did you race?
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 02-26-2014, 06:56 AM   #6318
NutDriver's Avatar
Trader Rating: 16 (100%+)
Didn't get to race this past weekend, but I will be racing VTA at Bush River Raceway in Columbia, SC THIS weekend!!
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 02-26-2014, 07:00 AM   #6319
snoopyrc's Avatar
Masked on a Challenger shell last night. Might get to spray a little tonight.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 02-26-2014, 07:05 AM   #6320
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by oeoeo327 View Post
This is the LAST thing we'd want. Want proof? Visit the Tamiya TCS and Mini threads to see what "open motor" choices did to the mini class. Choosing one spec motor might seemingly show bias towards one manufacturer, but offers the fairest racing.
Most of the other 25.5s don't appear on the ROAR approval list - why should the USVTA sanction their use if we have no hope of verifying that they offer similar levels of performance between brands?
The Mini chassis has a limited selection of gear ratios that, along with the way the Tamiya rules are currently written, means the motor kV rating is almost the only important number. Even the tallest ratio is way too short for most tracks.
VTA has it much better. Unless you are running under local rules with a restricted FDR, then a small variation in the free-running motor RPM has virtually no effect-- you simply change the gear ratio to compensate.
Yes, the one-brand rule for VTA works very well!
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 02-26-2014, 07:07 AM   #6321
howardcano's Avatar
Originally Posted by edhchoe View Post
If I had to follow the rule where I cannot go over 45 timing I could be 1 or more off to the wrong side and I would be at a disadvantage. Or I could "accidentally" place the sticker to my advantage a couple of degrees.
But where I race there is no restriction on end bell timing so it's not that crucial for me.
Originally Posted by snoopyrc View Post
I had no idea the tolerance was that great. Now I feel like my best chance of having any power is just to set it where it will turn some rpm and then gear it so it has some punch. Over simplified and probably wrong, but it's what I am thinking.
A difference of a couple of degrees in the motor timing might change the free-running RPM, but it has an extremely small effect on output power. Just change the gear ratio to what the track and car require and you're pretty much good to go.
Howard Cano
Old 02-26-2014, 07:22 AM   #6322
DARKSIDE's Avatar
Originally Posted by DARKSIDE View Post
hello....
well I raced at Summit RC in Ft Wayne Indiana in the 2nd RD of the USVTA National Series....Indoor Carpet Nationals!!!!
the racing was a lot of fun and a packed house to boot....lots of fast racers and good atmosphere for any USVTA racer.
I made the A main in GT and VTA, but didn't get that briefcase, so that was Travis and Brian fault...lol
I didn't honestly see one unhappy person all weekend....small issues were taking care of quickly and fairly.
biggest thing was the Rides in GT...any questions?...they work and work well..
also, I didn't have not one person come ask me was such & such "cheating", or thought unfair this and unfair that....maybe Jeremy or Rob did, but nobody said it to me....and that alone made it great, and proves that all the USVTA and USGT rules work when done right with proper tech and eyes
thank you again Rob, 2010 and still going...
Old 02-26-2014, 07:27 AM   #6323
snoopyrc's Avatar
That was such a great post, I am going to forgive you for setting the question up yourself and then quoting yourself to answer it.
Old 02-26-2014, 07:34 AM   #6324
Trader Rating: 71 (100%+)
Markus is online now   Reply With Quote
Old 02-26-2014, 07:46 AM   #6325
IndyHobbies.com's Avatar
hello....
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
Member Hoosier RC Racers club - www.HRCRacers.com
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 02-26-2014, 08:09 AM   #6326
As a side note, I am hooking these motors to a 27t via a flexible coupler, so they are under a load and not free rev'd.
Please keep in mind, anything we use to check anything, is a reference number, track scale, multimeter, etc. What I use is different from what someone else uses so "our" numbers will or may be different. In any case, as long as I/We use the same equipment every time we check something, the relevance of the numbers is correct for the user.
Enough about stickers and RPM's.................. the old faithful VTA chassis is going back together for some fun
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 02-26-2014, 08:28 AM   #6327
Trader Rating: 83 (100%+)
And what would be the tires that are reccomended for high bite carpet? Would those be the same part number or would they be the other only tires allowed in VTA. What about low bite carpet on a cold track in an unheated warehouse. What tires would you use for that? Would those also be the only tires allowed in VTA? Or the other only tires that are allowed in VTA.
Pretty funny, I deserve that. I meant what is the best VTA "style" tire (doesn't need to be legal for racing) that i could use on a Dusty, low bite, asphalt condition.
bigbeej is offline   Reply With Quote
Old 02-26-2014, 08:30 AM   #6328
edhchoe's Avatar
Trader Rating: 41 (100%+)
No argument here that this is the most fun class.
Do you guys sauce full on the front and set up the car around it?
Or set up the car then vary the saucing depending on the track?
edhchoe is offline   Reply With Quote
Old 02-26-2014, 08:43 AM   #6329
oeoeo327's Avatar
Trader Rating: 70 (100%+)
The answer's the same... Of the 3 types of tires that fit the VTA specific wheel, the 4793/4797 combo works best.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
oeoeo327 is offline   Reply With Quote
Old 02-26-2014, 08:48 AM   #6330
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Sure, sure, all our fault! lol
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 6014 10-15-2017 12:37 PM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
