Like Tree236Likes
Old 01-28-2014, 07:23 AM   #6061
snoopyrc's Avatar
Originally Posted by theproffesor View Post
The rs or rs pro will most likely never be allowed in USVTA. Nor will any other ESC tbat csn be taken out of blinky mode or have timing added. I think the question is whether the RS Spec with locked timing will be allowed. They are currently testing it and I am sure we will hear something very soon.
Just about everyone realizes that. The Tekin RS and RS Pro are not on the table for USVTA approval. Talking about it is a dead horse. Only the Tekin RS-Spec is up for consideration.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 01-28-2014, 07:28 AM   #6062
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by nashrcracer View Post
The advantage of a USVTA approved speed control is for the race director and the other racers at the club level. This is so that don't have to worry IF another speed control is not in blinky. It's not an issue of ROAR calling them equal.
I'm late to the discussion, but I think nashrcracer's statement bears repeating, so I made the it bold in the above quote.
USVTA attempts to equalize the performance of the cars, including the ESC and other components.
ROAR does not test ESCs for performance equality. ROAR only tests ESCs to ensure that they have zero timing. There are no requirements or tests for on-resistance or other items that might be an advantage.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 01-28-2014, 07:43 AM   #6063
Any of the pro-Tekin people care to explain how it adds "value" to the series?
And if you're going to say "more people will run VTA" then I'm going call BS.
The infinitesimally small number of new racers to VTA due to new ESC isn't worth the potential issues even if the chances are .01%.
Anything else?
.crispy is offline   Reply With Quote
Old 01-28-2014, 07:53 AM   #6064
Trader Rating: 18 (100%+)
heres my VTA TC 6.1 its only missing the body...hope it goes good with some help from a few local racer it should be set up properly...
Danny
flag72 is offline   Reply With Quote
Old 01-28-2014, 08:04 AM   #6065
DARKSIDE's Avatar
ROAR VTA I assume?...nice cause it is AE..j/k...glad you joining
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
Final On-Road Race
Summit RC Raceway June 17th
Ft. Wayne IN
DARKSIDE is online now   Reply With Quote
Old 01-28-2014, 08:33 AM   #6066
theproffesor's Avatar
Trader Rating: 55 (100%+)
It can add value because if you look at the list a very large number of approved esc are no longer available. This would give racers more choice in an esc. I for one never liked any of the Novak ESC's. I had severe glitching issues and I never liked programming through blinking lights. Thats why I purchased a HW Justock. I like Tekin because of there customer support, so I have a RS Spec that I am running since my local track runs ROAR rules
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 01-28-2014, 09:11 AM   #6067
RussF's Avatar
Trader Rating: 21 (100%+)
Originally Posted by alloyslash View Post
I just got a new HW Justock in yesterday to replace my SP Revention that I killed. After reading over the paperwork I realized that it's functions are very simular to the SP esc.
It comes with the factory defaults set at;
Forward only w/ brake
10% Drag Brake
3.2 LV cutoff
Level 7 punch (out of 9)
75% Max brake force
0% initial brake force
My question is are you guys that are running the HW ESC just plugging and playing, or are you moving the factory defaults around? The only default I see that I might want to change may be the punch control ( from 7 up to 9).
I have the SP "multi esc programming box" that plugs into the esc, has anyone tried to use that on the HW esc since they are so simular, instead of trying to do it by the buttons/lights/tones?
The HW Justock is a very compact esc, comes with a fan already mounted, and has plenty of wire length for the battery and motor connections which is very nice. For $50 I feel I didn't go wrong with the purchase.
Question about this ESC. Is the punch level a similar feature to boost? If this is used for USVTA is this feature off while in Blinky mode?
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 01-28-2014, 09:24 AM   #6068
That's value to YOU. How does it make the series better or stronger?
Old 01-28-2014, 09:39 AM   #6069
alloyslash's Avatar
Trader Rating: 19 (100%+)
NO. All punch is is how much throttle response that the ESC feeds the motor with the initial pull of the trigger. It in no way has anything to do with timing whatsoever, just how much beggining throttle the motor received to begin with. The WOT signal stays the same, timing stays "0".
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 01-28-2014, 09:48 AM   #6070
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to AudioStylz
All speed controls are available still. Just some on that list are no longer available new in package from the company. I don't mind using a used model if it keeps me legal. I think you're also excluding a large number of available speed controls because of a certain feature on most novaks. IMO I think VTA should only allow speed controls with absolutely no program features like the Novak Club Spec. Absolutely nothing to do on that speed control besides set it up with your receiver and go.
It's plenty fast enough to keep up with the best of them. I'm not even using a Ballistic 25.5 or Boss 25.5. Still running the SS Pro 25.5. I like to stick with the KISS system, Keep It Simple Stupid!. Makes it easier to focus on the chassis and my driving. Too many options can make things way more complicated then they need to be.
Mike Zadler
Associated TC3 VTA (RIP 4/23/17)
AudioStylz is offline   Reply With Quote
Old 01-28-2014, 09:49 AM   #6071
Im pretty sure I worded that in way that showed it could add value to the series. More choice from a company that is top rated in quality and customer service, not to mention it supports US jobs and growth as Tekin is a US based company.
The question is, why, when tested by the powers that be, the ESC proves to be on a level field with the rest, would you not want it added to the list?
Edit: If you cant buy it new from the company, to me that means no longer available. That doesn't mean you cant still find some new floating around at an obscure hobby shop somewhere, or get used ones in very good condition. I mean I can still get parts to restore my 77 Beetle, but they arent coming from Volks Wagon.
Old 01-28-2014, 09:55 AM   #6072
AudioStylz's Avatar
I'm all for the Tekin if it can pass the testing and get legal. Being USA made explains the higher cost though. It's listed as the highest price out of all the speed controls currently listed on the USVTA website. Tekin Spec RS at $130 with the Novak 2s Edge 2nd at $115 (according to amain).
I still like the idea of no features period style speed controls. Go back to the days of old where speed controls had very few options. Just you, car setup, and good driving skills.
Mike Zadler
Old 01-28-2014, 10:04 AM   #6073
I live in Quebec Canada.they use basic VTA rules with 21.5 motor and any 2C Batt...
never ran sedan VTA cant whait to get it going...
Old 01-28-2014, 11:08 AM   #6074
wwddww34's Avatar
Trader Rating: 9 (91%+)
They are? Please show me where I can get a used LRP A.i. Brushless Reverse ESC, P/N LRP80100 or LRP80150. I really want to try this ESC in my VTA.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 01-28-2014, 11:21 AM   #6075
AudioStylz's Avatar
Gotta look for them. They are out there on occasion. Check out craigslist or ebay on a daily basis.
Mike Zadler
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 5996 Yesterday 06:50 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
