Like Tree1Likes
Old 12-26-2013, 09:42 PM   #5761
edhchoe's Avatar
Trader Rating: 41 (100%+)
System double post.
edhchoe is offline   Reply With Quote
Old 12-26-2013, 09:45 PM   #5762
edhchoe's Avatar
Originally Posted by edhchoe View Post
Can anyone confirm that the Edge + Boss combo comes with red wire stator?
Yes. Just received the motor and it does have red wire.
Old 12-29-2013, 03:53 PM   #5763
Default 25.5 BOSS MOTOR Problems
Been having problems with the motor stalling and not wanting to run, but with a gentle push it runs fine until you stop or slow and then try to start again. From past experience it sounded like either too much timing or a bad/loose sensor wire. Wasn't too much timing so I switched out the sensor wire with the one that was on the 21.5 that was in the car (when it ran fine) and still had the problem with the BOSS. Narrowed the neutral range in my TX and increased the BOSS timing to the MAX and it improved some but still had the problem. Pulled the senor wire completely out of the ESC and had the same condition but all of the time. So I suspect there is a problem with a sensor in the endbell.
Since I'm trying to make a race next Saturday, is there anything I can do here without having to send the motor back to NOVAK? I'll look for a Novak thread and post there too
Any help will be appreciated.
John Wallace2 is offline   Reply With Quote
Old 12-29-2013, 04:42 PM   #5764
DARKSIDE's Avatar
make sure you DONT over tighten the timing screws on the endbell as this will damage the sensor board .
sometimes you can wiggle the end bell and just snug the screws in and it will work fine
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Indoor Carpet Nationals
Summit RC Raceway www.summitrcraceway.com
1421 Goshen Ave, Fort Wayne, IN 46808
DARKSIDE is offline   Reply With Quote
Old 12-29-2013, 04:42 PM   #5765
mikel33's Avatar
Trader Rating: 2 (75%+)
just buy the sensor board. 5 minute repair.
Michael Larson.
Village Idiot Racing
mikel33 is offline   Reply With Quote
Old 12-29-2013, 04:53 PM   #5766
GP40X's Avatar
If you have another Novak Ballistic motor, you can swap the sensor end end bell and see if that cures your problem. If it does, then chances the sensor board is bad. Be sure to check the end play of the rotor so it is not too tight when you swap end bells.
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 12-29-2013, 05:24 PM   #5767
Thanks all - you were spot on - it is the sensor board. I found a NOVAK thread here on RCTECH & there was lots of discussion about NOVAK sensor board issues. One post said you can check to see if it is the senor board by loosening the endbell scews and if the problem goes away its the senor board. I did and tested it in the driveway before it got totally dark outside and the problem went away, or at least well enough that the car doesn't stop any more and need a push, so I can race Saturady and send the motor back Sunday. Now I have to keep the end bell loose enough to keep it running and tight enough so the timing doesn't change. What fun! Just hope I don't get rained out for a 3rd week in a row here in San Antonio - shouldn't be saying that as much as we need the rain!
Old 12-29-2013, 05:27 PM   #5768
ASM
ASM's Avatar
Trader Rating: 17 (100%+)
I had a very similar sounding problem and it turned out to actually be the sensor cable. A quick change and no issues since.
Scott Meeks
2016 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 12-29-2013, 05:57 PM   #5769
mikel33's Avatar
you just have to be careful not to crank on the screws. You can buy a replacement sensor board without sending it in to Novak. Takes 5 minutes to replace it.
Michael Larson.
Old 12-30-2013, 12:21 AM   #5770
John.. Novak has a 120 day warranty so call them today. You might get lucky and have a replacement one by Saturday. USPS Priority mail is my favorite way of delivery. Calling Amain.com myself at 9:30 am for some VTA 5 spoke black rims cause HobbyTown only had chrome one.
Cant wait for the 4th for some VTA action..hope to see you there.
☆frankie p☆
Mr.75MHz is offline   Reply With Quote
Old 12-30-2013, 02:12 AM   #5771
Yep been there and done that before, that's why I swapped out the sensor cable first with one I knew was good. Unfortunately, it didn' fix the problem.
Like Frank said the motor is under warrantee & I still have the receipt from Tower so I'll just send it back to Novak Sunday after the race and let them fix the thing. From the Novak Thread there are other issues with the Ballistic series of motors, missing or wrong sized spacers causing the bearings to rub on the sensor boards, so while replacing the sensor board is easy, it may not fix the problem.
Old 12-30-2013, 02:37 AM   #5772
☆frankie p☆
Those will be some really expensive black wheels! Not sure I would use USPS as they do not guarantee any specific delivery date (found out that the hard way). Nothing wrong with chrome - I'll bring my chrome Martini Porsche on the HPI 4wd chassis.
Me too & hope we don't get rained out. Wish Al had not reverted back to Saturday racing. He told me he had changed to Sunday racing so I got my Trans Am car ready & thought I had died and gone to heaven; Off road on Saturday and On-road on Sunday (at least until the wife got irritated!). Now I'll have to make some hard choices on where to play.
Old 12-30-2013, 05:00 AM   #5773
godzukihop's Avatar
Trader Rating: 31 (100%+)
☆frankie p☆
I have no problem with AMAIN, I use them a lot also but TQRCRACING has a lot of VTA parts, they ship same day and they are a site advertiser and the prices are very good. Customer service is GREAT!!!
http://www.tqrcracing.com/shop/produ...02&s_maker_id=
JOHN's MOBILE RACEWAY | 180 RACEWAY | Jackson RC Track
Murnan Modified because HP is intoxicating!!! | VP RACE FUEL |
G-FORCE HOBBIES | Fordham Hobbies | ASHFORD HOBBY | TEAM CAMDEN
RC AMERICA / XRAY / HUDY / TEAM POWERS
godzukihop is offline   Reply With Quote
Old 12-31-2013, 02:35 PM   #5774
I have a question on the driver inserts. Amain doesnt have any that I can find, I did a general google search and found some online stores that carry them. How do these fit into your bodies? I not a big fan on any of the designs.... I also saw about 30 pages back ppl saying as long as theres head and shoulders anything goes, so if I wanted I could just put a lego characters top half and place weight lower?
B5M CE
T5M
Tekno SCT410.3
Kbmoss is offline   Reply With Quote
Old 12-31-2013, 02:38 PM   #5775
Trader Rating: 57 (100%+)
No
"ANY suitable 1/10 driver figure is legal-these are readily available examples"
PROMODVETTE is offline   Reply With Quote
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5864 01-07-2017 11:00 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
massenb203, NutDriver
