Like Tree3Likes
Old 12-16-2013, 01:44 PM   #5701
edhchoe's Avatar
Trader Rating: 41 (100%+)
I have to trim down my novak edge brakes. It is too powerful at 100%.
edhchoe is offline   Reply With Quote
Old 12-16-2013, 01:49 PM   #5702
Tommy R's Avatar
Trader Rating: 19 (100%+)
Originally Posted by JayL View Post
kinda confused about all the brake talk
I never use brakes, drag or push, in VTA
Almost never even get all the way out of the throttle except on tight 180's
cars are so slow just turning scrubs enough speed and I run front DCJ's
I can only offer up my own personal experiences, but yes, it's usually possible to race around the track holding WOT the entire time. However, it just scrubs the tires, generates excess heat/stress in the driveline, and I'm usually much faster if I let off the throttle and/or hit the brake where applicable. And we usually race on pretty open tracks. It's not often that I use brakes on the larger layouts, but I've never raced a circuit where I didn't at least let off on a few corners each lap.
Tommy R is offline   Reply With Quote
Old 12-16-2013, 01:51 PM   #5703
DJayhawk's Avatar
Originally Posted by moparSRT View Post
Forget Novak, get a JUSTOCK and a program card all for around $60
Ok, so what motor should i run with that? How about a servo suggestion for a TC4? Also what is a program card?
Thanks guys!
DJayhawk is offline   Reply With Quote
Old 12-16-2013, 01:55 PM   #5704
edhchoe's Avatar
+1 on JayL's comment about not letting out all the way except for 180 hairpins.
That made me faster.
I used to coast with no throttle on some turns but now I give it some throttle on all turns except for the really tight ones.
Old 12-16-2013, 01:58 PM   #5705
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
never had to stop for a slower car in front of you? or a car that had an issue getting back into the racing line? I know I have
I always run brakes - no for drag brakes because you never know when you'll need to stop WITHOUT barreling thru another car
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-16-2013, 02:01 PM   #5706
k_bojar's Avatar
in the last 4 years of running this class, I can count on 1 hand the number of times I ran on a track where it was WOT all the time. every track around here (including a trip to the scale nationals in Wisconsin) has something that requires braking - and it may only be a tap of the brakes, but its more then just letting off the throttle
yes, these were from my personal experiences - but can't ever hurt knowing its there if you need them
Old 12-16-2013, 02:12 PM   #5707
oeoeo327's Avatar
Trader Rating: 70 (100%+)
+1 on both posts... If you're relying on tire scrub to slow you down enough to take corners properly, you're not going as fast as you possibly could be. Can many circuits be lapped @ WOT? Sure, they could - but I never went any faster doing so.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 12-16-2013, 02:46 PM   #5708
moparSRT's Avatar
Thanks guys!
depends on the rules at your local track, if usvta then get a boss novak, its the only legal not discontinued motor. If roar vta then any brand 25.5 is fine, even the $40 Speed Passion is great
I run Associated DS1015 servo's, there bulletproof. If weight/space is a problem then Spektrum S6070
Program Card for setting up your Justock : http://racevta.com/product_info.php?...products_id=92
There is also a more advanced card that lets you hook up your esc with usb and update software: http://racevta.com/product_info.php?products_id=91
moparSRT is offline   Reply With Quote
Old 12-16-2013, 02:56 PM   #5709
GTB 2 low profile + 25.5 Novak Boss with zero brake = a main win 1 weekend & TQ two weeks later for me.. now if only Mr.Tommy R would only show up n letting me see how the Champ does it I might learn something new.
☆frankie p☆
XRay 2013 VTA Firebird Trans Am
CRC1/12 Alter Ego
Mr.75MHz is offline   Reply With Quote
Old 12-16-2013, 03:31 PM   #5710
Tommy R's Avatar
☆frankie p☆
CRC1/12 Alter Ego
LOL! Frankie, I don't think you or anyone else would learn anything new from me!
Old 12-16-2013, 05:20 PM   #5711
How things have changed and also stayed the same. Just got my first set of HPI TRANS AM tires and WOW they are they different than what we used to get. These feel like they might have some traction right out of the bag. The old ones had a hard glaze on them that you had to "wear" off before you had any traction (probably the source of the no tire grinding rule - not that I ever did that ). But its still the same with all the mine's bigger/better than yours discussion. Only now it just ESCs we're debating.
John Wallace2 is offline   Reply With Quote
Old 12-17-2013, 12:24 PM   #5712
Tech Legend
Cain's Avatar
Trader Rating: 219 (100%+)
Originally Posted by PirateRN View Post
Hey all! I just changed from a TC4 Club Racer to the Spec R S1.
I have searched for some VTA setups for the chassis, but keep getting 17.5 or mod results.
Does anyone have any links they could share?
So far, I really like the chassis and my lap times and consistency have improved.
this is the car that is similar to an xray vehicle?
If so, there is a USGT setup that I put on mine that I am really liking, I have an Xray T3 2012.
< Team Associated RC10B6D x 2>
< Tekno SCT410.3 x 2>
< HB Racing D413 x 2>
Old 12-17-2013, 03:02 PM   #5713
JayL's Avatar
So you want one faster than mine?
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 12-17-2013, 06:22 PM   #5714
I have three Spec-Rs, I use an S1 and a R1 for VTA, and another S1 for USGT. I think they're great. I'm competitive with all the guys running the expensive chassis and one of the "good" guys ran my S1 and won the A-main.
So yeah, they're "like an X-ray" only a LOT cheaper...
.crispy is offline   Reply With Quote
Old 12-17-2013, 07:56 PM   #5715
PirateRN's Avatar
Well, Jay, one of these days I will keep up with you. I use all of the advice you nicely share with me. I just like to see other things that I could try.
Thanks for the help everyone. One of these days, I'll travel east for a race.
PirateRN is offline   Reply With Quote
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5864 01-07-2017 11:00 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
Currently Active Users Viewing This Thread: 10 (2 members and 8 guests)
GerryH, roosterreagan
