Like Tree409Likes
Old 11-28-2013, 12:35 PM   #5581
edhchoe's Avatar
Trader Rating: 41 (100%+)
I took all the bearings out and degreased them with brake cleaner. The bearings are dirt and grime free and spin very freely. But when I add the high speed bearing oil made by Yeah racing, the bearings don't spin freely because of the oil. Does anyone run with dry bearings? Should I oil them? Which is faster? Oil or no oil?
edhchoe is offline   Reply With Quote
Old 11-28-2013, 12:44 PM   #5582
oeoeo327's Avatar
Trader Rating: 70 (100%+)
I'd never consider using an unlubricated bearing. Each clean bearing needs only a drop or two of oil, and shouldn't cause the bearings to add any additional resistance.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 11-28-2013, 01:01 PM   #5583
alloyslash's Avatar
Trader Rating: 19 (100%+)
I use the blue Epic oil, very thin and lightweight. After the cleaning I'll put 2 drops in each. Initially it slows the freespin down, but once it has been spun in the bearing for a while they will free back up. On the blue rubber cover bearings Xray uses I'll take a small round file and remove the rubber from the center of the cover before I reinstall it, thus eliminating any possible drag from the cover itself. It also makes it easier to add oil to them between cleanings.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 11-28-2013, 01:04 PM   #5584
edhchoe's Avatar
I will use oil.
So run blue rubber shield on the side facing outside only?
Old 11-29-2013, 08:06 AM   #5585
alloyslash's Avatar
I actually run both sides on my bearings as I believe it helps keep a small amount of lube inside the bearing. After removing the lip of rubber in the center there isn't any chance of the cover causing any resistance ( if re-installed correctly ). There is alot of racers who run their bearings faceless on the inside, nothing wrong with that way either. Its just really what ever way you prefer to do it.
Old 11-29-2013, 08:11 PM   #5586
snoopyrc's Avatar
Originally Posted by ercwhtsd View Post
For some bodies, (HPI 70 Boss for example) you will have to cut back the foam bumper to get a good fit/lineup of the wheel wells.
I didn't have to do that. It was a very snug fit, but I didn't have to trim my bumper. Yokomo SD
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 12-03-2013, 03:29 PM   #5587
Brady_21x's Avatar
Trader Rating: 28 (100%+)
any chance this ESC will be approved?
http://www.amainhobbies.com/product_...-Brushless-ESC
www.FantomRacing.com for all your Motor and Lipo needs!
Brady_21x is offline   Reply With Quote
Old 12-03-2013, 03:38 PM   #5588
moparSRT's Avatar
It meets all usvta esc requirements so should see it on the list soon seeing its now available
moparSRT is offline   Reply With Quote
Old 12-04-2013, 05:22 AM   #5589
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
I will use oil.
I gotta be the only person that runs the bearings as is, including rubber seals and my car is quite competitive as is
I've tried doing all the voodoo to the bearings, but to me, I never saw much of an improvement - so I just stopped...I guess I'm just lazy and that's where that extra .001 i'm always looking for is
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 12-04-2013, 05:34 AM   #5590
oeoeo327's Avatar
I use the Avid metal shielded bearings, available for $1 each. I'll add a drop of light oil to each bearing prior to installation, and replace the bearing once it's on the verge of failure. No voodoo, extra effort, or magic oil required.
Old 12-04-2013, 05:36 AM   #5591
k_bojar's Avatar
avid's are in all of my cars as well for the $$, they are MORE then worth it
Old 12-04-2013, 05:37 AM   #5592
oeoeo327's Avatar
Associated TC6.x VTA racers - quick question for you... If you wanted to gear your car at an FDR of 3.4, what size spur would you use? A local racer is setting up a VTA car, and wanted to know what spurs he'd need. Any help you could provide would be appreciated.
Old 12-04-2013, 02:32 PM   #5593
wwddww34's Avatar
Trader Rating: 9 (91%+)
Assuming all Spur/Pinion gears are 64-Pitch, here are a couple options for gearing the TC6.x:
  1. Spur = 88T; Pinion = 51T; FDR = 3.45
  2. Spur = 88T; Pinion = 52T; FDR = 3.38
  3. Spur = 90T; Pinion = 52T; FDR = 3.46
  4. Spur = 90T; Pinion = 53T; FDR = 3.40
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 12-04-2013, 02:41 PM   #5594
Tommy R's Avatar
Trader Rating: 20 (100%+)
I believe the issue with the TC6.x is that you run into pinion/spur fitment or engagement issues easily. For mine, I'm pretty sure I had to run a 96t spur in order to be geared that tall.
Tommy R is offline   Reply With Quote
Old 12-04-2013, 02:41 PM   #5595
edhchoe's Avatar
So the internal gear ratio is 2.0 for tc6..
FDR= spur/pinion X 2.0
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 6010 09-05-2017 10:53 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
