Like Tree84Likes
Old 09-10-2013, 07:25 AM   #5116
DARKSIDE's Avatar
Originally Posted by DARKSIDE View Post
I figured this would be a good time to update my setup from boxstock, to dang near boxstock, it was good for a couple of tenths on the current Thunder RC layout, home of the SOLD OUT!!!!... USVTA Southern Nationals in Music City USA
hope this might help somebody looking for a good starting point
Cant load ????...anyway, if you need it I can email it to you
mytiibattman@aol.com
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 09-10-2013, 09:06 AM   #5117
RussF's Avatar
Trader Rating: 21 (100%+)
I also run a mostly box stock VTA setup on my TC6.1. I have a few RSD upgrades like 1x1x1.5 pistons and soft bladders. I just changed it from a TC6 to 6.1 by adding the arms, hubs, knuckles, turnbuckles, sway bars, etc.
I do like it but would love to see what you have changed so I emailed you.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 09-10-2013, 09:25 AM   #5118
DARKSIDE's Avatar
email sent...thanks...also have RSD bladders
April 8-9
Old 09-11-2013, 07:08 PM   #5119
Looking for pictures or a how to on putting a usvta approved rear spoiler on a hpi 65 MUSTANG ... anyone using this body make a custom one or by a part for another body.
Thanks.
rescue119 is offline   Reply With Quote
Old 09-11-2013, 08:25 PM   #5120
wwddww34's Avatar
Trader Rating: 9 (91%+)
Thanks.
I usually recycle a rear spoiler from a beat-up HPI Camaro body to use on the HPI Mustang bodies.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 09-12-2013, 04:26 AM   #5121
Just make sure the "chord" length doesn't exceed 20mm!
.crispy is offline   Reply With Quote
Old 09-12-2013, 12:13 PM   #5122
BlueGlowBoy's Avatar
Curious.....has anyone tried going to rear wheel drive, with all the other rules the same? Most cars could just remove the front belt... and the real cars were RWD. I think it would be an interesting thing to try!
RC8.2 | B4.2 | SC104x4
Clockwork Racing Engines - Seeing is Believing
Sponsors - My Kids, My Wife, and My Wallet!
BlueGlowBoy is offline   Reply With Quote
Old 09-12-2013, 12:16 PM   #5123
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Brakes would really suffer, and pull coming out of corners IMO.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 09-12-2013, 01:19 PM   #5124
wwddww34's Avatar
A 4WD car converted to a RWD will always push like a dump truck in every turn. Guaranteed the RWD car will loose a race against a 4WD car.
Old 09-13-2013, 05:32 AM   #5125
howardcano's Avatar
Trader Rating: 35 (100%+)
Yes, it's quite fun! You will need to remove the front belt and drive shafts (since you don't want the diff coupling the front tires together).
Remove all trail braking (drag brake) from the ESC or radio. The car will have much better turn-in, especially if you usually run a very tight or viscous front diff. Conversely, you may pick up some understeer on the corner exit, since the diff won't be pulling the front end around.
You can either set the brakes so the rear doesn't lock up, which also doesn't give much braking, or tap the brakes near the entrance of a corner to get the car sideways to scrub off speed. That takes good reflexes!
Removing the drag from the belt and bearings will gain you a little horsepower and help top speed.
On most tracks, including any with tight, low-speed corners, you'll turn slower times with RWD than with 4WD. But there are a few rare occasions when running RWD will be faster. Running RWD on a big, flowing track with no slow corners (like a 1/8 nitro track, or a big oval) can be an advantage, both from the horsepower gain and because eliminating the front tires scrubbing against each other (from diff drag) will give higher lateral acceleration.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 09-13-2013, 05:11 PM   #5126
gruman28's Avatar
Trader Rating: 16 (100%+)
Quick VTA question..... I burnt my esc up (rookie mistake, lol) and was looking to get a new esc. I was going to get another Novak, but I see the HW Juststock was much cheaper.
Any opinions on if there is much difference between the two?
Chris
gruman28 is offline   Reply With Quote
Old 09-13-2013, 05:15 PM   #5127
bertottius's Avatar
Trader Rating: 17 (100%+)
Any options on if there is much difference between the two?
Chris
I use the Speed Passion and love it. Give it a try you won't be disappointed. I stay away from Novak speedos. Nothing wrong with them. I just prefer others. I've heard good things about the Hobbywing too.
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 09-13-2013, 05:52 PM   #5128
Chris
Justock is a great esc, you will really like it
Rojna is offline   Reply With Quote
Old 09-13-2013, 08:33 PM   #5129
DarthRacer's Avatar
Chris
I recently picked up a Justock to replace my Havok Pro and I like it better so far. I feel it is a little bit faster for me, and you have the ability to program it via PC or LCD card.
For the Sontaran Empire!
Carolinas R/C Track Directory - https://sites.google.com/site/carolinasrctracklocator/
DarthRacer is offline   Reply With Quote
Old 09-14-2013, 12:47 AM   #5130
wwddww34's Avatar
This is PROTOform's new cover photo on Facebook...
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5917 03-22-2017 03:44 PM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
