Like Tree1Likes
Old 04-22-2013, 09:21 PM   #4576
Meradin's Avatar
Trader Rating: 19 (100%+)
Do these have a crawler mode? Sounds like a crawler ESC setting as those guys don't use delay between forward and backwards.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 04-22-2013, 09:38 PM   #4577
Trader Rating: 27 (100%+)
Originally Posted by Tommy R View Post
Well, I just did a test on the bench and I can go from throttle to brake to throttle with no delay whatsoever. I even tried partial throttle and brake positions and had the same results. So is it something that only happens under load?
Here's a thought. My Savox 1257 is a known power hog. Usually when I get this delay it's entering a corner. I wonder if maybe the ESC is browning out when braking and turning simultaneously? I've got a glitch buster. Maybe I'll install that for Sunday's race to see if that helps any....
Yeah try the glitch buster next
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 04-23-2013, 03:11 PM   #4578
JayL's Avatar
Savox are known to cause ESC glitches/power drops
When I first started VTA I thought my esc was doing this, turned out I just wasn't giving enough throttle for the motor rpm to be faster than the corner speed due to the LOW power of the 25.5
MOD: A800 R1 Digital-2 HW G2 4.5T|||VTA: Awesomatix EVO 1.1 Orca VX3 24K |||F1:
Xray X1 2017 HW XR10 StockSpec R1 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 04-23-2013, 03:24 PM   #4579
Tommy R's Avatar
Not sure. We crawlers definitely don't use any kind of delay, that's for sure. But I'm not actively engaging reverse. It's possible that I'm modulating the brakes entering a corner and it's possible that action is making the ESC interpret it as an engagement of reverse. I really don't think that's the case. Usually, when I apply the brakes, I apply them in one motion and then roll off the brakes....not on/off/on/off the brakes. Hopefully that make sense.
Yep, I will. Hopeful that's the issue here.
Yeah, the Savox servos are known to do that. I'll find out this weekend after I install the glitch buster. The issue definitely isn't the lack of power (not that these motors have much power).
Tommy R is offline   Reply With Quote
Old 04-23-2013, 05:30 PM   #4580
Meradin's Avatar
Yup, I know when I have trouble with my esc is it cause I programmed the throttle range wrong on the ESC, have it in the wrong mode, or have bumped my throttle trim on the radio.
Old 04-23-2013, 05:42 PM   #4581
GasGod's Avatar
open up the deadband@neutral
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 04-24-2013, 07:34 PM   #4582
5th wheel's Avatar
Anyone know if tank power lipos are any good?
5th wheel is offline   Reply With Quote
Old 04-25-2013, 08:43 AM   #4583
TT_Vert's Avatar
Trader Rating: 63 (100%+)
Can you tell me what you notice when you have max drive set high? My understanding based on the manual is that it applies throttle quicker. Does that make it more difficult to apply the throttle smoothly?
Dave
Originally Posted by DARKSIDE View Post
AE TC6
Novak GTB2 Xdrive LP max drive no drag brake
Novak Ballastic 25.5 38 deg timming w/ LRP fan
FDR 3.69
Robinson 96 spur
Trinity 52 pinion
AE 35 wt oil front
AE 30 wt oil rear
RSD yellow springs front
RSD teal springs rear
AE 40 wt oil rear gear diff
-1 deg camber F/R
Full sauce rear tires
1/2 sauce front tires
Futaba 9551 servo
RSD sway bar collars F/R
1mm washer in front wheels
5mm ride front
5.5mm ride rear
2mm droop F/R
the rest is manual build setup
TT_Vert is offline   Reply With Quote
Old 04-25-2013, 08:51 AM   #4584
bertottius's Avatar
Trader Rating: 17 (100%+)
Default ESC
Anybody using he Speedpassion Reventon Stock Club ESC in VTA?
CHRIS BERTOTTI
www.teamirsrc.com
bodiesbybean.com
bertottius is offline   Reply With Quote
Old 04-25-2013, 12:57 PM   #4585
Default ride height adjustment
going from carpet to asphalt should i change my ride height from vta rules min height of 5mm to higher height to keep the chassis from rubbing the asphalt ?
bigtee is offline   Reply With Quote
Old 04-25-2013, 12:59 PM   #4586
mkiiina's Avatar
Trader Rating: 69 (100%+)
Unless you are running on concrete or a very well prepared surface, yes i would raise it up.
mkiiina is offline   Reply With Quote
Old 04-25-2013, 01:00 PM   #4587
Tommy R's Avatar
I run 5mm on asphalt, but don't have issues with rubbing the chassis or body. Although, be aware there may be bumps or dips on the track that may require a ride height change.
Old 04-25-2013, 01:57 PM   #4588
IndyHobbies.com's Avatar
If you are concerned about the bottom of your chassis getting all scratched up, you can put hockey stick tape on it too. You can buy it at some hobby shops. Its the stuff the boat guys use to seal their hatches. Its good stuff. Really thick and transparent. Some sporting goods stores carry it too if hockey is played in your area. It does add a little weight since its thick. Not enough to matter most of the time, but if you are die hard about staying at 1500 grams...
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 04-28-2013, 11:51 PM   #4589
wwddww34's Avatar
Trader Rating: 9 (91%+)
+1. Thanks for the pointer IndyHobbies. I am going to buy a roll.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 04-29-2013, 06:39 AM   #4590
Trader Rating: 39 (100%+)
I would be warry of hockey style take as it can easily peel back. I use the Jconcepts Chassis protector sheets. very sticky does come off if you want it to but is thick enough to keep a carbon fiber chassis in perfect condition while running over stuff outside. Also run 6mm ride height for good flat surface but I have gone up to 8mm with no issues in the slower classes. the faster you go the more you can traction roll with a higher ride height
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5864 01-07-2017 11:00 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
