Like Tree502Likes
Old 03-26-2013, 10:53 AM   #4471
Just remember that some drivers are smoother than others. Check your lap times and motor temps and go from there.
chuck
mackin is offline   Reply With Quote
Old 03-26-2013, 11:57 AM   #4472
Tommy R's Avatar
Trader Rating: 20 (100%+)
Originally Posted by beemerfan View Post
I experimented with this last year during the ROAR Nats in Joliet, IL. after watching another car find some new speed by doing the same thing. The track layout made the straight away roughly 180 feet. I compared 2.98:1 at the stock 30 degrees of timing to 3:27:1 at 45 degrees. The numbers are to the best of my recollection because I lost my notes. The lap times were about the same but I remember the motor being slightly cooler, maybe 5 degrees with the 2.98 and stock timing. The temps stayed under 130 either way using a fan. Ultimately, I ran with the higher timing and shorter ratio because the car just felt better to me. Could just have been a "mental" thing too.
Originally Posted by Shawn68z View Post
I have been playing with gearing and motor timing a lot lately too. And sometimes having the power from the motor at the right time is everything. I have been setting my cars up with higher FDR (lower Rollout), so I can get better acceleration out of the corners and make my passes on the infield. I just make sure that I don't go so low that the cars are able to pass me back again on the straight.
Shawn.
Thanks, fellas! Just the kind of info. I'm looking for. I'm currently finding that my infield speed is rather good, but I'm getting pulled too hard down the straight. Sounds like it may not be as uncommon as I'd thought to run real tall gearing. Time to step it up!
Tommy R is offline   Reply With Quote
Old 03-26-2013, 04:15 PM   #4473
alloyslash's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Tommy R View Post
What's the tallest gear some of you have run on more open layouts? So far I've run as tall as 3.62, but I may need to step it up a bit. I always monitor my motor temps, but I'm just curious....how high have you geared your motor before it's either got too hot or maybe become too sluggish?
Would there be a potential benefit to running less timing (presumably more torque, right?) when running a taller gear?
I rarely run 45* timing, did when I 1st started but now I generally run mine at 37* and taller gears on the big track ( 100'x48'? ). My laptimes got better and I don't get " pulled " anywhere on the track now. I'll run at around 30* on the small track and again, taller gear than most people thats cranked up. Works for me and my driving habbits
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 03-28-2013, 04:19 AM   #4474
bertottius's Avatar
Default TC4
Looking to buy a used tc4 roller or one with a VTA setup if anybody has one.
CHRIS BERTOTTI
Alpha Pace Racing
bertottius is offline   Reply With Quote
Old 03-28-2013, 10:29 AM   #4475
IndyHobbies.com's Avatar
There are 5 or 6 of them on eBay right now I noticed last night. Just search "Associated TC4" and click the "used" box.
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
Member Hoosier RC Racers club - www.HRCRacers.com
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 03-28-2013, 10:50 AM   #4476
Don't tell him that. Tell him he wants to buy mine Scott...
.crispy is offline   Reply With Quote
Old 03-28-2013, 11:16 AM   #4477
But Crispy's is the BEST DARN ASSOCIATED TC4 THIS SIDE OF THE MISSISSIPPI RIVER SO I WOULDN'T EVEN CONSIDER LOOKING ON EBAY!!!!!
(How did I do Gary?)
USVTA #144
Old 03-28-2013, 11:53 AM   #4478
You could also have mentioned that Indy RC Racer said it was better than his!
Now I'm down to one TC4. Makes me sad. But I'm gonna keep the other as my "Arrive and drive" VTA car for friends and family. Nobody would pay what I have in it.
Old 03-28-2013, 07:17 PM   #4479
5th wheel's Avatar
I can't get the drag break to do anything on my Novak edge it set to 10 that's 100%and still looks like its not slowing down at all.
5th wheel is offline   Reply With Quote
Old 03-28-2013, 07:45 PM   #4480
nashrcracer's Avatar
R/C Tech Charter Subscriber
just getting a chance to post from Sunday racing. took my Ballistic and GTB2 powered Xray T3r FTW usvta style over Eric Gellispe by a lap with battery by EA Motorsports
https://www.youtube.com/watch?featur...&v=Kiodrplh_Cg
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 03-28-2013, 08:13 PM   #4481
beemerfan's Avatar
Trader Rating: 34 (100%+)
Was that your car sitting upside down about half way through? Curious what you ran for motor timing and gear ratio in that race? If you don't want Eric to know, please PM me.
beemerfan is offline   Reply With Quote
Old 03-28-2013, 09:33 PM   #4482
I tapped a couple times and rolled it twice. I was the white yellow blue car that comes by the camera in the first second eric was the white car.
if everybody is just as fast as everybody else then it all comes down to driver
and that's what it's all about....
3.36 and about 37 degrees
Old 03-29-2013, 12:01 AM   #4483
beemerfan's Avatar
Actually, the max setting of 10 is only 30% of your full braking force. You don't see or feel much braking but it is there slowing the car enough for the turns. I don't think Novak designs their drag brake to replace actual braking like you'll see a lot of guys do with some programmable speed controls setting it at 50% or more.
Old 03-30-2013, 11:55 AM   #4484
IndyRC_Racer's Avatar
I decided to try a different battery last night in VTA to see how it performed. I had a spare Orion 4000 Rocket stick pack lipo with Dean's plugs (25c).
Since I'm running a tub chassis TC4, the first benefit was the battery was lighter. I actually had to add a bit of weight to get to 1550 grams. While I don't mind running a heavy car (handles side by side contact better), it is always nice to be able to put the weight were you want/need it.
I have several 5000 mah 40c batteries, but the Orion 4000 has the fewest cycles on it (less than 50). As far as on track performance I was able to run consistant laps for the entire run with very little drop off at the end.
I'm certainly not saying that this is a superior battery, but I was surprised at how well it performed for me. I might have to look into getting a good shorty pack to help shave some weight off my FT TC4 car - since it weighs over 1600 grams in race configuration (GTB with full size servo).
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 03-30-2013, 02:11 PM   #4485
I have an almost new 4400mah shorty in that TC4 of mine that you drove. You can run that next week.
With less weight and a good battery you can win by an even larger margin.
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 6017 11-14-2017 08:49 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
glennhl
