Old 03-21-2013, 01:23 PM   #4426
NutDriver's Avatar
Trader Rating: 14 (100%+)
@TommyR, thinking back to the days folks in this area ran 1/8th scale on road, the 4wd BMTs used to have a 10mm split in diameter between the front and rear. I don't recall 100%, but I believe that the car was "overdriven" (tires spun faster at a given rpm) to the front. As the front tires wore more quickly than the rears (generally), the car would "lose" front drive and the car would become more like a 2wd car. I remember him changing front/rear splits regularly to adjust handling. Keep in mind that 1/8th was with a oneway front and a spool rear.
With a TC3/4, I don't know of a way to adjust the drive ratio. Maybe the belt drive cars can do this. Could this be a tuning option in VTA? Seems like more "work" than "Fun" to me.
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 03-21-2013, 01:52 PM   #4427
theproffesor's Avatar
Trader Rating: 45 (100%+)
Sorry double post
Tamiya 419x
Tamiya TA07
Tamiya M05
SMC - Fantom - Motiv - Savox - Spectrum - Exotek.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 03-21-2013, 03:43 PM   #4428
robk's Avatar
Trader Rating: 22 (100%+)
You can split the belt cars. The Losi sedans had this option with different pulleys. That being said, it was mostly a foam tire thing, and not often used.
Old 03-21-2013, 07:06 PM   #4429
Pit-racer's Avatar
Whats the secret on gluing these tires? The outer bead has more glue going on my fingers than the rims.
www.igthobbies.com / Serpent Cobra GT / 748 TQ / Serpent Eryx 3.0 / Desoto Racing / Veytrex.com / JZRacing / Flo-Control
Pit-racer is offline   Reply With Quote
Old 03-21-2013, 07:10 PM   #4430
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Originally Posted by DARKSIDE View Post
new tires are faster..imo
IMO tires with 1 run on them are the fastest or was it 2
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 03-21-2013, 07:49 PM   #4431
I get the tires completely on the rims. Then with the tire laying flat on my work surface in front of me I press down on the tire at the 9 o'clock position with my left thumb and I have the glue bottle (with long tip) in my right hand squeezing glue in the gap.
Squeeze until I can see glue in there. I use medium so it doesn't set too fast.
Work my way around in a clockwise direction. Glue never touches my hands.
.crispy is offline   Reply With Quote
Old 03-21-2013, 07:59 PM   #4432
IndyRC_Racer's Avatar
Last week I gathered FDR information for everyone running VTA at Indy RC Raceway in Indianapolis (Beech Grove, IN). Average fast laps are usually around 10 seconds at our track (It was around 9.5 seconds last week). I didn't record timing (had to let everyone keep something secret). The car who qualified 2nd ended up winning the main.
QUAL|FDR|LAPS|YEAR|CHASSIS
01 | 3.71 | 33/5:04 | 2007 | TAMIYA TA-05R
02 | 4.10 | 33/5:08 | 1999 | AE TC3 (with aftermarket carbon fiber chassis)
03 | 3.68 | 33/5:08 | 2010 | AE TC6
04 | 3.75 | 33/5:08 | 2004 | AE TC4
05 | 3.92 | 33/5:09 | 2009 | XRAY T2-09
06 | 4.04 | 32/5:00 | 2011 | TAMIYA 417-X
07 | 3.64 | 32/5:01 | 2011 | XRAY T3-11
08 | 3.89 | 32/5:03 | 2007 | XRAY T2-07
09 | 3.72 | 32/5:07 | 2012 | SPEC R
10 | 3.79 | 31/5:07 | 1999 | AE TC3
11 | 3.75 | 30/5:03 | 2004 | AE TC4
12 | 3.82 | 30/5:04 | 2004 | AE TC4
13 | 3.80 | 29/5:04 | 2012 | SERPENT s411 SPORT
14 | 3.50 | 28/5:00 | 2007 | AE TC5
15 | 3.94 | 28/5:01 | 2010 | AE TC6
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 03-21-2013, 10:54 PM   #4433
AudioStylz's Avatar
Trader Rating: 15 (100%+)
Send a message via AIM to AudioStylz
That's a bit of cool information right there! Especially looking at the FDR's and how no one is running the exact same FDR.
Mike Zadler
Associated TC3 VTA & TC6 USGT
Tamiya M-05
AudioStylz is offline   Reply With Quote
Old 03-21-2013, 10:57 PM   #4434
BrianVTRMiller's Avatar
If any of you guys are planning to run the Vaterra V100-S in this class, like the '69 Camaro, drop me a line.
Thanks,
-Brian
Horizon Hobby - http://www.vaterrarc.com - Vaterra
BrianVTRMiller is offline   Reply With Quote
Old 03-22-2013, 10:43 AM   #4435
SS LS1's Avatar
Trader Rating: 23 (100%+)
Exactly, the differences in car setup, driving style and Novak motor variances means there its no magic FDR for VTA racing on the same track. You must do the testing and spend the money on gears to find the best FDR for your particular car. New guys always ask what gear they should buy for their VTA car. I suggest a safe FDR and tell them it is a starting point only and to experiment from there if they want to be on pace. Some listen some don't unfortunately.
Question on the data above........... Indy, how many of your VTA racers were using cooling fans and what FDR were they running? That might also be interesting to know.
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 03-22-2013, 11:12 AM   #4436
Top 9 finishers are within one lap or less of leader which is no small feat in itself in normal rc racing, add to that fact there were 9 different chassis combinations in that top 9. Out of the total 15 racers there are 11 different chassis. Speaks volumes for the rule setup that has evolved within the VTA and how well it works for parity between low dollar/high dollar budgets.
Legend00 is offline   Reply With Quote
Old 03-22-2013, 11:51 PM   #4437
Actually there were 10 different chassis combos in the top 10. The top TC3 has a aftermarket carbon fiber top deck/bottom chassis and has a shorter wheel base. Enough differences to consider it a different model.
Many of the people at our track are running fans in VTA. I've run a TC4 with a large heat sink and no fan and have qualified near the top in the past. Difference in motor temps at our track with/without a fan are usually around 10 degrees. Regardless, if you are getting a motor without a fan over 150 degrees at our track, your car isn't working well.
Old 03-24-2013, 07:12 PM   #4438
Suspended
Hey guys sorry been MIA for a bit this thing called work/Job is starting to get in the way of my hobbie lmao
Sooo what's new in VTA land ???
Any news on new stuff ???
Old 03-24-2013, 07:25 PM   #4439
wwddww34's Avatar
Trader Rating: 9 (91%+)
Here's some new stuff...
My LHS has stocked a couple of these fully RTR 1969 Camaros made by Vaterra. It's similar to the HPI Sprint 2 RTR Camaro, only it costs less. Also the Vaterra is a shaft driven car, not belt driven like the Sprint 2.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 03-24-2013, 07:32 PM   #4440
Suspended
Wow that's kool
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5864 01-07-2017 11:00 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
SEO by vBSEO 3.5.0
