Like Tree13Likes
Old 03-05-2013, 07:50 PM   #4261
Marv's Avatar
Own a piece of history =
http://www.canepacollection.com/deta...d-5117023.html
Marv is offline   Reply With Quote
Old 03-06-2013, 05:57 AM   #4262
DARKSIDE's Avatar
Originally Posted by Marv View Post
my junk just moved...whew..glad too....lol
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Scale Nationals
Windy City RC in Arlington Heights IL
April 8-9
DARKSIDE is offline   Reply With Quote
Old 03-06-2013, 02:46 PM   #4263
Marv's Avatar
Mila Kunis...
Old 03-06-2013, 05:40 PM   #4264
GP40X's Avatar
Mila Kunis...
Summer Glau...
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 03-08-2013, 02:43 PM   #4265
Tommy R's Avatar
Trader Rating: 19 (100%+)
Hey guys, regarding this rule:
Ride Height Specification:
Minimum ride height is 5mm.
I just saw in the VTA picture thread that this applies to the chassis ride height AND the body ride height. Is this true? If so, why would the body ride height be restricted?
Tommy R is offline   Reply With Quote
Old 03-08-2013, 03:00 PM   #4266
Marv's Avatar
Not to worry -
Mila Kunis does meet the minimum ride height specs!
Old 03-08-2013, 03:06 PM   #4267
beemerfan's Avatar
Trader Rating: 34 (100%+)
A minimum ride height rule is just that. Every part of the car must have a minimum of 5mm clearance, body and all. The "wand" method is a very good way to check.
beemerfan is offline   Reply With Quote
Old 03-08-2013, 03:12 PM   #4268
DARKSIDE's Avatar
Ive seen it done 2 ways in tech...
1. body on after weight, with the rod to check for complete ride height
2. no body and just chassis with a RHG, for front side and rear ride height
April 8-9
Old 03-08-2013, 04:14 PM   #4269
alloyslash's Avatar
Most of the time if the body is any lower than the chassis it will drag in the turns. I sit my car on my pitboard with the body pins on and the wheels off, chassis flat on the board. Then I lay a sharpie on its side and drag it around the body. That makes a good cutline that won't be too high, but won't drag either.
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 03-08-2013, 04:14 PM   #4270
Why isn't VTA 2wd?
I just ask because I've never seen 4wd Mustangs or trans am's, etc.
Sean B. is offline   Reply With Quote
Old 03-08-2013, 04:18 PM   #4271
alloyslash's Avatar
I think its because it was originally thought up to be able to use the older TC chassis that was a few years old and out of date to this year's chassis designs.
Old 03-08-2013, 07:26 PM   #4272
One way I do it is with body and car in race trim, standard sharpie all the way around, trim just over the line and it gets you just over 5mm.
Same premis,just different.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 03-08-2013, 10:31 PM   #4273
Marv's Avatar
Doesn't that kind of negate the USVTA "Body must be trimmed at body trim lines" rule?
(that is currently still in place at this posting)
Just askin'
Old 03-09-2013, 03:15 AM   #4274
alloyslash's Avatar
Just askin'
That rule means that the body must be trimmed at the trimline. it is in place so no one tries to trim it "long" to keep air from getting under the body. It is legal to initially cut it at the trimlines, pin it on the car and trace around it to take care of any possible scrubbing issues, basically just making sure its square with the edge of the chassis. That trick is primarally used when fitting TC bodies, due to the way they are molded long at the bottom for fitment.
I have run XRay T2, T3, and T4 platforms in VTA so far. With every one of them the suspension " uptravel " will prevent any lowering of the body because the front tires will hit the fenderwells.
Old 03-09-2013, 10:17 AM   #4275
IndyHobbies.com's Avatar
Originally Posted by Sean B. View Post
Why isn't VTA 2wd?
And, you've probably never seen ELECTRIC Mustangs or Trans Am's either.
(...although, the current Administration may try to change that. )
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5870 02-22-2017 09:31 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
