Old 02-15-2013, 08:23 PM   #4141
Originally Posted by ercwhtsd View Post
One of these random thoughts that occasionaly pops into my head.
How many of us use the information provided to us after a run to evaluate our overall performance, car and driver?
Fast lap vs Last Lap over the course of a run in regards to battery performance and gearing/timing?
Motor Temp vs gearing/timing, I know we all look at this, but have you factored in the voltage of the battery after your run and how much we are putting back?
Heat race gearing vs 8 minute main gearing?? How many change gearing for each?
The car whose tires are "squerking" vs the faster car that doesn't make a sound in the corner?
Is your car a touch "pushy" loose in the front side of the run and get better later, or is it on rails up front and tighten up and slow down later?
I know we have all experienced a "soft feel" to the car somewhere in the run, but have you used the above to help diagnose the issue, or just adressed gearing timing?
On our current layout, I will typically use around 950 mah on a 6 minute run and about 1200 on an 8 minute run, with battery voltage at 8.1V after 6 and 8v after 8.
Just a random question to think about
Sounds like the stuff we did in the 80's where we geared are cars to last 4 minutes, no hot laps and nobody was woried about motor temps, just runtime.
Any VTA should easily run 20+ minuts on a 5000 lipo.
drop it and drive it like you stole it
Rojna is offline   Reply With Quote
Old 02-15-2013, 08:31 PM   #4142
Originally Posted by nashrcracer View Post
people like you take the spirit out of VTA just throw it down and drive it!
Originally Posted by SoAzRC View Post
Yep... my thoughts exactly. I work on it on the bench and tweak in practice, but for the most part it's all about the racin'.
:-) couldn't tell ya the last time I worked on mine.
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 02-15-2013, 09:32 PM   #4143
oeoeo327's Avatar
Trader Rating: 70 (100%+)
I'll run this class from time to time because I've chosen NOT to think about any of the points mentioned above. If I want to address the "finer points" of R/C racing, I'll direct that energy towards a class that makes me want to pull my hair out by day's end...
VTA - build it and tweak it, then drive it and forget it.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 02-15-2013, 10:39 PM   #4144
nashrcracer's Avatar
R/C Tech Charter Subscriber
everybody was giving me a hard time about running VTA at snowbirds but I was like I'm running 4 classes I figured I could top 3 in vta even if I never touched the car which is what I did.
VTA charge dope drive laugh charge dope drive cut up charge dope drive smile
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 02-16-2013, 02:06 AM   #4145
LasagnaCat's Avatar
Trader Rating: 137 (100%+)
Send a message via AIM to LasagnaCat
Not really, they both are adjustable though to get the feeling you want. IMO, hobbywing based products have a smoother/"spongy" feel on the brake side. It may just be me though.
We owned two... I'm still not convinced that they had actual working brakes.
Dumped them and went back to Novak esc's and the brakes were much better. That's assuming you actually NEED brake, my other half apparently does not.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 02-17-2013, 06:50 PM   #4146
Default HPI 1970 Mustang Boss 302 Body (200mm)
First off, no it isn't a question about the wing
If anyone has run this body on an Xray T3 2011, did you have to cut the front bumper? I ask because I do and I did have to cut the bumper so that the wheel wells would fall in the right place. I was just wondering if anyone had an alternative solution.
Thanks!
CajunJoe is offline   Reply With Quote
Old 02-17-2013, 07:47 PM   #4147
I'm running it on a Spec-R S1 and I had to trim the foam bumper about 1/4". Not hard to do with an exacto.
Andy
Subaru Brat - Sand Scorcher - Rising Storm - Wild Willy II - 1967 Beetle - F350 High Lift - Stampede - Rustler - XXX-SCT - Micro Baja - XX-CR - SC10RS - B4.1FT - S1
Drive what you want. Bash when you can, race to win , but do it all while having fun.
Jeckler is offline   Reply With Quote
Old 02-21-2013, 05:24 AM   #4148
Hello everyone I'm new to vta, ill be running a xray t2 09. My question is I'm big ford person. So I have a mustang body of course also I have a lotus consul(cortina) body I want to run in vta. They made these cars in 64 and raced I the US in late 60's in the trans series but ran in the slower class in the series. So it this body legal since it did race in trans am series or not legal because its not iconic American muscle cars? Thanks for the help.
Rebelracer568 is offline   Reply With Quote
Old 02-21-2013, 06:04 AM   #4149
beemerfan's Avatar
Trader Rating: 34 (100%+)
It's not legal because it's not on this list.
http://www.usvintagetransam.com/rules/index.html
It's up to your local club or race director if they want to make an exception like some do for the old Stingray body.
beemerfan is offline   Reply With Quote
Old 02-21-2013, 06:26 AM   #4150
You can run it, but you have to run at 75% throttle.
Don't worry, you'll win the U-2 class...
[/humor]
.crispy is offline   Reply With Quote
Old 02-21-2013, 06:27 AM   #4151
I figured as much, thought I'd ask and see. I read rules And made sure I got bodies that were legal. I just love the cortina cars and wanted to use it. I guess it will be a practice body for me. Thank you
Old 02-21-2013, 06:29 AM   #4152
[/humor]
75% throttle I can handle that lol means I may not wreck as much considering I'm new to this series but not new to road racing lol
Old 02-21-2013, 09:50 AM   #4153
DarthRacer's Avatar
After reading this thread and the TC4 thread I thought the TC4 was supposed to be a real pig of a TC. I measured the race ready weight of my TC4 and it was underweight by 20oz!!!
DarthRacer is offline   Reply With Quote
Old 02-21-2013, 10:05 AM   #4154
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
The latest justock software - "508_NO_TIMING" fixes the brakes. By default, they are set to only 75% strength - use the program box or the blinken lights to turn it up to 100%. Swap out the single cap it comes with, to the optional two capacitor kit ($8 bucks) as well. Do all that, and you can lock up the wheels. It's pretty sweet.
I race at www.mncarpetoval.com !
cdwilliams1 is offline   Reply With Quote
Old 02-21-2013, 10:08 AM   #4155
out of the box mine had all the brakes I will ever need.
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5864 01-07-2017 11:00 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
SEO by vBSEO 3.5.0
