Like Tree309Likes
Old 02-06-2013, 05:06 PM   #4066
Looks fine!
DLS II is offline   Reply With Quote
Old 02-06-2013, 08:33 PM   #4067
tajar66's Avatar
Default Help Me PLEASE! Gearing
OK I am attempting to set up a TC4 for the VTA races. I am having a heck of a time with gearing. I am attempting to get to the 3.5 - 4.0 FRD neighborhood. From what I hear most of the peeps at my local track are in the 3.5 area. I know about the various calculators and have been using them. My problem is getting gear that will actually fit in the space and mesh properly. I started with a 49T spur 48pitch and 31T Pinion 3.9 FDR not enough adjustment to get the pinion and spur to touch, about an 1/8th" short. My next try was going to be 60T Spur and 39T Pinion. for a 3.8 FDR I just checked the 39T pinion and the gear is too big and hitting the chassis. Looks like I can alter the chassis with a dremel, but before I do that I figured I would turn to the interweb to see if I can get some help.
tajar66 is offline   Reply With Quote
Old 02-06-2013, 09:02 PM   #4068
rctoyguy's Avatar
Trader Rating: 21 (100%+)
Go to 64pitch gears - it will save you a lot of time/trouble, allow finer adjustments, and run quieter/smoother.
Jeff
rctoyguy is offline   Reply With Quote
Old 02-06-2013, 09:25 PM   #4069
IndyRC_Racer's Avatar
Gearing on a TC4...If you can find a FT TC4 (double deck carbon fibre car), you won't have to dremel under the pinion. If you are running a tub TC3/4, you will have to dremel under the pinion. It doesn't affect the handling of the car.
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 02-06-2013, 09:37 PM   #4070
tajar66's Avatar
If I change to 64 pitch I will still have the same problem. The diameter of the actual gear will be the same as 48p (or close to it). I am not opposed to changing to 64p I was thinking the 48p would be more forgiving to improper gear mesh.
Old 02-06-2013, 09:40 PM   #4071
tajar66's Avatar
Thanks Indy It doesn't look like I need to remove much material to get the clearance, until I start gearing up if needed.
Old 02-07-2013, 06:38 AM   #4072
Default Driver Figures
Here are some of the newer driver figure inserts that are becoming available for those that may not know.
http://www.teamassociated.com/cars_a...s_accessories/
http://www.hpiracing.com/products/en/107371/
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 02-07-2013, 06:50 AM   #4073
tajar66's Avatar
Default Tire gluing question
I am new at on road and sure to have many more questions I appreciate all the help. OK I know to glue the tire on the bead my question is do you glue the small flap the comes over the tire as well? I did a search and it seems some do and some don't, is there benefits either way?
Old 02-07-2013, 06:50 AM   #4074
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default TC4 Gearing...
Hello,
Getting the correct ratio on the TC4 can be a bit of a challenge.
48 pitch will be fine, 64 pitch is better but not manditory. I use the robinson racing 52T spur gear (White) and this allows me to install a 33 - 40 tooth pinion into the car netting a gear ratio range of 3.93 - 3.25 FDR. You will have to grind some of the chassis webing out below where the Pinion gear will set otherwise a 35 or larger pinion will rub on the webing.
If you need a larger gear ratio (Higher number) You can go with the 66 tooth spur gear and get up to a 34 or 35 tooth or smaller pinion giving you 4.0+ FDR ratios.
I like right around 3.8 - 3.7 ratio range for most track other than really large ones with my VTA car.
Hope this helps!
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 02-07-2013, 08:11 AM   #4075
tajar66's Avatar
Originally Posted by JFuel11 View Post
Hello,
Hope this helps!
Thank JFuel11,
That is exactly what I was looking for. RCTECH is awesome for help everyone here ROCKS!!
Old 02-07-2013, 08:30 AM   #4076
Marv's Avatar
The OEM tires come on the Sprint 2 from HPI do have the flaps glued...
Marv is offline   Reply With Quote
Old 02-07-2013, 10:36 AM   #4077
SS LS1's Avatar
Trader Rating: 23 (100%+)
Glue the flaps, less squirm of the tire tread and helps to keep from the flap grabbing the track and causing a traction roll
Tamiya 417v7 Sedan, ___ Tamiya 417v7 USGT, ___ CEFEX EVO w/ 417 suspension VTA
Exotex TA06 Pro CS Drifting, ___ Tamiya 417v5 (sold)
AE SC10 4x4
AE SC10 AE B4.11
SS LS1 is offline   Reply With Quote
Old 02-07-2013, 10:44 AM   #4078
I run robinson 60t 48p spurs on my TC3 & TC4, yes you need to remove some plastic under the pinion.
Rojna is offline   Reply With Quote
Old 02-07-2013, 12:37 PM   #4079
Meradin's Avatar
Trader Rating: 19 (100%+)
Tommy, over in the paint thread asked how people are mounting their drivers and I mentioned there and a while back I would share my technique.
I used some scrap lexan to fold some brackets to hold my figure in the proper place when the body is on. I wanted to mount the figure to the chassis so I wouldn't have to switch him back and forth when I changed bodies.
There are two brackets. One long one in an upside down "u" shape that is servo tapped to the receiver then then up to the figure and then towards the back of the driver to the top deck where it is again attached with tape. I added another one that goes down the back of the driver to the chassis under the motor to help keep him still. The first one was enough but he wobbled around a bit so I added the other one.
The driver is from the double HPI set for their desert truck I think. My brother has the other one. Mounting it this way lets me position the driver where I think he looks best in the car.
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 02-07-2013, 08:08 PM   #4080
Ready for battle
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 6004 08-07-2017 07:09 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
