Like Tree13Likes
Old 02-05-2013, 04:58 AM   #4051
howardcano's Avatar
Trader Rating: 35 (100%+)
Originally Posted by cdwilliams1 View Post
This is what we do with VTA cars on oval night :-)
https://www.youtube.com/watch?v=547UwkAj5Uk
That's hilarious! The Brits would probably call it "Roundabout Racing".
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 02-05-2013, 10:05 AM   #4052
SNOWBIRDS A Main Action
Rojna is offline   Reply With Quote
Old 02-05-2013, 11:36 AM   #4053
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
Originally Posted by Rodarbal View Post
FUN! Do y'all run any weeknights? I'll have to stop out next time I'm in town. Not sure if I'd want to take that marshal position in the donut... I'd get DIZZY!
Saturday Oval nights only for flagpole. Actual VTA runs on Wednesdays and Sundays :-)
I race at www.mncarpetoval.com !
cdwilliams1 is offline   Reply With Quote
Old 02-05-2013, 02:18 PM   #4054
rcsuicide's Avatar
[QUOTE=howardcano;11775746]
https://www.youtube.com/watch?v=547UwkAj5Uk[/]That's hilarious! The Brits would probably call it "Roundabout Racing".
What would the Brits call this type of racing? ...
http://www.photobucket.com/media/Figure8race.mp4.html
rcsuicide is offline   Reply With Quote
Old 02-05-2013, 02:56 PM   #4055
Marv's Avatar
That one might qualify for an Allstate Mayhem commercial...
Marv is offline   Reply With Quote
Old 02-05-2013, 10:39 PM   #4056
muahdib4's Avatar
Send a message via Yahoo to muahdib4
Anyone have any experience with the Tamiya TA05 for VTA? Put the front wheels on tonight and noticed that the upper camber link ball cup rubs the inside of the wheel. I'm running the required 0 degree offset HPI wheels. Am I going to need to run extended wheel hexes or is there a better fix? If I push the wheels out more I'm afraid they will stick outside of the front wheel wells. I'm running the HPI GT350 body. I can post pictures later but my iPad wont let me copy the URL when I put the pic in my album on here.
KCRC - Kansas City Remote Crawlers
Team Chucklenuts Racing
Midwest R/C Rally Confederation
KC/RC Drift Movement
muahdib4 is offline   Reply With Quote
Old 02-05-2013, 10:52 PM   #4057
Marv's Avatar
You can try to file some off the top of the ball cup on an angle =
I had to do this with my S2 =
I'm using RPM 80202 6mm Hex Nut Adapters on the front with the zero offset vintage wheels so the rub was near the edge of the rim = I took a file to my RPM Ball End & I lightly sanded the inside of the wheel where it was rubbing.
I also marked the top of the ball end with a magic marker afterwards.
Old 02-06-2013, 07:40 AM   #4058
Racer X79's Avatar
Trader Rating: 30 (100%+)
I ran mine 2 different ways. Early on, I used the tamiya 1mm wheel shims to space the wheels out just enough to clear, I think it needed 2 on each side. Then, when the 416 came out I switched to 416/417 style c hubs and steering knuckles (I had a TA05R so it already had the lightweight suspension arms). Those give you proper clearance and you don't have to use spacers or 6mm wheel hexes. Either way works, but I preferred the c hubs/steering knuckle swap.
--Ermer Racing Inc.--
IDC Precision Machining (www.idcwi.com)--Trackside Raceway (www.trackside.com)--Hounds Hobbies and RC Track In The Back--
Racer X79 is offline   Reply With Quote
Old 02-06-2013, 07:48 AM   #4059
muahdib4's Avatar
Thanks guys, I will play around with it and see what works best for me. I'm running a pretty much stock TA05 so don't have the lightweight suspension. Would the TRF parts still fit? If not, I will probably just shim them I guess. I don't like the idea of sanding the inner wheel...because I'm an idiot and would have the wheel balance all kinds of screwy.
Old 02-06-2013, 07:52 AM   #4060
on my ta05v2 i am running 5.5mm hex in the front and 7.7 mm hex in the back.. the 7.7mm hex are from a traxxas stampede
so far so good.
rescue119 is offline   Reply With Quote
Old 02-06-2013, 08:42 AM   #4061
f1larry's Avatar
R/C Tech Charter Subscriber
Trader Rating: 17 (100%+)
Send a message via AIM to f1larry
The rubbing issue is not a problem on the Version 2 of the TA05, it is a completely different front suspension. the version 2 the c hubs are shorter (smaller bearing) and fit in the wheel better.
I had the same issue on my TRF415 and TA05. had to shave the top of the ball joint as well as shave the inner edge of the wheel.
The other option is to put the Version 2 suspension on the car. The virsion 2 suspension is the same as the 416/417. You have to change the suspension arms, c hubs, uprights, and bearings. (TA05 bearing is a 11x5 the version 2 bearing is a 10x5)
so far so good.
Windy City RC Raceway & Hobbies, Arlington Heights, IL
Exotek F1R3|Tamiya TRF 415|TA05 v2|TA05|TL01RA|TL01|M06|F104 Pro|F103RM|RM-01
Custom Racing Stickers
2012 TCS Race #170 "The Track" @ Harbor Hobby Best of Show Mini Pro
f1larry is offline   Reply With Quote
Old 02-06-2013, 12:40 PM   #4062
don't look like fun. might as well call it crash up derby rc
bigtee is offline   Reply With Quote
Old 02-06-2013, 01:18 PM   #4063
howardcano's Avatar
[b
"Bidirectional Bangers"? Or maybe they'd just lump it in with "Yank Racing"?
Howard Cano
Old 02-06-2013, 01:47 PM   #4064
Marv,
Can we get a shot of the outside of the wheel? It looks like you blacked out the spokes and I'm wondering what the final result looks like.
Andy
Subaru Brat - Sand Scorcher - Rising Storm - Wild Willy II - 1967 Beetle - F350 High Lift - Stampede - Rustler - XXX-SCT - Micro Baja - XX-CR - SC10RS - B4.1FT - S1
Drive what you want. Bash when you can, race to win , but do it all while having fun.
Jeckler is offline   Reply With Quote
Old 02-06-2013, 04:41 PM   #4065
Marv's Avatar
Originally Posted by Jeckler View Post
Marv,
I used flat black Testor's Model Master paint and a brush...
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5870 02-22-2017 09:31 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
