Like Tree238Likes
Old 04-09-2012, 01:46 PM   #391
Originally Posted by aarivers View Post
and if we really wanted to be anal about it we would be running F103GT's for the 2wd live axle feel of an old muscle car. Then these things really would be a handful.
That would be a lot of fun. I can't wait to build a gtp car on a f103. They aren't really hard to set up and drive just very different techniques. I may drop my 25.5 and a mustang body on it just because.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 04-09-2012, 02:45 PM   #392
[QUOTE=snoopyrc;10573003]190 +6+6=202 plus you have to consider that the wheel and tire are 31mm not 26. That's another 5mm on each side.
The way that I understand wheel width and offset is that if you had two wheels with the same offset, but one was 5 mm wider, the extra width would be split evenly between the two parts of the wheel on either side of the mounting plate. The wheel would stick out 2.5 mm farther and also come 2.5 mm closer to the chassis on the inside. Offset on the other hand is all one way or the other. With two wheels of the same width, but one with a 6 mm offset, the one with the 6mm offset will stick out the full 6mm and the inner edge of the wheel would also be 6 mm farther away from the chassis.
Therefore, under my understanding, the outer edge of the rear wheel on our VTA cars sticks out 8.5 mm farther than the front wheel, and the inner edge is 3.5 farther out. (6 mm offset reduced by the 2.5 extra inner width)
8.5 + 8.5 = 17 mm wider overall in the rear.
Rufus2010 is offline   Reply With Quote
Old 04-09-2012, 03:45 PM   #393
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
[QUOTE=Rufus2010;10580179]
wow...that's a whole lot of over thinking
if you are running a car that's designated as a 190mm chassis (which most of us are), then the 31mm +6 wheel work on the back of all the bodies...assuming you are running a 5-ish mm wheel hex, even a 6mm will be fine..I know on my TCX, I have the 5mm hexes with a red tamiya wheel spacer (don't know the size off hand) and I don't have any issues..
I know almost all the HPI bodies are wider in the rear then the front - even the protoform is the same way..
we've all seen images of the pegasus bodies that are, well, just plain WIDE
and parma's work...
maybe I just like things simple
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 04-09-2012, 03:50 PM   #394
DARKSIDE's Avatar
Originally Posted by JustWill75 View Post
I'm running in USVTA with A EDGE and SS motor combo. I'm now considering gettig a Balistic 25.5 and just wanted to know if this is a faster motor? I've heard rumors that SS motors can be faster but it depends on the batch and I dont have the money to be out running through motors till I find that gem......
Are there any conditions where one motor might be better than the other. I curently race a mid sized technical track layout with a TC6.
Does everyone just crank the Timing all the way up on the ballistics or has anyone found that sweet spot.
only advantage over a SS, is its rebuildable....nothing more...
and I dont know about any batch of motors, but Ive had awesome luck with all 3 of mine...SS reman, SS new, Ballastic stator....no issues at all...
I never crank my time on the motor all the way up....its a sweet spot to every motor...along with the gearing(FDR)...always remember a cool motor is a fast motor, and more consistant...
For HS, ask Melvin or Joe...
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
Southern Indiana RC Raceway
Independance On-Road Bash
July 1,2017
DARKSIDE is offline   Reply With Quote
Old 04-09-2012, 04:02 PM   #395
LasagnaCat's Avatar
Trader Rating: 140 (100%+)
Send a message via AIM to LasagnaCat
I was considering waxing the outside of my shell to lower the coefficient of friction between the boards and my shell.
You haven't *been* doing that? Parma Fashine wash/wax should be your friend... Rookie.
I actually do wash/wax our bodies every week.
Admittedly it's ONLY done because my other half insists on light colored bodies and the black asphalt road rash on the roof drives me nuts, and because I won the bottle of Parma stuff in a raffle a few years ago.. it *does* make them purty though.
Well if it seems to be real, it's illusion
For every moment of truth, there's confusion in life...
LasagnaCat is offline   Reply With Quote
Old 04-09-2012, 04:06 PM   #396
DARKSIDE's Avatar
over think...humm...I have to agree...Ive run 6-8 chassis in VTA , from E10,Sprint 2, TC3/4/5/6, Xray T1/2/3...and they all seem to work with the legal front and rear tires/rim from HPI and bodies....
I dont see an issue?....but for pic
HPI 1970 Cuda on HPI E10
HPI 1968 Camaro on TC3
HPI 1965 Mustang GT on TC4
HPI 1965 Mustang GT on TC5
HPI 1968 Camaro on TC5
U.S. Vintage Trans-Am Racing Part 2-07-19-08_2127.jpg   U.S. Vintage Trans-Am Racing Part 2-68-chevy-camaro...usvta-2008.jpg   U.S. Vintage Trans-Am Racing Part 2-my-pics-898.jpg   U.S. Vintage Trans-Am Racing Part 2-usvta-nationals-2009-069.jpg   U.S. Vintage Trans-Am Racing Part 2-usvta-nationals-2009-091.jpg
July 1,2017
Old 04-09-2012, 04:16 PM   #397
DARKSIDE's Avatar
BMI
Xray T1 with 70 Cuda
Sprint 2
Losi
Xray T2
U.S. Vintage Trans-Am Racing Part 2-wednesday-night-ta-001.jpg   U.S. Vintage Trans-Am Racing Part 2-wednesday-night-ta-079.jpg   U.S. Vintage Trans-Am Racing Part 2-wednesday-night-ta-018.jpg   U.S. Vintage Trans-Am Racing Part 2-wednesday-night-ta-016.jpg   U.S. Vintage Trans-Am Racing Part 2-ta_practice.jpg
July 1,2017
Old 04-09-2012, 04:58 PM   #398
pejota's Avatar
Ya know... i've got an F103gt sitting around doing nothing... i might have to try that.
If you want some real fun, go find an RC10DS and throw some VTA rubber on it! The wheelbase is a bit long IIRC, but it was a blast tearing up the street in front of my house!
pejota is offline   Reply With Quote
Old 04-09-2012, 05:29 PM   #399
wwddww34's Avatar
Trader Rating: 9 (91%+)
That's some great advice. Thank you L-Cat. I'll get some high-shine car wax and put it on my VTA before the next race on Thursday.
__________________________________________________ ___________________
---->2012 Summer Carpet Shootout Series brought to you by Mikes Hobby Shop
wwddww34 is offline   Reply With Quote
Old 04-09-2012, 05:33 PM   #400
LasagnaCat's Avatar
I'll be waiting for the full page photo.
Old 04-09-2012, 05:36 PM   #401
DARKSIDE's Avatar
I raced some of those at the VINTAGE ONROAD CHAMPIONSHIP. With my tc3 with the front axle disconnected to make it rear wheel drive. Btw I won that race. Sweet
July 1,2017
Old 04-09-2012, 06:18 PM   #402
303slowdown's Avatar
Trader Rating: 21 (100%+)
And the half big half little post..
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 04-09-2012, 06:32 PM   #403
snoopyrc's Avatar
That makes sense in theory, but I have been under the impression that the Vintage HPI shells were 200mm front and 210mm rear. I guess I read that. Thought I got it from HPIs material. My VTA chassis fits well under HPI shells and I have measured it with rims on at 190mm F 200mm R. So my hands are up. My shoulders are shrugged. I don't know man.
Thats pretty good math though. I will have to measure the rear wheel of the VTA set to see if its 2.5mm more from the hex hole to the inside edge of the rim.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 04-10-2012, 04:25 AM   #404
k_bojar's Avatar
not sure if ALL the HPI vintage bodies are that dimension - but they are all 200 in the front and wider in the rear, to account for the wider rear tires
Old 04-10-2012, 06:33 AM   #405
wwddww34's Avatar
After spending all that time making sure your car's wheels are flush with your car's body I certainly hope that you've spent enough time practicing on the track and getting your line down so that you don't clip a corner of the board and put a rip in your car's body, or worse, catch one of your front tires on the board and damage your steering parts.
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 5996 06-21-2017 06:50 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
