Like Tree514Likes
Old 01-06-2013, 02:29 PM   #3646
Default New Person needs help
Greetings folks-
New here to VTA and need some guidance. I am putting together a TC3 VTA spec car and was wondering if I am correct when it comes to the pinion. I am going on the assumption that the internal ratio on the TC3 is 2.5 and I have the standard 72 tooth spur. I have read that the desired final drive ratio for the motor spur combo would be 4.0 which would mean a 45T pinion (48 pitch). Does that seem to be correct? Never ran a pinion that large before, but then never ran a 25.5 turn motor either. Thanks for any info you can give me.
Larry
lwolf is offline   Reply With Quote
Old 01-06-2013, 03:11 PM   #3647
Mundy1's Avatar
Trader Rating: 50 (100%+)
Somebody once said "be careful about what you wish for." I purchased a Cirtix Stock Club race + Ultra Sportsman 25.5T motor Combo. I put the combo in my VTA to test it and found out my car was going much slower than before. I gave the motor to my roommate who was able to test it with his SkyRC BMC-01 Brushless Motor Checker. His motor checker showed my S.P. 25.5 motor had about 1223 Kv. We tested a Novak Ballistic 25.5 motor in the BMC-01 Checker and it showed the Ballistic had about 1542 Kv. The Ballistic motor has +319 Kv advantage over the S.P. 25.5 motor.
The Ultra Sportsman and the Competition V3.0 are different motors as well.
I believe the Ultra Sportsman 25.5 was made to be a Cheap crawler motor. The Competition V3.0 25.5 was made with racing in mind and should be on par with the Novac for VTA.
TLR SCTE BCE H1,Hobbywing Xerun 150 SD , Hobbywing 4000KV
TLR 22SCT Speed Passion GT Pro Stock, Express Motorsport 13.5
TLR 8ight 2.0 BCE, Hobbywing Xerun 150 SD, Tekin T8 2050
TLR 22 Hobby Wing 3.1 Stock Sec, Express Motorsport 17.5
Mundy1 is offline   Reply With Quote
Old 01-06-2013, 06:27 PM   #3648
Originally Posted by kennym View Post
where about is carrollton at in texas?-------that would be coll but heck i am lucky to have gas to make it to the end of the driveway on gas-loloo
1/2 mile north of Dallas
www.UltimateOval.com
[email protected]
-NOVAK
tgr2000 is offline   Reply With Quote
Old 01-06-2013, 08:11 PM   #3649
alloyslash's Avatar
Trader Rating: 19 (100%+)
Originally Posted by bertottius View Post
I think it may be my transmitter. Which radio do you use?
Futaba 4pl
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 01-06-2013, 08:25 PM   #3650
bertottius's Avatar
Originally Posted by alloyslash View Post
Futaba 4pl
I think I'm just used to the old brushed motor brakes and maybe these motors don't have the same? I checked my radio and I think everything looks good.
CHRIS BERTOTTI
Alpha Pace Racing
R.C. Hobbies
MSA Distribution
bertottius is online now   Reply With Quote
Old 01-06-2013, 09:04 PM   #3651
GP40X's Avatar
Carrollton is a suburb of Dallas between Farmers Branch and Lewisville. Mikes is on I35E between Beltline Road and Sandy Lane on the west side of the Freeway
Google Maps is your friend:
Mikes Hobby Shop, home of the 2013 Ultimate Trans-Am Championship
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 01-07-2013, 07:00 AM   #3652
DARKSIDE's Avatar
so how was your VTA racing this weekend?...
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/OTT/1UP
Apex Raceway and Hobbies
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 01-07-2013, 07:11 AM   #3653
The Captain's Avatar
Pretty decent. Made the A main by 1 sec, and finished last. Think I left the traction compound on too long, as I was traction rolling until about half way through the main. Still learning setup techniques though.
Question for you fast guys: Are you staying on full throttle almost all of the time? Is this how my car should handle?
-Derrick-
"Yeah, well, thats just like your opinion, man."
The Captain is offline   Reply With Quote
Old 01-07-2013, 07:16 AM   #3654
mkiiina's Avatar
Trader Rating: 69 (100%+)
For the second week I set TQ and then it all went sideways in the main. A fellow racer has locked up First place in out Winter Series and I have a pretty solid second. Great weekend of racing again this week and we had several people bring their VTA's out for practice/tuning that were brand new. Look forward to seeing them on the carpet!
mkiiina is offline   Reply With Quote
Old 01-07-2013, 07:20 AM   #3655
mkiiina's Avatar
Depends on your layout. Traction roll is not normal. A band-aid fix is back off how much traction compound you are using (if you are saucing the whole tire back off to 2/3-1/2 and see what happens).
Old 01-07-2013, 07:29 AM   #3656
Yeah I put it on about 1 min before the B main, which is 3 min longer than the qualifiers, and I think thats what did it ( I usually put it on right after the heat before mine). ~4 min longer was too much I guess. About half way through the main it was hooked up real nice, but by then I was so far behind I had no chance.
-Derrick-
Old 01-07-2013, 07:36 AM   #3657
mkiiina's Avatar
I usually sauce my tires basically right after I come off the track and then its an hr +/- before the next round (we have an off road program that gets mixed in).
If traction came up throughout the day check to make sure you are doing a good job of cleaning your tires. If you have compound building up it will change how the car handles throughout the day. (ie. First qual - Low traction, Second/Third qual - good traction, Main - too much traction leading to rolling).
Might want to try swapping out springs or going to a front roll bar/going one step stiffer.
Old 01-07-2013, 07:41 AM   #3658
Thats a good point as well, the layout was brand new, and by the end of the night you could clearly see a new groove. I didnt even think about that.
My tires are REALLY broken in, I cant sauce them too much or I traction roll like crazy. They have almost 100 runs on them.
Track before racing (Pics by 3D-Seth)
After
-Derrick-
Old 01-07-2013, 08:19 AM   #3659
markt311's Avatar
Trader Rating: 32 (100%+)
VTA setup for sale. If it doesn't go soon it will be racing at ThunderJam 5 in a few weeks.
Xray VTA setup 2 races old
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 01-07-2013, 05:31 PM   #3660
rcsuicide's Avatar
Southern California is kicking off their new VTA Race Club with a Swap Meet. Anybody living near Chino (Los Angeles) California area should go to this Swap Meet at TQ RC Racing. There are going to be hundreds of hard-to-find items there. Click on the pic below to read more about it.
rcsuicide is offline   Reply With Quote
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 6019 11-19-2017 07:11 PM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
Currently Active Users Viewing This Thread: 15 (7 members and 8 guests)
Csaari77, microed, Rcforlife13, Serzoni, team_tamale, theproffesor
