View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#3560
If you have a very tight track with an abrasive surface I find the tire rolls over too much and prematurely wears the front tires on the inside.
for gluing the sidewalls it's more for stopping traction rolling by adding a slippery surface near the edge of the tread. I have never used it but know others that have the wrong setup try it as a stop gap
#3561
What is your link positions? If you have alot of camber gain in the suspension when in a turn that will do it. No matter what your camber is set at on the tools you can possibly be gaining another 1.5*-2* when the chassis rolls into the turn. If you have 1.5* already, you can possibly be around 3*+ in the turns ( right where tire wear is the greatest ) Also, if you only put additive on the 1st few treads that will soften the sidewall and increase treadwear.
#3563
I find that the front tires wear faster on a chassis setup that pushes, and/or one that concentrates more weight towards the front of the car.
So if you are cranking 100% steering into it and the car isn't turning as well as it should, and/or you are using the steering to slow it down going into a corner, that's hard on the front tires.
When I balance my VTA car with more weight to the rear (I need about 70g of lead to hit 1550), the steering is better and the front tire wear is reduced. If I put the lead on the front, it pushes more and wears the front tires faster.
#3564
Also, be sure to tell all of your friends about this race by clicking on one of the Facebook, Twitter, or LinkedIn icons at the top right corner of the web page.
#3565
Hi guys,
Just picked up some TC3 and TC4's for myself and my sons.
Went to order esc's and motors and bought the last 2 Novaks Amain had in stock. So I ordered 2 Speedpassion revention's for the last 2 cars but need 2 more motors because I cannot use a SpeedPassion 25.5
Can someone give a little insight into why only Novak motors are allowed?
I could see the level playing field if it were only one motor but with 3 different Novaks approved there is a difference just like there would be with a SpeedPassion compared to Novak.
#3566
Hi guys,
#3567
I glue the side walls as the rear tyres move around on the rims too much and can cause the car to randomly react during cornering. But the fact we run 17.5 blinky might not be helping that fact.
I also find my frot tyres wear out prety quick but iv put that down the the spool i run in the front
#3568
Hi guys,
#3569
Spool or Diff in front?
Pros & Cons...
My thoughts:
Diff would allow the car to roll through the center of the corners better and inprove turn in. Also would reduce front tire wear
Spool helps car pull off corner and pull straight, but with such low HP in VTA are we really gaining much with a spool?
Pros & Cons...
My thoughts:
#3570
I think this answers my question on the same subject, but I am unclear on couple things =
I have no traction roll at all with either setting
Yes, there was heavy chassis roll {tight course, many short tight 180 turns in a limited space}
Initial camber setting =
After five straight back to back 5 minute races
Front camber at -1.0
Front toe 0°
Rear camber at -1.0°
Rear toe at -2° {fixed}
Resulted in heavy wear on the outside edges of all tires with the front showing more that the rears
Next camber setting =
Front camber at -2°
Front toes at -1°
Rear at camber at -1.5°
Rear toe at -2° fixed
Resulted in heavy wear on the inside edges of all tires with the wear about even on all tires
I'm unclear on the term camber gain =
Chassis rolls and changes the camber setting as it rolls?
I'm not quite sure I understand how to reduce the chassis roll... (?)
Stiffer springs?
Shorten or lengthen or raise/lower (AND/OR both?) the camber link ?=
Sprint 2 has only one camber link/adjustment per each corner =
Each may be lengthened/shortened and slightly raise or lowered at the shock towers
Thank in advance
