Like Tree5Likes
Old 12-18-2012, 04:35 PM   #3391
mikel33's Avatar
Trader Rating: 2 (75%+)
Originally Posted by LloydLoar View Post
This thread is absolutely ridiculous, and has played a huge role in ensuring I will never race VTA outside of my local tracks. Positively asinine.
Lloyd, every thread on RC Tech is like this in some form or fashion. Just a bunch of internet cowboys thrashing each other. VTA racing is some of the best racing you will find. I have raced VTA at tracks in Ohio, Wisconsin, Illinois, Tennessee, and Indiana. Trust me, its all good. You're missing out if you don't take you vta car with you to other tracks.
Michael Larson.
Village Idiot Racing
mikel33 is offline   Reply With Quote
Old 12-18-2012, 06:00 PM   #3392
GP40X's Avatar
Originally Posted by rcsuicide View Post
Ok. I am hooked. How big is it?
Originally Posted by DontChangeUSVTA View Post
Is it bigger than my dog, Pluto?
Originally Posted by mkiiina View Post
That's a big dog.... and yes it is bigger
Much Much MUCH BIGGER
More information coming soon so stay tuned.
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 12-18-2012, 06:03 PM   #3393
DARKSIDE's Avatar
its pretty BIG...VTA BIG!!!!
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Indoor Carpet Nationals
Summit RC Raceway www.summitrcraceway.com
1421 Goshen Ave, Fort Wayne, IN 46808
DARKSIDE is offline   Reply With Quote
Old 12-18-2012, 07:51 PM   #3394
IndyRC_Racer's Avatar
Thanks to those who gave good information on traction rolling. How much does shock oil (weight) have an affect on traction rolling? If you like everything else on a setup, can oil or piston changes help?
I'm currently racing VTA. Check here for rules/info: http://www.usvintagetransam.com/
IndyRC_Racer is offline   Reply With Quote
Old 12-18-2012, 08:31 PM   #3395
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Its another tuning aid and can be misused if not fully understood....general rule of thumb is stick with what you know works on your base setup...most times thats 30 to 40wt oil. When you go stiffer(heavier) oil you might need to go up in spring rate as well. Smaller pistons holes or less holes has the same feel as stiffer oil. If you go too heavy on the oil the car is unresponsive and it might still traction roll if other things on the setup are not changed. Thats why I didnt talk about it too much there are more things to change that have a quicker effect than shock oil. The best advice I can give is when ever your car starts to feel a little off just rebuild your shocks and 9 times outa 10 that solves most problems. Alot of times guys over look their shocks and leave the oil in there for months at a time when really it should be changed about every 2 race days.
If you have anymore questions feel free to ask everyone will do their best to help.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....14th year running 2016/17!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 12-18-2012, 08:57 PM   #3396
robk's Avatar
Trader Rating: 22 (100%+)
As far as the reason to glue sidewalls, you can generally glue up the tires and not change your car a ton. If the first thing you do is change all the camber links and shock oil, your car is going to be much different to drive. Now you may have different problems.
Beyond the glue, the way to think of preventing traction rolling is to keep the car rolling within the limits of its suspension. If you watch a car that snap rolls of the track, it's like a door hinge. The car immediately transfers so much weight so fast it just lifts the wheels. If the car can roll more in the confines of the suspension, and does it in a slower fashion, it won't start lifting the tires.
Old 12-19-2012, 07:29 AM   #3397
WD40's Avatar
Originally Posted by rcpaintinpete View Post
Will that sucks
I'm gonna pm you my #
if you could get some time off
The track is about 1 hr from my house
Would have no problem having a guest once
I TELL the wife lmao ?
I'm not gonna make the full race probley a qualifier or 2 and then the main
But it would be great to race with you again
I will work on trying to get off for work, but it isn't looking favorable. Thanks for the offer Pete, but I don't want you to have to listen to me for a whole week! haha
WD40 is offline   Reply With Quote
Old 12-19-2012, 09:12 AM   #3398
wwddww34's Avatar
Trader Rating: 9 (91%+)
It's bigger than this Caterpillar Truck ...
wwddww34 is offline   Reply With Quote
Old 12-19-2012, 09:16 AM   #3399
NutDriver's Avatar
Trader Rating: 14 (100%+)
My apologies for not reading back through the 227 pages in this thread to find the answer to this question. My question is what are the exact differences between a TC3 and a TC4? What parts are interchangable? Thanks for tolerating my laziness.
scott
"Racing makes heroin addiction look like a vague longing for something salty" - Peter Egan
USVTA member #111
NutDriver is offline   Reply With Quote
Old 12-19-2012, 10:39 AM   #3400
scott
The battery on the 4 was moved closer to the center line, camber links moved to the stiffening wings, different shock towers, different drive line carrier/input shaft(?), different arms,hubs,steering blocks, hinge pin holders. The 3 also had a "slider" steering set up and the 4 is a double bell crank. I am sure I forgot something
I have put TC3 shock towers on a TC4 to play with camber positions as well as putting TC4 Castor blocks on the 3(you have to drill a hole for the set screw to hold the pin in). You can also use all the TC4 suspension on the 3 with little to no modification. The steering knuckles and rear hubs should go on the TC3 with no issue (besides drilling a hole for the set screw in the hub).
Team Novak,Gravity RC,
ercwhtsd is offline   Reply With Quote
Old 12-19-2012, 12:49 PM   #3401
The inner hinge pins on the TC3 and TC4 (a-arms) are not the same diameter, so they are not a direct fit. The a-arm mounts also are different so they aren't a direct fit either. Bottom line is that many parts may fit on each car, but may require some modification. Also, some Losi XXX-S parts will fit on the TC3 (steering knuckles, caster blocks, rear hub carriers)
All of the drive line parts are interchangeable EXCEPT the spur gear assembly holders. Also the TC4 drive shaft/input cups use smaller roll pins. So if you use a TC3 shaft on a TC4, you will need to use TC3 input cups.
Many people have created their own version of a TC3.5 by using the TC4 shock towers, chassis braces, and steering knuckles (all are a direct fit onto the TC3).
Some aftermarket chassis also had the ability to use a swing steering rack (http://www.xtremercracing.com/Produc...10040&pID=1155).
Bottom line is that I've run a stock TC3, tub TC4, and FTTC4 in VTA and was competitive with all of them. Each car has quirks (TC3 rack gets dirty, tub TC4 is a pain to adjust shims under a-arm mounts, FTTC4 is a pain to replace a spur gear/change pinion & you have to cut an ear off your servo), but all are capable of a podium finish.
Hopefully this info helps.
Old 12-19-2012, 01:30 PM   #3402
All of the drive line parts are interchangeable EXCEPT the spur gear holders. Also the TC4 drive shaft/input cups use smaller roll pins. So if you use a TC3 shaft on a TC4, you will need to use TC3 input cups.
Thanks Brian- I knew you would come through, (fastest tubby in the IL/IN area IMHO).
Old 12-19-2012, 01:37 PM   #3403
IndyHobbies.com's Avatar
I just learned something from you guys, thanks!
Also, to help cross reference, I printed these two lists off a while ago. One is a numerical list of the TC3 parts and then one of the TC4 parts. I used a highlighter to go through them and see which parts worked for both cars. I've attached the PDF versions you can print or save.
Or, you can get other lists with these links:
TC3 List: http://www.teamassociated.com/pdf/ca...at_rc10tc3.pdf
TC4 List: Go to this link and push the "Download in EXCEL" button in the upper right corner and you will get an Excel spreadsheet of parts: http://www.teamassociated.com/cars_a...s_accessories/
Now that the TC4 has been re-released, parts for it will be much easier to find I imagine, and available for a while. But, the unique TC3 parts might be something to keep an eye out for at swap meets or ebay.
I would suggest that you print a copy or save the electric file. You never know how long they are going to leave this stuff up on the web.
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 12-20-2012, 04:50 AM   #3404
I have very specific questions for what I would imagine is a very specific group of people.
I am running a stock TC4 Club Racer with the Novak Edge 25.5 motor. What gearing are you running? 48P or 64P? What is the stock spur in the TC4 Club Racer?
I have spoken with others at the track and they suggest a FDR of about 4.00. But I can't for the life of me figure out what the stock spur gear is. It looks like 66, but its so small it is really hard to tell. With that said, I am running the stock spur with a 37 tooth pinion. 37 is about as big as I can go. 39 seems to fit too tight. Based on the above, assuming stock spur is 66, I would need somewhere around a 41-43 tooth spur to hit a FDR of 4.00. Am I missing something?
rtebbe is offline   Reply With Quote
Old 12-20-2012, 05:09 AM   #3405
The stock spur gear is 72 teeth. I am still running 48p on my club racer, but I have switched to a 60 tooth spur gear. That puts you at a much easier to fit 60 spur and 38 pinion, but I am pretty sure any pinion larger than 35 tooth will need some grinding done to the chassis supports so the gear doesn't rub.
anr211 is offline   Reply With Quote
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5867 Today 01:45 PM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 08:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 08:56 AM
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
vta4life
