Like Tree129Likes
Old 12-02-2012, 03:14 AM   #2971
DARKSIDE's Avatar
U.S. Vintage Trans-Am Racing Part 2-trophytimem.jpg   U.S. Vintage Trans-Am Racing Part 2-usvta_2009_003.jpg   U.S. Vintage Trans-Am Racing Part 2-usvta-nationals-2009-098.jpg   U.S. Vintage Trans-Am Racing Part 2-img_0489ahmm.jpg   U.S. Vintage Trans-Am Racing Part 2-chipconcoursem.jpg
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform/RockStar Paint, LLC
2017 USVTA Summer Slam
July 28-30
DARKSIDE is offline   Reply With Quote
Old 12-02-2012, 03:14 AM   #2972
nwv327's Avatar
not to wild about how the numbers on the hood came out... probly should have gone smaller but w/e
xray t3/t4 viper vtx10r/vst, tc3 VTA novack edge/ballistic , rc18r reedy , losi muggy, axial exo MM2/castle 1415, losi 8ight T 2.0 /castle 1515/MM2 , proboat blackjack29 hobbywing 130 HV/turnigy super edf 6s =)
nwv327 is offline   Reply With Quote
Old 12-02-2012, 03:23 AM   #2973
DARKSIDE's Avatar
U.S. Vintage Trans-Am Racing Part 2-usvta-scale-nationals-2011-002.jpg   U.S. Vintage Trans-Am Racing Part 2-usvta-scale-nationals-2011-001.jpg   U.S. Vintage Trans-Am Racing Part 2-usvta-scale-nationals-2011-019.jpg   U.S. Vintage Trans-Am Racing Part 2-usvta-scale-nationals-2011-004.jpg
July 28-30
Old 12-02-2012, 06:21 AM   #2974
shadowracer24's Avatar
Just for your info Bill we at PC do not run light weight. The cars are put on the scales and must be at 1550g or higher. We give new racers a race or two to get there equipment to spec as not to discourage them from continuing in this class.
Richard Carpenter
SPEEDZONE Batteries Team Driver
BMI Team Driver
2014 F.E.D.S. Mod Sprint and Sportsman Late Model Champion
2013 FSERA World GT State Champion
shadowracer24 is offline   Reply With Quote
Old 12-02-2012, 08:27 AM   #2975
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by alloyslash View Post
I ran my T3'12 in VTA and knocked my best lap time down by 0.9sec ( run a T2'07 usually in VTA ). Large track, med/high bite, this worked for me;
2.8/2.6 springs
35w oil all 4
1.5*f / 2*r camber
#2 link hole front w/4mm shim out and 1mm in
#2 link hole rear w/1mm shim out and 1mm in
0* front toe
2* rear toe
50mm ECS shafts front
52mm rears
top shock hole #3 f&r
5mm ride height f&r
6mm front droop
5mm rear droop
medium flex settings top and bottom
f&r diffs up position
1.4 swaybar front
1.2 swaybar rear
Setup worked for me with my driving style
what about the wheel base front and rear ?...Thanks
OVA is offline   Reply With Quote
Old 12-02-2012, 08:54 AM   #2976
Marv's Avatar
Originally Posted by DARKSIDE View Post
also any chassis is allowed cause why not...if you want to spend big money on a new chassis...knock your self out...but dont get pissy about the class when Joe Blow whoops you with a Sprint 2...just saying, any chassis will work if you can get it setup for your style of driving...
It could happen...
And the name be ZION!
Wait a sec...that's in a Jimmy Buffet song...
Marv!
Yeah, that's it... Marv!
OR
By The Battman driving Marv's Sprint 2.
Marv is offline   Reply With Quote
Old 12-02-2012, 10:32 AM   #2977
havent tried a 108...but 104,100, and I currently use 96 all Kimb,...not sure whats not fitting
My post was a little unclear. My chassis is XRay and that is why the Kinbrough spur gear won't fit. It is just a touch too thick. I am going to give it to my friend who I talked into trying the hobby. He got a good deal on a used TC6 and is collecting what he needs to race. An 88 tooth 64p spur gfewear came with the car, but I don't think it will work for the final drive ratios we need in VTA because of fitment/clearance issues with the chassis and/or motor mount. Am I right on this?
Maybe the 108 spur I was going to give him won't fit either (too large, too much space between the transmission layshaft and the motor shaft to fit in the chassis), because the pinions needed for the right fdr are too large?
I don't have access to his car today, otherwise I would just mount things up and check.
I have this collection of large pinions (54 through 58) I don't use right now and I would just as soon let him use them as keep his entry cost to the hobby lower, but if the won't work, it's not the end of the world.
Rufus2010 is offline   Reply With Quote
Old 12-02-2012, 04:06 PM   #2978
Default driver figures
Where can I get a driver figure to use in my vta car? What to have one as a option on for fun. Was just think of just going to toy store and buying some type of action figure and using the head and maybe mount it some type away in the car make it a Bobble head Lol
bigtee is offline   Reply With Quote
Old 12-02-2012, 04:28 PM   #2979
5th wheel's Avatar
NWV327 very nice looking car ALLthe cars look very nice guys
5th wheel is offline   Reply With Quote
Old 12-02-2012, 04:38 PM   #2980
mkiiina's Avatar
Trader Rating: 69 (100%+)
I run a T3'10 and run a 96/45-47 iirc and it works just fine. Mine had a slight rub when I improperly installed the top deck/holders. Check there first as there shouldn't be any difference between the 104-100-96
mkiiina is offline   Reply With Quote
Old 12-02-2012, 05:11 PM   #2981
mikel33's Avatar
Trader Rating: 2 (75%+)
Originally Posted by OVA View Post
Hi
I have the Xray T3 2011 , who got the VTA chassis set up for Xray car?
ps 2012 T3 is Thanks
Here is my T3 2012 setup that qualified 5th at the last weekend's Cleveland indoor champs:
This is pretty much my stock set-up. Traction was pretty good in Cleveland but not super high.
Sorry for things being in no particular order.
Final Drive = 3.42
Rear gear dif, 1000 cst
Front Spool
med hing pin holders front and rear
2 MM spacers on front hinge pints
4 deg caster
arm spacing full long in rear, 1 mm from full long in front,
+ 0.75mm hexes on the front, standard in rear
standard 52 mm shafts on the front (no ecs)
5mm ride height, droop = 2mm over ride height front and rear
1mm ackerman shim
1mm bump steer shim
medium location for inner links front and rear (as bite comes up move to shortest location as preferred)
4mm shims on outer ballstud in rear, inner hole on rear hub.
1mm shim on outer ballstud in front
Rear Shock: 275 or 350 cst oil w/ 2.4 springs, 25% rebound, top position layed all the way down
Front Shock: 350 or 400 cst oil w/ 2.8 or 2.6 springs depends on feel, 25% rebound, top position middle hole or 1 lower.
1 deg camber in front
1.5 deg camber in rear
1 deg toe out in front
3 deg rear toe
In my possibly uninformed opinion, the protoform body works best.
I was playing around with the shock oil all weekend, pick your flavor. I had the suspension pretty soft. The car is pretty darn fast
And before anyone comments on running a T3 2012 in vta, its what I had. Total costs to convert were tires, body, and a 25.5 stator.
Another racer was nice enough to take a picture of my car (Thanks!):
Michael Larson.
Village Idiot Racing
mikel33 is offline   Reply With Quote
Old 12-02-2012, 05:13 PM   #2982
mikel33's Avatar
HPI makes one
Tamiya has some stuff also
probably others.
I used a PEZ dispenser head a few years ago.
Michael Larson.
Old 12-02-2012, 05:42 PM   #2983
JFuel11's Avatar
Trader Rating: 145 (100%+)
Hello,
I wanted to check on a concern I have regarding cooling fans and motor heatsinks...
Is it legal or non-legal in VTA to run motor fan or heatsink with built in fan?
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 12-02-2012, 05:53 PM   #2984
mikel33's Avatar
Originally Posted by JFuel11 View Post
Hello,
I actually talked to Rob about this the other day. He can correct me, but you should be fine.
Michael Larson.
Old 12-02-2012, 05:54 PM   #2985
Geno-Machino's Avatar
I'm using the RJ Speed interior #1531 also available from Tower stock #LXDADB
Geno-Machino is offline   Reply With Quote
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5973 04-20-2017 07:27 PM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
