Like Tree236Likes
Old 11-12-2012, 11:44 AM   #2626
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
After the beating mine took at the GORC Im thinking about getting a new body, all the traction rolls I got in the main killed it. So far the 68 camaro has worked the best for me, although I have a Cuda body sitting here unpainted. Ill probably just get the camaro again.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline   Reply With Quote
Old 11-12-2012, 11:52 AM   #2627
I fully understand the USVTA rules and because Novak helped to create the class so USVTA stands behind them.
We do this too because ORCA made a special brushless system for our Mini series.
I do see however 8 esc's that aren't novak in the rule set on the website but why aren't the hobbywing esc's listed on the PDF?
I run the Cirtix by the way.
Some people are anti manufactures and that's fine, but a motor isn't going to cause you car to burst in flames if geared right.
I had a Novak 10.5 way over geared in my SCT and all it did was stop. It was somewhere like 250F-300F......
I've never seen an on road esc flame! If plugged in backwards, (Operator error) it was just a puff of smoke.
I tried the javelin, but like the Boss 302 better. To bad the front of the Boss is so weak and flimsy.
Shoo Goo and some vinyl screen made it strong though.
Jeff Cohen
www.rcgears.net, www.carcar.ca, www.trukz.ca
Thanks to my Sponsor: Shred-A-Can Metal Recyclers LTD
www.shredacan.com
chongo is offline   Reply With Quote
Old 11-12-2012, 11:59 AM   #2628
savageboy69's Avatar
Trader Rating: 88 (100%+)
ive seen 3 novak escs burn a car down, and these guys had them setup up correctly and ran them for multiple races through out the year then POOF, this was in offroad mind you but still after seeing that its hard to run a novak
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 11-12-2012, 12:03 PM   #2629
Ive only seen 1 on road burn but I believe he said he found out he had some wires get together, that was a novak. Ive seen alot more in off road burn, none were Novak. Some very fierce...a 4s going up puts on a hell of a show
Old 11-12-2012, 12:09 PM   #2630
yes a very bright and smokey show and i love it when the owners get pissed when you throw the car off the track, im pretty sure me throwing it is the least of the damage you have to worry bout
XB8 2016
XB8-E 2016
XB4 2017
Old 11-12-2012, 12:13 PM   #2631
rcsuicide's Avatar
I've got a question for those of you who run a Novak Ballistic 25.5 and a Novak GTB2 ESC. Has your VTA ever stalled after rolling to a stop? For some reason my VTA will not move after the car has come to a complete stop. If somebody gives it a push it will go just fine. I have already run Novak's Hall Sensor Test™ on my GTB2 and all the LEDs show that the timing sensor is working 100%. I also swapped out the sensor wire just to make sure it not a wire issue. But the car still does not move from a dead stop!
rcsuicide is offline   Reply With Quote
Old 11-12-2012, 12:24 PM   #2632
Make sure your 3 timing screws arent too tight. That happened to me when I first got into it. Just literally snug them, dont tighten them. Soon as I fixed that (thanks to Darkside) All was good.
Old 11-12-2012, 12:25 PM   #2633
My LRP went up in flames in off road after a hard landing!
A buddies 4s lipo went up and it was epic! Buggy was fine!
We even had flames shooting out of a nitro truggy at the clutch bell!!
Jeff Cohen
www.shredacan.com
Old 11-12-2012, 12:37 PM   #2634
wwddww34's Avatar
Trader Rating: 9 (91%+)
Yes. I had the same thing happen to me at the USVTA Southern Nationals. I had a Ballistic 25.5 and a Speed Passion Cirtix Stock Club ESC. My VTA just would not start moving after coming to a complete stop. I replaced the Speed Passion ESC with a brand new Novak Edge ESC and the problem disappeared.
There was nothing wrong with the Ballistic motor, it was the ESC that had a problem. So my guess is that you may have something wrong with the GTB2 ESC. It could be a bad sensor input or a bad motor drive circuit.
wwddww34 is offline   Reply With Quote
Old 11-12-2012, 12:40 PM   #2635
rcsuicide's Avatar
I checked the 3 timing screws and just made them snug. The car still does not move from a dead stop. This $uck$ bad!
Old 11-12-2012, 12:42 PM   #2636
rcsuicide's Avatar
So you're saying that I should get a different ESC (maybe and Edge)? That will take some time for me to save up $100.00. Does anybody want to buy a used GTB2?
Old 11-12-2012, 12:57 PM   #2637
Odin544's Avatar
Trader Rating: 93 (100%+)
Originally Posted by robk View Post
So how do you propose we enforce this? Not that what i think has any bearing on anything
Don't have a good answer for that. Ideally you have racers that don't try to get passed the rules. But everyone knows thats not gonna happen. It's racing. Everyone wants an edge.
BTW, My comment "regardless of what RobK or anyone else thinks" was to simply say your opinion or anyone else's wont change my opinion of the rule. If you allow it at races you run then thats up to you.
If something is in the rule book and its too difficult to police then maybe it shouldn't be in the rule book, or maybe all that is needed is to define what is acceptable use of traction compound and whats not.
And no I'm not saying the rules need to be changed. Just clarified. Someone new should be able to read the rules and have no question as to what's allowed and what's not. I had my wife read that specific rule, she doesn't race, and her thought was the same as mine.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 11-12-2012, 01:02 PM   #2638
I just take the screws till they stop with little pressure on the end bell then about 1/8th turn. What I had thought was "snug" before turned out to be too much and what you described is exactly what mine was doing. Put a year on it since without a single issue.
Old 11-12-2012, 01:03 PM   #2639
Have you tried another motor?
Have you called Novak? Warranty maybe.
Jeff Cohen
www.shredacan.com
Old 11-12-2012, 01:07 PM   #2640
wwddww34's Avatar
It's just my opinion. All I'm saying is that if I had to start troubleshooting a VTA motor/ESC combo, I would start looking at the ESC first. You already did the Novak Hall Sensor Test, so that rules out the timing sensor and sensor wire from being faulty. Using process of elimination, the next thing to check would be the ESC's drive output. Has your GTB2 been used to drive a modified motor? If so did the ESC overheat?
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 5996 06-21-2017 06:50 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
svturtle
