Like Tree309Likes
Old 11-07-2012, 10:39 PM   #2506
Originally Posted by PROMODVETTE View Post
That would come out to 3.84 and most likely fine depending on how large the track is. If anything you can switch pinions to get you closer.
Yea I figure it be a good starting point. First vta car I brought the xray as a roller and that was the pinion installed. I have not advanced the timing on the motor yet.so should I try to get as close to 4.0 FDR as possible?
bigtee is offline   Reply With Quote
Old 11-07-2012, 11:14 PM   #2507
Trader Rating: 57 (100%+)
I ran mine at max timing with 3.8 fdr at the GORC. It come off after the 8 min main at 140 degrees exactly. Some guys were running closer to 3.7 some probably 4.0. Anything around that should be good, but the final ratio is ultimately going to be based on your track size.
PROMODVETTE is offline   Reply With Quote
Old 11-08-2012, 05:19 AM   #2508
orcadigital's Avatar
Trader Rating: 61 (100%+)
4.0 is a safe starting point. Check temps at 1 min (should be less then 110) and then every 2 min after (should not get higher then 160). If it does, you need to determine why.
Track depends, but most of us were running 3.6 to 3.8 at the GORC. I was at 3.73 and should have gone lower but was more concerned with my TC really. Nashville I was running a 3.5, One Lug I ran a 3.8. At GORC I came off at 125 consistently, but I am also running a motor fan.
Motor timing, as well as the quirks of each motor will have different gearing/timing requirements to be optimal.
Desoto Racing * Serpent America * Boca Bearings
"I was doing fine until about mid-corner when I ran out of talent."
orcadigital is offline   Reply With Quote
Old 11-08-2012, 07:57 AM   #2509
DontChangeUSVTA's Avatar
Originally Posted by Evoracer View Post
The drift 1969 Mustang body should be left as a choice for each group; not put on the official list of approved bodies. It's in no way a vintage reproduction Trans Am body. Although this may be the only "resto-mod" body we'll see, it's still not within the spirit of the class.
+1 to the above.
If we're going to start stretching, then the DeTomaso Pantera should be on the list since it actually did race in Trans Am.
-1 to the last sentence. Italian sports cars should not be added to USVTA.
There is no need to change USVTA Rules. They are working great!
USVTA is why I started into this R/C hobby. I love it!
Spec-R R1 - HPI #17519 1966 Mustang GT - Novak Ballistic - HobbyWing Justock ESC
HPI Racing Vintage 8-Spoke Wheels and Tires - Team EAM 5000mah 70C Lipo Battery
DontChangeUSVTA is offline   Reply With Quote
Old 11-08-2012, 09:04 AM   #2510
snoopyrc's Avatar
I disagree on the same grounds that keep the Pantera and the Corvette out of the list. We are representing a range of years from the TA at its peak. Same reason the 78 Trans Am is not on the list. This Mustang is 69. Right in the middle of it. And you dont want it in because of accuracy of representation? By that logic the Parma shells should be pulled off the list because they arent even close to looking like what they are supposed to be. (Sorry Parma, No offense.)
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 11-08-2012, 09:33 AM   #2511
rcsuicide's Avatar
If we were to use that logic (i.e. representing a range of years from the TA at its peak) then the 1967 Corvette Stingray falls into that range of years and should be added to the list. The Golden Era of U.S. Trans Am racing was from 1966 to 1972.
rcsuicide is offline   Reply With Quote
Old 11-08-2012, 09:40 AM   #2512
wwddww34's Avatar
Trader Rating: 9 (91%+)
I brought up the '67 Corvette Stingray about 2 years ago and I was told by the keepers of the USVTA Rules that if the body was not found on the roster in this web page --> http://www.trans-amseries.com/
then it was not going to be added to the USVTA list of approved bodies.
wwddww34 is offline   Reply With Quote
Old 11-08-2012, 09:43 AM   #2513
al dente's Avatar
I really think the corvette should be allowed. It is a great looking shell that looks sweet on the track.
But hey, I don't run vintage, I don't own a tc chassis, so my opinion doesn't count for much.
Team CRC / Dumper's Speed Shop / Team Scream Racing / Black Art
RC America / FB/FX / Colorado On Road RC Club
5280 Raceway (5280raceway.com) home of the MILE HIGH INDOOR CHAMPS April 20-23, 2017
al dente is offline   Reply With Quote
Old 11-08-2012, 09:43 AM   #2514
+1
Old 11-08-2012, 09:44 AM   #2515
where is my javilin body then
rescue119 is offline   Reply With Quote
Old 11-08-2012, 09:50 AM   #2516
FauxMako's Avatar
AMC Javelin is listed several times ...
http://www.trans-amseries.com/Roster.html
Mike
3 3Racing Sakura Zeros: Mustang Boss VTA // Lexus LFA USGT // MazdaSpeed 6 TC
Mini M03 & M05
Life is better with a soundtrack
FauxMako is offline   Reply With Quote
Old 11-08-2012, 09:55 AM   #2517
Meradin's Avatar
Trader Rating: 19 (100%+)
Isn't is also right up front on the header picture?
Better than Randy, Adam said so!
Second thought...I don't trust Adams, they make up everything!
"Leave it to Steever", custom paint masks, decals, and paint.
Meradin is offline   Reply With Quote
Old 11-08-2012, 10:02 AM   #2518
There are six Javelins on the roster ...
  • Car # .. Year .... Car ............... Owner .................... Driver .................... Hometown .............. Original Driver
  • # 3 .... 1968 .... AMC Javelin .... David Feece ............ David Feece ............ Los Gatos, CA ......... Peter Revson
  • # 6 .... 1969 .... AMC Javelin .... Craig Jackson .......... Craig Jackson .......... Paradise Valley, AZ ... Jerry Grant
  • # 6 .... 1970 .... AMC Javelin .... Bruce Canepa .......... Bruce Canepa .......... Santa Cruz, CA ........ Mark Donohue
  • # 1 .... 1972 .... AMC Javelin .... Stephen Sorenson .... Stephen Sorenson .... Morgan Hill, CA ........ George Follmer
  • # 2 .... 1972 .... AMC Javelin .... Ken Epsman ............ Ken Epsman ............. Saratoga, CA .......... Roy Woods
  • # 2 .... 1972 .... AMC Javelin .... Ken Epsman ............ Scott Rubin ............. Saratoga, CA ........... Vic Elford
Old 11-08-2012, 11:15 AM   #2519
The 67 vette is a nice body,IIRC the vette is classed as a sports car, not a sedan. I don't think the Corvette was ever allowed to run TA. Don
DLS II is offline   Reply With Quote
Old 11-08-2012, 11:22 AM   #2520
wwddww34's Avatar
I agree with Don. Out of all the pictures I have seen of U.S. Trans Am racing (http://www.historictransam.com/EventPhotos.html), not a single one has a Corvette in it.
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 6004 08-07-2017 07:09 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
