Like Tree309Likes
Old 11-04-2012, 07:58 AM   #2446
Originally Posted by Jerz616 View Post
The 40wt oil is going to feel like a really loose ball diff. Most are running between 1000cst to 2000cst in a gear diff. The way I was explained was if you have a high traction track you can run a lighter oil and if you have a lower traction track you can run a thicker oil. AE 70wt shock oil is 900cst and their 80wt is 1000cst. I would adjust according to the available traction you have. I run 2000cst in my cars at my home track which is low to med grip.
Originally Posted by GP40X View Post
XRAY recommends 600 to 800 cst for low traction tracks and 900 to 2000 cst for higher traction tracks for a rear differential. Softer oil increases rear reaction and harder (thicker) oils increase on power steering. if you are running a front diff the consensus is around 300,000cst oil.
Thanks for the help but both your statements contradict each other.
Jerz you say thick oil low-mid, thinner high bite
were as
GP40X quoting XRAY states the opposite.....
Also I think you meant softer oil increases rear traction and not reaction.
From researching the AE gear diff runs 30-50wt on team setups with a spool up front in TC on high bite tracks.
The Spec-R gear diff was in the 1000cst - 3000cst range.
I did notice one AE team drivers setup that he was running 2000cst on high bite carpet.
Well test and tune time.
Jeff Cohen
www.rcgears.net, www.carcar.ca, www.trukz.ca
Thanks to my Sponsor: Shred-A-Can Metal Recyclers LTD
www.shredacan.com
chongo is offline   Reply With Quote
Old 11-04-2012, 08:15 AM   #2447
GP40X's Avatar
were as
Yep, I meant traction. Fumble fingers strike again. Also that information is directly from the T3`12 instruction manual.
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 11-04-2012, 08:21 AM   #2448
Yup that's how I found your little typo....
Jeff Cohen
www.shredacan.com
Old 11-04-2012, 05:52 PM   #2449
OVA
OVA's Avatar
Trader Rating: 76 (100%+)
Default 25.5 novak
Hi
I ran my first VTA races last nite.. The question about usvta rules 25.5 motor..my endbell timing at 38deg and fdr gearing is 3.80 ..the motor came off the track very cool at 110 deg.. I did gear at 3.6 at first heat and it wasn't any faster than 3.8fdr
but I was able to shave .5 off my best paces...3.8 fdr
what is the best gearing and timing for this novak 25.5? large carpet track
OVA is offline   Reply With Quote
Old 11-04-2012, 06:58 PM   #2450
trytowin's Avatar
Originally Posted by OVA View Post
Hi
Try running 0 timing and 3.8 fdr, see what happens.
I'm just here to discharge my battery.
trytowin is offline   Reply With Quote
Old 11-04-2012, 07:35 PM   #2451
DARKSIDE's Avatar
Hi
Im not sure how big your track is...but our (Thunder RC),is around 95x50?..and Im at 3.6-3.8 at around 37 deg, depending on traction temp around 90-110deg...are you running a fan?
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 11-04-2012, 08:37 PM   #2452
OVA
OVA's Avatar
Hi Darkside
yes I;'m running the fan and gearing at 3.8 with 38deg on the motor..I think our track is 60X100 here the video of our track
http://www.youtube.com/watch?v=VRrjk...layer_embedded
Old 11-04-2012, 09:11 PM   #2453
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Hi Darkside
Ova that's a very nice size track looks like a fun place to race
Had a good flow to it
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 11-05-2012, 05:35 AM   #2454
Hi guys. I don't know if i asked this before or someone else do it before but according the USVTA rules we need to put in the car a pilot figure. But who made this piece and where can i buy it???
Marcelo
MARCELO CAMPOS is offline   Reply With Quote
Old 11-05-2012, 05:39 AM   #2455
DARKSIDE's Avatar
Driver Figure part numbers (ANY suitable 1/10 driver figure is legal-these are readily available examples)
HPI
#104815 INNER BODY SET FOR DT-1 TRUCK BODY
Associated
6180 Driver, unpainted, 1:10
McAllister
#423 Stock Interior and Driver
#419 SPRINT CAR DRIVER
Old 11-05-2012, 07:17 AM   #2456
HPI
Associated
McAllister
Darkside, thanks a lot. But where can i find it?
Towerhobbies has only the HPI pilots. I need to see the others..
Marcelo
Old 11-05-2012, 10:04 AM   #2457
IndyHobbies.com's Avatar
I just finished building a Tamiya F1 car. They have some awesome drivers. Perfect for VTA too. The 1/10th driver figure that came with the car would be a nice scale choice for VTA. I put the face shield on him. That didn't come with the kit. Just cut it from scrap lexan.
Next time you are at your LHS or looking on line, check for Tamiya F1 driver figures. There are several they make.
http://www.tamiyausa.com/product/ite...uct-id=0225031
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 11-05-2012, 10:28 AM   #2458
savageboy69's Avatar
Trader Rating: 88 (100%+)
i just ran my firs vta race last weekend my car is a 415 msxx mre and im running the tekin rs pro and tekin 25.5, ive noticed these motors take a bit of time to get the right timing and gearing just right, our track is like 90x50 or somewhere around there and i ended up running 30 degrees on can with a 4.0 fdr, i still have to do some more testing, id like to lower the fdr a bit and see how it runs, im coming off the track at 150 degrees with no fan, maybe add some more gear and less timing
Xray|Rc America|Hudy|FX engines|Tekin|SOR graphics|LFR|Ogio|SRT servos|
XB8 2016
XB8-E 2016
XB4 2017
savageboy69 is offline   Reply With Quote
Old 11-05-2012, 10:29 AM   #2459
Default new to vta
building a vta car. chassis i am using is either 08 or 09 xray . i will be installing the novak edge esc with ballistic 25.5 blue label motor what i need is a good starting point for gearing and chassis setup shocks, ride height, front and rear sway bar,ect i brought the chassis as a roller it came with rear ball diff and a one way up front. thank in advance for any advise giving
bigtee is offline   Reply With Quote
Old 11-05-2012, 11:12 AM   #2460
Can i use this pilot from proline?
http://www.amainhobbies.com/product_...Interior-Clear
Marcelo
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 6004 08-07-2017 07:09 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
