Like Tree84Likes
Old 09-29-2012, 02:42 PM   #1936
GundamWZero's Avatar
Send a message via MSN to GundamWZero Send a message via Yahoo to GundamWZero Send a message via Skype™ to GundamWZero
Default This can't be real, right?
Originally Posted by IndyHobbies.com View Post
I purchased mine direct here: http://www.hobbypartz.com/98p-40c-50...-hardcase.html
They came with the removable pigtails when I bought them. I believe you can get them with soldered in tails too if you prefer. I have had some grit get into the holes where the banana plugs connect. Soldered versions would prevent that.
I also bought their chargers which I've been pleased with too: http://www.hobbypartz.com/thac6smbachw.html
99.9% of the time, I'm a LHS guy through and through, but when I bought these GENS Ace batteries the reviews were outstanding and the cost was less than half of what I was seeing in the hobby store for a similar battery. Since I'm paying for two of us to race in my house, it was really the only way I could afford to dump all my NiMH stuff ($$$) and start over with lipos. That was my justification anyway at the time. You can tell, I still feel guilty about buying online instead of locally.
Dude... these prices has to be a typo, right? If they had a saddle configuration for lipos, I would have bought two to three packs already!! I am going to stary buying packs next moth from these guys....
"People tend to get upset because they don't get what they ask for... then complain when they get what they deserve." - R.E.Jacobs
‎"We fight not because we hate what's in front of us...
We fight to protect whats behind us."
GundamWZero is offline   Reply With Quote
Old 09-29-2012, 03:34 PM   #1937
IndyHobbies.com's Avatar
Those are the right prices. All I can figure is they are a direct source. Here's the review I read on Big Squid. Convinced me: http://www.rc-battery.com/app/menu.p...show_new&id=44
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 09-29-2012, 06:07 PM   #1938
These prices are correct, that is why they sell out so fast.
Goal Achieved....Not Dead Last.
mooby64 is offline   Reply With Quote
Old 09-30-2012, 08:27 AM   #1939
rigelkent09's Avatar
Trader Rating: 40 (100%+)
hey guys, i need some advice here, im new to VTA racing, i got a tc6 from one of member here, the car has novak edge esc and novak 25.5 balllistics motor, the car currently has 75T spur/ 39t pinion 48 pitch, my question is the gearing right for the class??or do i have option to gear up to gain more speed? if so? any recommendation for gearing??i find the current set up slower,thanks.
rigelkent09 is offline   Reply With Quote
Old 09-30-2012, 08:41 AM   #1940
stro3579's Avatar
Trader Rating: 20 (100%+)
It depends on the size of the track you are running on. But to start that gearing is perfect. I would try and get away from the 48 pitch and get 64 pitch.
stro3579 is offline   Reply With Quote
Old 09-30-2012, 08:50 AM   #1941
track size is 72 feet x 32 feet, can you give me perfect gear set up for 64 pitch that will work best on the size of the track? thanks a lot for the help..
Old 09-30-2012, 09:24 AM   #1942
stro3579's Avatar
Start exactly where you are with 30 degree timing. Switch you 75th spur and 39th pin over to 64 pitch. The car will run more free and smoother with 64 pitch.
Old 09-30-2012, 09:37 AM   #1943
thanks for the input, i will start looking for 64 pitch, problem is associated dont have 64 pitch, are all 64 pitch gears will fit in directly in my tc6??thanks again for the help...
Old 09-30-2012, 10:15 AM   #1944
???E-Racer's Avatar
I asked a guy at the hobby shop in my area and the C rating doesnt matter.
A 25c pack will perform just as well as a 40c battery. C rating doesnt determine
how many amps a pack will push out to the esc. I always thought the Millamps
Hours is the most important thing of a battery. I just went Lipo and I know
my stuff is gonna be much faster than Nimh packs I was using.
I also went hard-case because of all the Lipo accidents I see with soft-case packs. Duratrax packs are fairly cheap to afford.
I bought 4 4000 25c packs with deans ends on them for under $160.
The top of the line packs by tracpower are $100-120 each.
Four tracpowers would have costed over $400. That's insane for 4 batteries.
Novak, Viper, LRP
4wd Slash Platinum,4WD SC10,Stock Slash Latemodel Oval,Losi Slider,E-firestorm Bomber, Team Terribles,www.rkhobbies.com,GOLFLAND USA
???E-Racer is offline   Reply With Quote
Old 09-30-2012, 11:21 AM   #1945
alloyslash's Avatar
Trader Rating: 19 (100%+)
The C rating has everything to do with the available " amp current" that a pack will push out. I think its something like 5 amps per c rating( ex; 20c=100a of current, 40c=200a of current). The milli amp hour figure determines the amount of stored energy, which is "runtime"
Pemberton SJ27 / Tekin RS / Cooper D4SS 17.5 / EAM 5000 / Futaba 9551 / 17.5lm
Pemberton SJ27 / Tekin RS / Bullet 13.5 / EAM 5000 / Savox 1251 / 13.5 Pro EDM
TLR22 / Tekin RS / D4SS 6.5 / Futaba 9551 / ORCA 6000 /SCMOD,
F14 carpet Oval Chassis too!
alloyslash is offline   Reply With Quote
Old 09-30-2012, 11:27 AM   #1946
Send a message via AIM to Jonesy112
its 5 amps for a 5000mah battery, 4 amps for a 4000 mah battery, 3 amps for a 3000 mah battery, and so on
But everything else is correct. But the speedo can only pull so much, so in theory nothing over about a 30C battery will make a difference (that would mean the speedo is trying to pull 150 amps)
Michael Jones
RC America - X-Ray - Team EA Motorsports - RockStar Paint - Apex RC Proshop - ProOne Tires
Jonesy112 is offline   Reply With Quote
Old 09-30-2012, 02:38 PM   #1947
Jerz616's Avatar
Trader Rating: 49 (100%+)
Look for kimborough spurs. Get a 100t spur and a 50t pinion. That will put you right at a 4.0 fdr. The tc6 has an internal gear ratio of 2.0. You can add or subtract teeth on your pinion to gear higher or lower depending on your track. 4.0 is a good place to start though.
Ryan Gracey
XRAY T4'14/ORCA VXX/ORCA TX 5.0
XRAY XB8'14
Jerz616 is offline   Reply With Quote
Old 09-30-2012, 03:10 PM   #1948
personally, I use a 96 tooth spur when possible. Seem to have a bit for ability to change the pinion higher and lower without loosing the ability to move the motor. With 100 tooth spur, there have been a few times where I couldn't move the motor pinion combo far enough to make it work. 100 will work, just a bit more flexibility with 96 tooth if you haven't purchased yet.
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 09-30-2012, 04:26 PM   #1949
thanks for the help guys, is 96 tooth spur 50 tooth pinion will work best at my track size? ( 72 X 32 feet)..also where is the best place to buy that brand of spur??thanks.
Old 09-30-2012, 05:41 PM   #1950
Jerz616's Avatar
I run a 4.04 fdr at my track. Mikes hobby shop in Dallas. This is where the roar carpet nats were held. A 96/48 will give you a 4.0 fdr. If you go 96/50 you will have a 3.84. Sounds like your track is pretty tight. I would stay around a 4.0 to 4.1. Going to low you will never get to top speed on a short straight. Running a 4.04 I am getting to top speed before the end of our 90' straight. You can get those spurs at most hobby shops and online like amain or tower.
Ryan Gracey
XRAY XB8'14
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Electric On-Road 5929 Yesterday 08:12 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
