Like Tree238Likes
Old 09-14-2012, 07:36 AM   #1861
wwddww34's Avatar
Trader Rating: 9 (91%+)
Originally Posted by Jerz616 View Post
I run an R10 in my TC and have the program box for it. Does anyone know if I can use it on my Justock that I just bought. They look awfully similar. Just wondering if they are compatible.
It looks like there are a few parameters that can be programmed by using the Hobbywing LCD Program Box. You can also update the firmware on the ESC. I copied the following text and images from FalconSekido.com:
2 Features
. 2.4 The internal timing is always zero degree to complaint with the rules of SPEC races such as ROAR SPORTMAN.
. 2.5 Multiple protection features: Low voltage cut-off protection / Over-heat protection / Throttle signal loss protection.
. 2.6 Plenty of programmable items.
. 2.7 Easily programmed with the SET button, LED Program card, Professional LCD Program Box and USB Link Software.
. 2.8 ESC firmware can be updated through the USB adapter in the LCD Program Box.
The ESC can be loaded with many different firmwares by user himself.
The options with italic font in the above table are the default settings (factory settings) of the ESC.
(* The programmable items and the default settings maybe changed in different firmware versions without prior notification.)
wwddww34 is offline   Reply With Quote
Old 09-14-2012, 08:59 AM   #1862
robk's Avatar
Trader Rating: 22 (100%+)
Ok here is the problem, so let me try to nip this in the bud. Falcon Sekido sells these escs, and their part numbers like Darkside posted are ok. There is not like 6 versions of the escs or anything that i can see. Look for the justock.
CRC is also a distributor of the HW stuff as well, and i used their part number/name, not knowing where my test sample came from. Myron sent it to me after he tested it, and at first I didn't know Falcon had sent it to him. I thought he had possibly gotten it from a hobby shop, until he told me Falcon had. sent it for evaluation.
However, both names and numbers will be kept on the website to avoid any confusion because of who the esc was purchased from.
Web page updated, .pdf to be updated soon
Old 09-14-2012, 09:13 AM   #1863
DARKSIDE's Avatar
ok cool..thats works for me...
btw...Im sending you a red package too...lol
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
Southern Indiana RC Raceway
Independance On-Road Bash
July 1,2017
DARKSIDE is offline   Reply With Quote
Old 09-14-2012, 07:36 PM   #1864
GP40X's Avatar
You mean? Really? One of our biggest critics may have finally come around?
OH HAPPY DAY!
Bill
"I used to be disgusted, now I'm just amused."
Team Qik
CustomWorks Outlaw Sprint Car
Xray T3 2012 USVTA
GP40X is offline   Reply With Quote
Old 09-15-2012, 02:35 AM   #1865
howardcano's Avatar
Trader Rating: 35 (100%+)
Default Hobbywing Justock CLUB SPEC ESC
Is this correct? I thought USVTA WSCs were strictly non-updateable to reduce the possibility of someone using modified programs.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 09-17-2012, 08:04 AM   #1866
wwddww34's Avatar
Here's the video of VTA A-Main during the Texas Electric On-Road Series, Round #3...
http://youtu.be/2TxXkt5UHng
Old 09-17-2012, 08:24 PM   #1867
If someone has the knowledge and equipment to program a esc, then that someone wouldnt have a problem programing any esc.
Rojna is offline   Reply With Quote
Old 09-17-2012, 08:36 PM   #1868
Trader Rating: 49 (100%+)
Pretty sure that means timing can't be updated, and will always be Zero, soneone correct me if I'm wrong
SpeedMerchant Rev7
oceanhighz is offline   Reply With Quote
Old 09-17-2012, 08:52 PM   #1869
nashrcracer's Avatar
R/C Tech Charter Subscriber
and you don't think that someone couldn't update the gtb 2? how do you think they added xdrive?
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 09-18-2012, 05:25 AM   #1870
howardcano's Avatar
I was referring to updates to the resident software made through an existing interface that is accessible to the end user. The GTB2 does not have this feature.
That's not quite true. Some microcontrollers cannot be reprogrammed; the microcontroller would need to be unsoldered and replaced with a new one. Many also have copy protection so that the program cannot be read, requiring any new program to be written from scratch. Both circumstances increase the level of difficulty of cheating to the point where other methods are easier. I (and many other people) have the knowledge to write the software, but given a choice I would restrict my efforts to the easiest route. An existing interface that is accessible to the end user makes it much easier.
I will abide by whatever the rules are. It just seems to me that teching the ESC might be a bit more complicated in this case-- but perhaps no more complicated than having to open one up to inspect the boards for modifications. (Of course, an oscilloscope would be the most expedient way to tech, but I wouldn't want to take mine to the track.)
Howard Cano
Old 09-18-2012, 08:08 AM   #1871
rcsuicide's Avatar
Does anybody know why the Speed Passion Reventon Stock Club ESC is not available in the USA? It looks like it's only available in the UK and Australia.
2. Speed Passion Reventon Stock Club Race part number: SP000048
rcsuicide is offline   Reply With Quote
Old 09-18-2012, 02:30 PM   #1872
DontChangeUSVTA's Avatar
No.
There is no need to change USVTA Rules. They are working great!
USVTA is why I started into this R/C hobby. I love it!
Spec-R R1 - HPI #17519 1966 Mustang GT - Novak Ballistic - HobbyWing Justock ESC
HPI Racing Vintage 8-Spoke Wheels and Tires - Team EAM 5000mah 70C Lipo Battery
DontChangeUSVTA is offline   Reply With Quote
Old 09-18-2012, 02:48 PM   #1873
303slowdown's Avatar
Trader Rating: 21 (100%+)
Originally Posted by DontChangeUSVTA View Post
No.
Great input....
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 09-18-2012, 03:30 PM   #1874
robk's Avatar
I posted before that I was somewhat hesitant to approve this esc, despite the assurances that only the non-timing software specific to this esc can be loaded. In fact, I initially did not allow it when it was presented to me about a year ago.
So far there have been no instances of legality problems popping up with HW speed controls. I also have no problem pulling the approval the second I hear of problems.
I just wanted to offer more choices to those who think that there is "favoritism" toward manufacturers.
Old 09-18-2012, 03:32 PM   #1875
robk's Avatar
Check with speed passion on their availability. They gave an early unit for testing, but I don't know what the hold up is.
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 5996 06-21-2017 06:50 AM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
