Like Tree272Likes
Old 08-16-2012, 08:19 AM   #1576
DARKSIDE's Avatar
Originally Posted by JustWill75 View Post
Any word on the ESC 's you were testing?
Originally Posted by rcsuicide View Post
Are those the blue ones?
I hope so, because I have been told numerous times.
BLUE IS BETTER.
Originally Posted by PROMODVETTE View Post
I can think of one instance blue isn't better. In that circumstance its much better to release. So someone release the news!!
we hope to have the final verdict soon...the testing went well, but with everything the USVTA does, we want to make sure anything added to the rules is the right move for all the racers that currently and in the future race the class. We have to check and double check everything.
And like stated before...this is just test...and like any test, failure can happen
Originally Posted by k_bojar View Post
actually seen it both way, with success
I have mine attached to the body - but then again, I'm using HPI mini trophy driver in mine and he mounts nicely to the inside of the body with some tape
ditto...+1
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
'17 USVTA Summer Slam @ The Gate
July 28th-30th,2017
DARKSIDE is offline   Reply With Quote
Old 08-16-2012, 12:16 PM   #1577
Marv's Avatar
Originally Posted by dumper View Post
For those of you using a driver figure, how do you mount them? To the body or to the chassis somehow?
U.S. Vintage Trans-Am Racing Part 2-dscn4389.jpg U.S. Vintage Trans-Am Racing Part 2-dscn4388.jpg U.S. Vintage Trans-Am Racing Part 2-dscn4387.jpg
Marv is offline   Reply With Quote
Old 08-16-2012, 01:35 PM   #1578
Marv's Avatar
Novak ESC & Novak fan - - -
How do I tighten the female connectors in the fan plug?
The connection is too loose...
I've tried two different fans / same problem...
Do I spread / pinch the male pins (and hope I don't break anything)?
OR
Just get / make a Y harness & plug into receiver - the connector is tight when plugged into receiver port.
I still have 1 more fan to install (motor) and I'll need an open spot for a transponder - how may things can I jump off of the receiver?
ALSO - the ESC to receiver connection isn't real tight... Is this a concern?
Is this an option - http://www.shopatron.com/products/pr...ber=5721/135.0
Old 08-16-2012, 03:05 PM   #1579
beemerfan's Avatar
Trader Rating: 34 (100%+)
Attachment 959146
OR
The newer Novaks use a smaller pin/spacing on the fan plug than the old traditional JST style ones. They call it a "mini JST." I've had some success with spreading the pins and putting a drop of Shoe Goo on the base of the plastic to insure it doesn't come loose, but that is not an ideal solution and I've always worried about breaking off the pin. Some of the aftermarket fans I've bought came with a smaller micro plug that I used to make an adapter and that works better. This could also be adapted...
http://www.shopatron.com/products/pr...9.0.0.0?pp=10&
beemerfan is offline   Reply With Quote
Old 08-16-2012, 04:01 PM   #1580
hotrodchevy14's Avatar
Trader Rating: 106 (100%+)
thought i would share this..sorry for the quality...parts tree "z" from tamiya hornet/frog. Has convienent mounting hole on top of the helmet, so a simple screw throught the roof works.
...oh our lady of blessed acceleration, don't fail me now..
sponsored by:Team lint in my pockets racing...
hotrodchevy14 is offline   Reply With Quote
Old 08-16-2012, 04:23 PM   #1581
side view
Old 08-16-2012, 08:04 PM   #1582
Attachment 959146
OR
You can pull the pins out of the plug and gently squeeze them together so they grab the male pins tighter. I switch a transponder between two cars so I have to squeeze the female pins every so often and it works well. just don't over do it. I would not try to bend the male pins. its much easier to replace a female end if you mess it up. the male pins on the esc or receiver will be very difficult to repair.
3Racing Sakura XI 17.5 TC
Formula Rabbit (FGX conversion) 21.5
STRC LCG 2WD Slash 17.5
Serpent S120 13.5
6376vette is offline   Reply With Quote
Old 08-16-2012, 08:44 PM   #1583
Trader Rating: 57 (100%+)
I have some of the mini jst pins now and some housings on the way from the UK. Marv, if you want a couple of the pins I can throw them in an envelope and send em out. This way you can replace the worn out pins. Just PM me an address.
Edit - Massive picture on this link
http://img854.imageshack.us/img854/2595/001uiy.jpg
PROMODVETTE is offline   Reply With Quote
Old 08-17-2012, 12:45 AM   #1584
303slowdown's Avatar
Trader Rating: 21 (100%+)
I would connect it to the chassis. Their where a few guys traction rolling at nationals (Mario helped me with this before nats) so i told them to remount their driver to the chassis and fixed the problem . These cars weigh to much as is ,so why put even more weight up high.
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 08-17-2012, 01:38 AM   #1585
Marv's Avatar
PM sent - THANKS!!!
Old 08-17-2012, 01:48 AM   #1586
Marv's Avatar
Is anyone using a heat sink/fan on their 25.5 with a thermal compound media like Arctic Silver?
Old 08-17-2012, 02:00 AM   #1587
Marv's Avatar
Thanks for the info!
I don't want to screw up he ESC pins - I haven't even set it up yet...
Old 08-17-2012, 08:39 AM   #1588
IndyHobbies.com's Avatar
That's got to hurt! I can hear the driver screaming
Airbrushing Projects: www.indyhobbies.com/Airbrushing.html
"If you’re in control, you’re not going fast enough." – Parnelli Jones
USVTA #144
IndyHobbies.com is offline   Reply With Quote
Old 08-18-2012, 06:05 AM   #1589
snoopyrc's Avatar
If I had the ability I would make an interior tray for USGT or VTA that would have a roll cage with a fire extinguisher on the bar. It would have Sparco seats in it and the driver figure from the Wild Willy jeep. Lighted dash and anything else I can think of.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 08-18-2012, 06:58 AM   #1590
Marv's Avatar
My S2 RTR is now VTA ARR...
There's a few minor tinks and the itintial setup adjustments to make & then it's judgement day.
U.S. Vintage Trans-Am Racing Part 2-dscn4400.jpgU.S. Vintage Trans-Am Racing Part 2-dscn4399.jpg
U.S. Vintage Trans-Am [PICS & PAINT Discussion ONLY!!!] speedsterblade Painting, Designs, Graphics and Photography 6002 07-24-2017 08:34 PM
TeamNovak (U.S Vintage Trans-Am) NovakTwo Electric On-Road 329 12-07-2013 07:48 PM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
U.S. Vintage Trans Am Nationals: April 12th, 2008 squarehead Wisconsin & Illinois Racing 308 05-14-2008 07:56 AM
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
theproffesor
