Old 05-25-2014, 07:35 PM   #166
mac853's Avatar
Could anybody tell me if this x2 has got race charge mode?
Then i want also to know if someone has some information of this charging mode from elan r ac dc
Best regards
mac853 is offline   Reply With Quote
Old 05-25-2014, 07:48 PM   #167
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Best regards
The X2 (dual charger wit built in PSU) does NOT have race charge mode. On the single charge unit with built in PSU (Elan R ACDC) has it.
There is no plan for Elan to update the X2 from what I have been told.
The race charge mode is proprietary software designed to enhance performace of lipos in stock or zero boost classes. Alex Hagberg and Andreas Myberg and Py Tang used it at TITC and reported on Elan FB page earlier this year.
Hope that helps.
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 09-18-2014, 07:55 PM   #168
Joel Lagace's Avatar
Anyone know where i can buy the 90degree bullet connectors? Since the ELANGEARS does not respond to emails i thought id check here.
http://www.elangears.com/wp-content/...ries_main2.png
They call them the angle type connector...
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 09-18-2014, 09:16 PM   #169
CW22's Avatar
Trader Rating: 93 (100%+)
Go to SMC racing , they sell the charger conector.
look under wire or cable section.
CHRIS
Tamiya cars.
TRF, Muchmore racing.
CW22 is offline   Reply With Quote
Old 09-18-2014, 10:49 PM   #170
vabroom's Avatar
Here's one:
http://hotlapracingusa.com/index.php?l=product_list&c=6
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 09-22-2014, 03:50 AM   #171
Skiddins's Avatar
ANyone know how the plastic backing for the balance circuit board is attached?
The connector that connects the cable to the charger has come loose so I need to resolder it.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 10-04-2014, 04:00 AM   #172
pphaneuf's Avatar
I've got an Elan R ACDC here, and I have a few questions that the manual doesn't seem to answer...
During charging, what are the first and second numbers at the bottom?
The first on the left, I think it might amps, but it often says 4.0 when I've selected 1 amp charging, say? Or maybe this is an effect of the SMT mode? I seem to remember having tried it in the basic mode (which should be continuous), and the number not being the amps that I selected, but I might be wrong...
The one in the middle appears to be a counter, and at first it looks like it's updating every second, but it was *just* a bit bigger than the elapsed timer reading on the right (when converting the minutes to seconds)? And it seems kind of weird having two elapsed timers next to each others, counting the same thing in different units, no?
My last question is whether it's possible to change the volume or mute it? I haven't opened it yet, but I'm starting to be willing to do so.
Thanks in advance!
pphaneuf is offline   Reply With Quote
Old 10-04-2014, 07:13 PM   #173
thanks guys i saw that smc had the full cables... i want to make my own so ill order up them connectors..
thanks agian
www.rcottawa.com
Old 10-04-2014, 07:31 PM   #174
Trader Rating: 57 (100%+)
Thanks in advance!
From left to right...
Amps - MAH going into back - elapsed time
For the amps, what are you charging at 1amp? You should be charging 1000 times less than the capacity of the pack. Ex, 7000mah pack = 7 amps, 2500 mah pack = 2.5 amps
As far as the sound, no, you cannot change it.
PROMODVETTE is offline   Reply With Quote
Old 10-05-2014, 06:09 PM   #175
bigcracing's Avatar
Trader Rating: 32 (100%+)
Does anyone know who is selling the ElanR chargers I am thinking of getting one?
bigcracing is offline   Reply With Quote
Old 10-05-2014, 08:00 PM   #176
Trader Rating: 70 (100%+)
Markus is offline   Reply With Quote
Old 10-12-2014, 08:16 AM   #177
pphaneuf's Avatar
Ah, thanks, that makes sense, the number was indeed close to my battery's rating when charging it after a discharge cycle.
I wasn't in a hurry, charging the battery while putting my new car together, so I figured I'd slow charge, to avoid straining the battery when I didn't need it.
Another question for you... I went through the settings, and all of them but one are explained in the manual: "power mode", with on/off? What does that do?
Old 11-03-2014, 03:41 PM   #178
Default Manual for Mini AC/DC
Where can a digital copy of the manual for the mini be found? I did not see it on the website.
Tibbar110 is offline   Reply With Quote
Old 11-08-2014, 07:56 PM   #179
I also want to know what the "power mode" does, as it's not in the manual. Also would be nice for a digital copy of the manual too
TLR 22T and Yokomo YZ-2 and 4
www.corvictoria.com
brew99 is offline   Reply With Quote
Old 05-13-2015, 04:01 PM   #180
Originally Posted by Skiddins View Post
Thanks guys.
So it's the total being drawn that actually matters?
I was worried about going over 10A on the extra outputs (can't remember where I got 10A from) so I haven't pushed it.
This means I can use my tyre sander as well as charging.
Glad to read this post before I commit to purchasing as my previous charger (Graupner Polaron Sports) crapped out when I tried to use my MM Tyre sander.
Thanks for sharing your insights. Will buy this little beast.
Too bad it doesn't read IR,
Stray monkey is offline   Reply With Quote
