Old 04-08-2013, 09:14 PM   #901
Microtome's Avatar
Default Well... That all depends
Originally Posted by Autocratic View Post
How tough is this car? Looking for a fast chassis that can handle wooden boards well.
For me....."Fabergé egg" comes to mind.
Really all depends on your skill level.
www.GoodentiteRacing.com
Microtome is offline   Reply With Quote
Old 04-08-2013, 11:27 PM   #902
spunkysandoval's Avatar
Trader Rating: 124 (100%+)
Thumbs up
I would say its very durable. I have the soft arms on my car and I gave it a few hard crashes over the weekend and didn't break a thing. One crash was so violent that it ejected my ESC and nothing broke.
Here is a quick pic of mine
Tekno RC - VBC Racing D06 - Axial Rubicon and Wraith - SC10.2 - Hitec - Speed Passion - Werks - lrhhobbies.com
spunkysandoval is offline   Reply With Quote
Old 04-09-2013, 09:24 AM   #903
Originally Posted by Dave Johnson View Post
Hey potoczak! Well because the wildfire rotates so well and doesn't scrubs speed in the corners, it should be a obvious standout for vta. Remember " vta races are won by rear toe" or I should say lack there of. As for hints, certain parts are beefed up and moved around for the "impacts" of vta. Better weight distribution to compensate for the offset of vta tires. Drivetrain efficiency is going to be awesome, It will drive like a very dialed touring car even with the aero challenged vta body's. testing setups and layouts now.
As for droop , I use an old school gauge off the bottom of the chassis, no droop blocks. So the numbers are from the (hold under the chassis to the arm method). Ok as far as links. If your looking down on your car. (Bumper north, rear south) the front links are upper inner holes and the rear links are lower inner if that makes sense?
Hope that helps.
I'm hoping for an extra hole low in the motor mount so VTA racers can run smaller spurs without motor screw access issues.
DavidNERODease is offline   Reply With Quote
Old 04-09-2013, 09:37 AM   #904
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Looks good! You are getting better at painting your bodies.
IIGQ4U is offline   Reply With Quote
Old 04-09-2013, 11:06 AM   #905
Potoczak's Avatar
Trader Rating: 107 (100%+)
Looks good! Now let's see some goods under the body
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 04-09-2013, 01:13 PM   #906
ChadB.'s Avatar
Trader Rating: 16 (100%+)
Anybody know where I can get the updated Wildfire car in the US?
Chad Burdick
*Mugen Seiki*Flashpoint Racing Products*9th Annual Timezone Grand Prix July 13th-16th 2017*Unique Air Design*TimezoneRacing*RoseCityScaleRacers* Daves RC Track
ChadB. is offline   Reply With Quote
Old 04-09-2013, 01:21 PM   #907
IIGQ4U's Avatar
RCMart just added it to their site last week I believe, so it should show up at CRC soon.
Old 04-09-2013, 02:57 PM   #908
Microtome's Avatar
Default Tight Squeeze
+1
FDR in the VTA class at the Gate is below 4.0 some guys running as low as 3.6 maybe even 3.5. I would like to keep the spur gear as small as possible. When I run a large pinion I have top brace clearance issues. I was able to file the top brace just enough to make room for a 47T, but I'm not sure how much larger I could or would want to go with the pinion in order to get my FDR where it belongs.
If we had a couple of options for different belt pulleys that may help as well.
Old 04-09-2013, 07:42 PM   #909
Potoczak's Avatar
Yes a redesign of the motor mount would be nice.
Pete Potoczak
Old 04-11-2013, 11:18 AM   #910
Default Eccentric Cams
So can you actually rotate the eccentric bearing holders without loosening the upper bulkhead screws? You can't for example on a Sakura because the upper bulkheads clamp down pretty hard on the eccentric bearing holders (without shimming).
Old 04-11-2013, 11:20 AM   #911
I am able to.
Old 04-11-2013, 11:26 AM   #912
That is awesome!
Old 04-11-2013, 08:24 PM   #913
Will this spur gear work? Thanks
http://www.amainhobbies.com/product_...Gear-H-84T-48P
Chrisg23 is offline   Reply With Quote
Old 04-11-2013, 09:36 PM   #914
IIGQ4U's Avatar
What class do you run? If you run 17.5 blinky, you would need a pinion near the 40 tooth range. Your 84 tooth 48 pitch spur is equivalent to a 112 tooth 64 pitch spur gear.
Old 04-12-2013, 02:11 AM   #915
I'll be running VTA. I'm not concerned with the ratio, I'll be running 78/35 for a 4.2 FDR. I just want to know that it will fit on the car properly cause I can't find a VBC 78t 48p spur. So basically, will this spur mount on the wildfire;
http://www.amainhobbies.com/product_...pur-Gear-H-78T
SEO by vBSEO 3.5.0
