Old 04-06-2013, 11:47 PM   #886
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Like Spunky, I too purchased a VBC Wildfire this week and had the opportunity to race it for the first time today.
Unfortunately, I was unable to finish my car until just before the second qualifier.
Prior to running the second qualifier, I hadn't raced onroad since December, 2009. After running my second qualifier, I ended up second qualifier in the A.
In the A, I was pacing the leader when I made a mistake coming up on lapped traffic. I began to reel in the leader, but made another mistake that shut the door on me and a potential victory.
Second place isn't too bad with a 3 heat field, but the car itself was/is a winner.
There was no other car on the track today that had as much corner speed as the Wildfires.
I have owned XRAY, Tamiya, Associated and Losi onroad cars and never has any one of them been as good as the Wildfire on day 1.
The build, the parts quality, unique parts and insane performance makes this car a serious race winning machine... Do not sleep on this car!
IIGQ4U is offline   Reply With Quote
Old 04-07-2013, 12:25 AM   #887
spunkysandoval's Avatar
Trader Rating: 124 (100%+)
Pretty impressive work IIGQ4U! Your car was definitely faster than the race winner. Can't wait to run again!
Tekno RC - VBC Racing D06 - Axial Rubicon and Wraith - SC10.2 - Hitec - Speed Passion - Werks - lrhhobbies.com
spunkysandoval is offline   Reply With Quote
Old 04-07-2013, 06:24 AM   #888
Potoczak's Avatar
Trader Rating: 111 (100%+)
Originally Posted by Dave Johnson View Post
Great to here that worked for you!!! The car has very good corner speed with that setup!!!! Sorry I haven't been on here much, real busy. ( testing the Vbc f1 car at uf1 series and running the Canadian nats). Now the latest from Vbc, I've been working on "the ghost" first touring car from Vbc made for VTA!!!!!!!!
Inspired by me. More info soon
Hi Dave, that's awesome news that VBC is coming out with a Vta specific car. Cant wait to see it. Any hints on what you guys are doing? Also on your starting setup for asphalt were your droop settings above ride height? Also what camber link positions did you use on the bulkheads?? Thanks for any info you could give.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 04-07-2013, 06:49 AM   #889
Hey potoczak! Well because the wildfire rotates so well and doesn't scrubs speed in the corners, it should be a obvious standout for vta. Remember " vta races are won by rear toe" or I should say lack there of. As for hints, certain parts are beefed up and moved around for the "impacts" of vta. Better weight distribution to compensate for the offset of vta tires. Drivetrain efficiency is going to be awesome, It will drive like a very dialed touring car even with the aero challenged vta body's. testing setups and layouts now.
As for droop , I use an old school gauge off the bottom of the chassis, no droop blocks. So the numbers are from the (hold under the chassis to the arm method). Ok as far as links. If your looking down on your car. (Bumper north, rear south) the front links are upper inner holes and the rear links are lower inner if that makes sense?
Hope that helps.
sponsors: Burleson racing #13,redbull, Dj paints!!!!, KT RACING!, outlaw Rc Motorsports, protoform.
Dave Johnson is offline   Reply With Quote
Old 04-07-2013, 06:58 AM   #890
Potoczak's Avatar
Hope that helps.
That makes perfect sense. Thank you for the quick response. Can't wait to try out the new Vta ride. When are you expecting it to be available ?
Pete Potoczak
Old 04-07-2013, 03:06 PM   #891
IIGQ4U's Avatar
Hey potoczak!
For the rears, do you measure from the bottom of the hub or the A-arm?
Old 04-07-2013, 08:59 PM   #892
Hey guys I measure from the bottom of the rear hub...
As far as the a availability of the ghost, we'll have to wait until at least after the USVTA nationals! It will be ran there for final "tweaking", but then expect shortly after....
Now Back to testing!
Old 04-08-2013, 03:36 PM   #893
IIGQ4U's Avatar
Swapped the ESC in my Wildfire and re-wired the car since it was a disaster to prepare for the race this past Saturday:
VBC Wiring by IIGQ4U, on Flickr
Old 04-08-2013, 04:23 PM   #894
Odin544's Avatar
Trader Rating: 93 (100%+)
Your steering links are different from left to right. You have it longer on the left.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 04-08-2013, 04:24 PM   #895
Jerry P's Avatar
Trader Rating: 44 (100%+)
Nice looking car.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 04-08-2013, 04:25 PM   #896
IIGQ4U's Avatar
I Adjusted my roll center and haven't put it on the setup station. Thanks!
Old 04-08-2013, 04:30 PM   #897
Jerry P's Avatar
I think he means the ackerman setting is different. they are in different holes.
Jerry P
Old 04-08-2013, 04:41 PM   #898
IIGQ4U's Avatar
Ahhh! Yeah, I fixed that earlier.
Thanks Jerry.
Old 04-08-2013, 05:56 PM   #899
Potoczak's Avatar
Very nice job on the wiring!!
Pete Potoczak
Old 04-08-2013, 06:59 PM   #900
Autocratic's Avatar
Trader Rating: 26 (100%+)
How tough is this car? Looking for a fast chassis that can handle wooden boards well.
Thanks to my sponsors for 2015!
XFactory RC | Proline Racing | Fantom Racing | Avid RC | Speed Passion USA | Factory1 | Hy-Traction Juice | Mike's Hobby Shop
Autocratic is offline   Reply With Quote
