Old 06-11-2012, 08:57 PM   #76
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Whats a good starting point for pinions with the stock spur for 17.5 blinky class on a small to medium indoor carpet track? Thanks.
Blitzrockey is offline   Reply With Quote
Old 06-12-2012, 05:57 AM   #77
gijoe64's Avatar
Trader Rating: 27 (100%+)
Can we get some team guys to get on this fourm and talk about the car? I would like to hear from the guys that have already raced the car or have information on performance.
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 06-12-2012, 06:10 AM   #78
snoopyrc's Avatar
Originally Posted by CypressMidWest View Post
Actually the car looks pretty sweet. May have to get one just so I can run USGT, and then my RobK can't dismiss my arguments as those of a "pan-car only" guy.
Thats a lot of car for USGT but I am not one to judge. I like nice things too. I like this but I just invested in something else that I want to try first.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 06-12-2012, 06:22 AM   #79
What would you like to know?
www.teamcrc.com, www.teamscreamracing.com, Outlaw RC Motorsports, KO Propo USA, www.crcraceway.com, Dumper's Speedshop, FB/FX Paint. 38.4mm>38mm, 9 degrees does not = Zero end of story. Vice-President of the F1 Pink Flame Posse
dumper is offline   Reply With Quote
Old 06-12-2012, 07:46 AM   #80
hanulec's Avatar
Trader Rating: 23 (100%+)
Dumper - when are we going to see you outside on the asphalt at Jackson??
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-12-2012, 08:07 AM   #81
Rick Vessell's Avatar
Yes, Ray, what would you like to know?
Rick Vessell is offline   Reply With Quote
Old 06-12-2012, 10:58 AM   #82
JeanC's Avatar
Can anyone of the team guys tell us how did the car felt in reedy? The track was quite slippery and how did the car behaved?
Car: VBC WildFireD06 / VBC Flash04
ESC: VRITRA VXX COMPETITION
Motor: LRP X20
Body: Protoform LTCR / Tamiya F60
JeanC is offline   Reply With Quote
Old 06-12-2012, 11:01 AM   #83
JeanC's Avatar
I see they have redone their web... The car is available at their web, do they ship to us?
Motor: LRP X20
Old 06-12-2012, 12:18 PM   #84
Jochim_18's Avatar
I pitted next to the team driver for VBC at the REEDY race "dave Erlich". car looks good on the track and both made the A-main on 17.5, 13.5 and MOD.....
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-12-2012, 01:17 PM   #85
Trader Rating: 24 (100%+)
Send a message via AIM to Max K
The car was very stable. Had plenty of rear grip while not sacrificing steering. Even tho there was low grip at the reedy race my car did not have a feeling of being loose. My fastest laps times in mod were close to the invite guys. 15.4s-15.8s.
RC America - XRAY - HUDY - Trinity - ORCA - Sanwa - ULTI - PROTOform - MaxFX - Slapmaster Tools - ApexRC - SXT
Max K is offline   Reply With Quote
Old 06-12-2012, 01:18 PM   #86
gijoe64's Avatar
For asphalt, will the stock box setup be good or what would you suggest we need when getting it ready. I will be racing 17.5 TC
Springs
Shock oil
I will be racing the Wildfire at the on-road nationals. My Gen Xi is money at Leasure Hours Raceway.
Raymon Robinson
ARC, LRP Go Blue!!
Old 06-12-2012, 01:25 PM   #87
Springs
Shock oil
I would start with my setup from reedy. Me and Dave were running basically the same setup and it worked very well!
Front Setup:
3rd from most inner hole
outer most hole on lower shock mount
40wt oil
hole drilled in shock cap
25% rebound
1.24mm swaybar
xray ecs drive shafts
.5mm wheel spacer
2mm spacer in back of arm for wheel base thick up front
2mm shim under inner link
0 shims under arm mounts
VBC Pink spring
-2 camber
6 droop
5mm ride height
Gear Diff 300,000
Rear Setup:
3rd front inner most hole
35wt oil
25% rebound
1.20mm swaybar inner mount position on arm
2mm shim under outer link
all shims forward on rear wheel base
0.5mm shim under front and rear block
VBC Blue spring
-2 camber
2 droop
5.25mm ride height
Gear Diff 1000
Took 2 screws out of top deck behind spur gear (helped rear end flex more)
Protoform LTCR Body
body roof height just slightly higher than ROAR Rule
I would start with a spool in the front tho. Thats the only thing I would change to start
Old 06-12-2012, 01:30 PM   #88
gijoe64's Avatar
Front Setup:
40wt oil
25% rebound
1.24mm swaybar
.5mm wheel spacer
VBC Pink spring
-2 camber
6 droop
5mm ride height
Gear Diff 300,000
Rear Setup:
35wt oil
25% rebound
VBC Blue spring
-2 camber
2 droop
5.25mm ride height
Gear Diff 1000
Protoform LTCR Body
Thanks for the information! That helps a lot
Raymon Robinson
ARC, LRP Go Blue!!
Old 06-12-2012, 05:15 PM   #89
The Teacher's Avatar
Trader Rating: 47 (100%+)
dumper, check your PMs got some questions...
The Teacher is offline   Reply With Quote
Old 06-13-2012, 07:08 AM   #90
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Front Setup:
40wt oil
25% rebound
1.24mm swaybar
.5mm wheel spacer
VBC Pink spring
-2 camber
6 droop
5mm ride height
Gear Diff 300,000
Rear Setup:
35wt oil
25% rebound
VBC Blue spring
-2 camber
2 droop
5.25mm ride height
Gear Diff 1000
Protoform LTCR Body
Front droop 6 and rear 2? Is this on blocks?
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
