Old 02-22-2013, 11:25 AM   #841
Why do you sell the car?
Lutz is offline   Reply With Quote
Old 02-23-2013, 04:50 AM   #842
butrflynlambie's Avatar
Is there a battery bar or or strap that works with the VBC?
I'm not a big fan of the tape.
butrflynlambie is offline   Reply With Quote
Old 02-23-2013, 06:22 PM   #843
Odin544's Avatar
Trader Rating: 93 (100%+)
Not from VBC. I would bet you could get the Xray setup or another brand to work though.
Maybe even this? http://www.reflexracing.net/RSD-Batt...D6_p_1225.html
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 02-25-2013, 01:59 AM   #844
Titc is over now. So how did it work for the vbc team?
Unfortunately there was a very poor event coverage so i don't know anything :-(
Old 02-25-2013, 04:33 AM   #845
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Ive seen pictures of one they are working on.
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 02-26-2013, 11:03 PM   #846
Does no one know how the vbc team ended up at titc?
Old 02-27-2013, 01:30 AM   #847
I think max said he had a racer in the boosted b final. They had quite a large contingent there
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-28-2013, 08:26 PM   #848
Looks like they have a battery strap coming out.
http://www.vbcracing.com/products/ce...-d-05-vbc-0070
Old 03-03-2013, 05:17 AM   #849
Reese Bobby's Avatar
Hey Lambie,
From what I can tell this isn't a strap / tape replacement as much as a holder?
I see the FF12 has been added to the VBC site, think it looks great. Looks like VBC has a few good things up their sleeve, very glad to see.
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 03-06-2013, 01:12 AM   #850
Hi guys,
Just wanted to ask what you think about the shocks of the wildfire?
I've got my kit now but I'm not that positive about them.
How did you built them and did you use other parts than the kit ones?
Also: which spur gears fit the wildfire? I want to run stock motors and i couldn't fit corally or kimbrough spurs.
Thanks in advance
Chris
Old 03-06-2013, 01:44 AM   #851
Hi guys,
Thanks in advance
Chris
Hi Chris,
I did a visual inspection of the shock bodies before assembly and found some burrs left over from the machining process. I removed them using tweezers being careful not to scratch the finish.
I used the shock upgrade kit which has the shafts and pistons which i found work very well. What are the problems you are having?
I am running a 114 tooth 64dp Panaracer Spur on both kits with no problems. If you really need to, you can also use the XRay spur gear.
VBC Wildfires
Old 03-06-2013, 03:37 PM   #852
My problem with the shocks was that with the std parts they cought air through the bottom and they don't move smooth. I switched the bottom parts and the pistons to some high quality ones and it got better. But now i can feel the burrs in the shock body. The body looks like it's not coated like the ones by other manufacturers or at least not well enough machined for a goof feel.
Regarding the spurs is my problem that my lhs doesn't carry those xray spurs or sth thats similar to them. I ended up sanding the plastic spacer between pulley and spur for about 1mm to fit a kimbrough spur. It was much work but it works now :-)
Old 03-07-2013, 06:03 AM   #853
Using a 87T 48p TC6.1 spur. I just leave out the plastic spacer. It's fine....
Forgetful_Duck is offline   Reply With Quote
Old 03-07-2013, 06:33 AM   #854
Hi Lutz,
Please let us know how the car performs and what your impressions are.
VBC Wildfires
Old 03-07-2013, 02:37 PM   #855
Forgetful_Duck: when you leave out the plastic spacer, doesn't the belt rub against the teeth of the spur? I think the plastic spacer is for guiding the belt so it doesn't break?
Reese Bobby: i will post my impressions sunday or monday after the first test day with the car. Hope it's faster than my photon ex and the arc of a local racer I'll have to compete against at our german nationals the week after :-)
