Old 01-02-2013, 01:20 PM   #796
Anyone? Help would be much appreciated...
Lutz is offline   Reply With Quote
Old 01-02-2013, 05:52 PM   #797
Trader Rating: 39 (100%+)
Originally Posted by Lutz View Post
Hi guys, I want to order a wildfire because I want to switch from top.
What spare parts and option parts would you recommend? And does anybody know if there are parts I can carry over from the photon ex to the wildfire? I mean parts I could use when I break something that I don't have as spare part by vbc but maybe from top. I have tons of top parts left over^^
Thanks for your help
Regards
Chris
Spares you will needs are Many Many Many steering knuckles and c hubs Or just switch over to the T3 ones and they are much better ( you have to file the c-hubs a little but they fit.
Get the Hard bumper, and Have fun.
Cheers
______________________________________________
Jason Deadman
I race toy cars for fun. If I need to explain, you'll never understand.
jdeadman is offline   Reply With Quote
Old 01-03-2013, 01:05 AM   #798
Hi, thanks for your answer :-) why do the steering knuckles break that easy?
Is it because the material is too hard? What is the hatd bumper for?
Does the kit include the double joint cvds or normal ones? Do I need some toe blocks or are they included in the kit? Stabilizers?
I saw there are wishbones in diffrent hardness. Which come in the kit and would others be better?
Sorry for all these questions, but I'm new to vbc :-)
Thanks in advance
Chris
Old 01-03-2013, 05:40 AM   #799
Their first gen knuckles had a weak spot and depending on your track when turning into a corner the front tire is exposed to impacts and this car really turns hard so you will hit the tire on objects. They have a newer version out that is stronger. The A-Arms in teh kit are very hard but you can get softer ones which will also help.
The hard bumper it to protect the suspension from hits. the hard one just protects better
CVD's are what comes with it and it comes with a selection of toe mounts I believe but I got one that was already built.
Jason Deadman
Old 01-03-2013, 01:34 PM   #800
Hm okay thanks for your help :-) I'll look for these parts. Any other recommendations on parts or useful tuning parts?
Old 01-04-2013, 09:15 AM   #801
Reese Bobby's Avatar
Hi Lutz,
A few of the upgrades I found worthwhile:
Shock Upgrade Kit: The teflon pistons and nitride shafts make for some of the smoothest shocks around.
Two piece driveshafts: Remove the inside wheel chatter which occurs on the standard CVD.
Centre Servo Mount: Helps eliminate tweak by mounting the servo centrally.
Hope this helps.
VBC Wildfires
Orca - Revolectrix - Sanwa - SMC
Reese Bobby is offline   Reply With Quote
Old 01-04-2013, 02:04 PM   #802
Thank you very much :-) yes this helps.
I've read that there are many different types of materials for different parts available. Are the stock ones the fastest or doesn't it matter and they are just different in durability?
Should I buy anything else than the mentioned option parts? Belts, chassis, plastics?
Sorry to bother you all too much.
Old 01-04-2013, 02:08 PM   #803
Potoczak's Avatar
Trader Rating: 109 (100%+)
I would buy some of the type r belts, the stock ones are like plastic. Also you could pick up the e25 rear tow plate as a tuning option. Also the sway bar kit for the front and rear, those are great tuning options.
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 01-05-2013, 09:43 AM   #804
Thanks for the answer :-)
Now I've just noticed that vbc has a new kit with several tuning parts integrated^^
http://www.vbcracing.com/collections...-d-05-vbc-0071
I believe if I buy this one I just need the plastic spare parts? And the toe blocks and belts of course.
Did someone try the double joint cvds with a mod motor or a 10.5 yet?
Do they last long or will they break easy?
Old 01-05-2013, 12:07 PM   #805
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Yes, the new 'team' kit has all the hop ups included. But as previously stated, depending on your type of track you will need parts like:
C- hubs
Spindles
Arms
Now that the 'team' kit comes with the upgraded belts, you won't need to replace the kit belts. (but would be good to have a rear belt spare)
Also, it's a good idea to get the c-hub bushings (if the c-hub breaks and you lose them on the track).
I have been running the car in mod on large outdoor tracks and yet to break a single part due to crashing. But did break rear belts (even the upgraded ones, but that's part and parcel of mod racing). The DCJ cvds are awesome! They are tough as and they are a captured pin design (no grub screws)!!!
HTH...
:::RCMaker.com.au:::Speedy RC.com.au:::
DirtyDog3375 is offline   Reply With Quote
Old 01-05-2013, 02:12 PM   #806
Hi Lutz,
IMO, the Team Kit looks like what you need, includes all the options listed above. I would also order spare suspension parts just in case and some belts.
Agreed, with a previous post, the two part drive shafts are durable and no need for concern there.
I think its a great kit, looking forward to hear how things go.
VBC Wildfires
Old 01-05-2013, 03:16 PM   #807
Alright, thanks for your help guys :-)
So now is the time come to sell all my old cars and switch to the vbc :-)
You've helped me alot and hope to get my new ride soon :-)
Thanks again
Old 01-08-2013, 02:19 PM   #808
roadkill's Avatar
Trader Rating: 126 (100%+)
Send a message via Yahoo to roadkill
what type of servo saver are you guys running on your vbc?
I put a small kimbrough ss on and i could not get the linkage to go all the way to the right,left was fine,so I put the stock servo arm on the servo,now i get steering in both direction,but no protection from wall hits on the wheel area.
Keeper of the check book, Pit butler,(for hire) President and life long member of the Black Flag Club,
roadkill is offline   Reply With Quote
Old 01-13-2013, 10:45 AM   #809
Hey roadkill,
I am also running the small Kimbrough SS and had the same problem. I made a small nick in the SS where it would touch the steering pivot to allow more travel. This seems to work well. Servo is protected and L/R steering swing reaches the stops in the hubs.
All the best.
VBC Wildfires
Old 01-13-2013, 11:01 AM   #810
Potoczak's Avatar
I am currently running the xray stiff servo saver without any problems.
Pete Potoczak
